As much as I try to keep track of charged/discharged/new batteries I still find loose batteries in an unknown state. My Ni-MHs can be tossed in a charger, so I guess my bigger need is for the AA/AAA/C/D alkalines that I still use for select purposes. (I think my wife is the culprit who throws them in the drawer in an unknown state ).
I bought a small one from Radio Shack but it pretty much says everything is good. It is a POS. I have a multimeter but it is kept out in the garage. Is there a reliable, budget-minded battery tester?
Those with a decent charge I consider good. Those that are low go into a pile for uses like remotes, cordless mouse, etc until they are truly drained.
Just putting a DMM on a battery tells you very little (unless the cell is as dead as Elvis). You need some kind of load on the cell to sort the wheat from the chaff…
Many years ago at work , we had a simple method of testing alkaline cells … We just used an Avo Model 8 on the 10A range as the load … If it still read at the top end of the range after a few seconds then the cell was OK … A bad cell drops very rapidly … Simple !
I have a cheap tester at home and I look for how fast the meter needle moves … If it clicks loudly as it hits the full-scale-deflection , then the battery is OK … So I do it by ear … Simple !
