a triple D cell host with side switch for modding purposes
5 posts / 0 new
Budgeteer
Budgeteer's picture
Last seen: 6 years 2 months ago
Found here:
http://www.tinydeal.com/big-3x-d-size-battery-flashlight-ultra-bright-li...
Anyone have experience on this one?
The idea is to fit a XM-L star on the stock pill without boring it adittionally and hoping the reflector is from aluminum. It should be since the incandescent bulb might get too hot for a plastic reflector or perhaps not if it uses a poor bulb.
Also would like to use the KD 2,8A linear driver (probably modded to 2,45A or less) and powering it by classic alkaline D cells perhaps Ni-mh in future. The question is would the alkalines be able to sustain 2,5A draw for a extened time?
What's on the other side of the pill? Suitable to install a driver?
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
Edited by: Budgeteer on 03/08/2011 - 11:07
srfreddy
Last seen: 7 years 2 months ago
Nice maglite copy-i doubt it has an AL reflector. Just use a mag.
Don
Don's picture
Last seen: 2 years 7 months ago
About an hour at 2.5A with decent alkalines, a lot less with cheapies. Given the cost of D Duracells round here it would not take long for rechargeables to be very well worthwhile.
http://www1.duracell.com/oem/Pdf/others/ATB-5.pdf
The voltage is likely to sag too low to light the LED in less than that. The Duracell chart is discharge to 0.8V - depends on how gracefully the driver handles low voltage.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Don
Don's picture
Problem is that in most of the world Mags are outrageously expensive. I could buy three of those for the normal price of a 3D Mag around here.
Budgeteer
Budgeteer's picture
That was the whole point. Smile
