A big thanks to Old Lumens and his fantastically well documented Maglite mods that were the inspiration for this mod. I've wanted to do a maglite mod for ages and getting a flashlight appreciating cousin in the Secret Santa for this year's early family Christmas was just the excuse I needed (and provided an excellent excuse to do some other Nichia 219 swaps :)).
The light is direct drive with a machined pedestal pretty much identical in form and function to the copper ones OL makes, with a 16mm Nichia 219 from Illumination Supply and Carclo narrow clear (10003?) 20mm optic as that's what I had laying around.
pedestal before being cut off its rod (scrounged from an old piece of lab equipment in the skip)
cut off, tapped and polished. If I were to do it again I'd stop being a cheapskate and buy some AA as the screws caused no end of problems.
Other end of pedestal, showing the hole into which the isolating washer is going to get pressed.
all the bits for the pedestal, including the washer and a small piece of unknown metal (brass?) for the +ve contact
+ve contact soldered up. Conveniently the end of the rod I scrounged was drilled and tapped already, so the wire is going straight up the centre of the pedestal.
Pill wired up. -ve wire added later to improve contact with the pill/ head.
Other end of the pill. This actually came out as I intended, which was a pleasant surprise!
Pill pressed into the head, with a thin layer of thermal paste, after literally HOURS spent grinding down the threads with my dremel. I really need to get a better lathe chuck :)
Showing the added -ve wire a bit better. No pics of the head before I put the pill in as I was too shagged out.
bottom of the pill. Isolating disk just clears the battery tube. Also sanded down the end of the battery tube so it completes an electrical path from LED -ve to pill to battery -ve.
Finished! Added some OL inspired polishing touches using a few pellets of NaOH and Mother's Magic Mag Wheel Shine
Sneakily put back into the packaging so it looks like I'm just cheaping out on his present by buying a $8 minimag from Walmart :)
No beamshots I'm afraid, as it was raining biblically after I finished it then I had to wrap it up and pack it into the car. I think I have some XM-L/ Carclo narrow beamshots around somewhere though. Really nice beam pattern, mix of spot and flood. Not as throwy as my Nichia modded RC-G2, but a more even beam. Joe was very happy with it, especially as his previous torch kicked the bucket only the week before. It was lovely and bright with 2 alkaline cells and pretty dim with NiMh, but that's to be expected. Nice to have the option though.
I really do need a better chuck and boring bar though...
