Shadow JM26 Driver (Place for more AMC7135)
101 posts / 0 new
Slacker
Last seen: 3 years 11 months ago
Hello!
So, I’ve just bought the Shadow JM26 and when I opened it up, I saw that the driver holds 8xAMC7135 (2.8 A), BUT there’s place for 3 4 more! Should I add another one, will it work? (Or maybe more than 1) :bigsmile:
Photo:
Thanks!
Regards,
Edited by: Slacker on 01/04/2013 - 14:56
JonnyC
JonnyC's picture
Last seen: 10 months 3 weeks ago
Do it!
Slacker
Fine, I will! How many? :bigsmile:
First I have to buy some, I have none at home and they don’t sell those in Sweden so I will have to order. It might take a while before they arrive Sad
MattSPL
Last seen: 1 year 3 months ago
How did you get the driver out?
Would stacking chips on the existing chips work?
scaru
scaru's picture
Last seen: 2 years 11 months ago
Hmmm... What is the diameter of that driver? But, yes add some more chips!
texas shooter
Last seen: 14 hours 53 min ago
Looks like the top 2 spots are the only ones with enough clearance. Whats the other side look like?
Slacker
MattSPL:
I used a tweezer for the whole process. Unscrew and then lift the driver up, it’s easy as pie:
Dunno about stacking, but it is really necessary? You could replace them all with 380 mA version and you’ll get 4180 mA Shocked
Yeah, I will order a bunch.
+scaru: +
Driver diameter is about 28 mm (~1.1 inch)
JonnyC
JonnyC's picture
FastTech seems like a good place to get them, as they sell them in quantities of 10 for cheap.  I have a few dozen coming my way.
MattSPL
Thanks for the reply and pics Smile
I have an SL3 i might open up Smile
Chicago X
Chicago X's picture
Last seen: 6 years 4 months ago
Does the "38M" designation not indicate the 380 mA version of these chips?
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
Slacker
texas shooter:
Clearance is not a problem Smile
JonnyC
OK, thanks I will look it up! But as I need some 26650 too, I might buy from intl-outdoor. They use Singpost on packages with tracking number, which takes just a few days to arrive in Sweden.
I ordered the JM26 from there, and here’s how fast I got it:
2012-12-26 15:06 —> Left Singapore
2012-12-30 13:57 —> Arrived in Sweden
I dunno what FastTech uses, it’s great if they use Singpost or HKP though.
MattSPL
No problem! Smile
Chicago X
I don’t know actually, I’ve also been thinking about that. Can someone else confirm this? Would be good to know, so that I know what to buy. I’m not at home so I haven’t got my DMM
MattSPL
I will have a look inside my SL3 and post pics later. The SL3 is 4.5A, so it will be interesting to see how they differ, and might help in knowing what to do to get more power Smile
JonnyC
JonnyC's picture
So jealous.
And yeah, 7135's are so cheap that it doesn't really matter where you buy them.
JonnyC
JonnyC's picture
Ah, I never noticed that.  Looking at the pics on intl-outdoor, that does seem to be correct.
Slacker
Update: The guy living here had a multimeter! (Dunno about quality though, lol) On full it draws 3030 mA, so those are 380 mA chips indeed. I’ll probably just add one more then :bigsmile: Feels like I’m pushing the XM-L too hard at 4.2A hehe!
Slacker
wrote:
Slacker wrote:
*Update: The guy living here had a multimeter! (Dunno about quality though, lol) On full it draws 3030 mA, so those are 380 mA chips indeed. I’ll probably just add one more then :bigsmile: *
GREAT NEWS. And when it gets really hot, please cook me a pizza or bake me some crisps.
I wouldn’t worry about it getting too hot Wink I mostly use it outside and it’s currently -22°C here (-7.6°F). -30°C to -40°C isn’t unusual here (-22°F to -40°F)
gords1001
gords1001's picture
Last seen: 1 year 4 months ago
Anyone else interested in the stars, they look like nanjg mode selection stars….
Toaster79
Last seen: 2 years 9 months ago
Which they are not. They are jsut bling factor. The center golden part of the circle, the stars and the masked part of the circle are all one same surface for the positive contact which leads through the vias on the other side of the board where the red wire is soldered.
MattSPL
I couldn’t get the driver out. I need to get a good tweezers or something as the disc is too tight.
Tom E
Tom E's picture
Last seen: 50 min 9 sec ago
 So you have 3.04A total in the design. I would recommend adding 2 350's or 2 380's, anymore won't do you much good - just verified that on a modified Crelant 7G9 - I dropped 4.56A (measured 4.50A) down to 3.80A, dropped 2 380 7135's, and the ceiling bounce test saw no difference at all. In theory, the XML's reach their peak at 3.5A, but I go for 3.7-3.85A, assuming there is some loss going to the LED.
 Buzz out those spots to see if they are trully parallel with the rest of the mounted 7135's, if so, use them, measuring after will confirm they are soldered ok.
MRsDNF
MRsDNF's picture
Last seen: 17 min 28 sec ago
Slacker. There is no question at all you should be adding the full compliment of 3 chips. If your not happy you can always remove 1 or 2 chips. We need to have before and after night shots as well. Thanks.
Tom E
Tom E's picture
 Do you think 3.8A to 4.1A will make a difference in brightness? I'm wondering how Match's results (http://budgetlightforum.com/node/2603
) work in the real world myself. He shows a peak starting at 4.1A, but very little gain above 3.8A or so. Haven't come across any corraborating evidence in real flashlight tests.
MRsDNF
MRsDNF's picture
Seriously I would try one at a time and check for heat build up. I have no idea what the heat sinking is like on this flashlight. The hotter the LED the less efficient. Before and after shots with the same camera settings will give a good idea whether the light is working better or not. 3 amps is the sweet spot for output and battery life. Good luck on your mission.
Hikelite
Last seen: 3 weeks 4 days ago
Those 38M 7315 are of course 380mA chips. The 350mA ones are 35"x", so the first two digits are that tell you the rating.
There are empty pads, look at that board, no need for staking.
Looks like there is room for a 4th chip, the ground wire is soldered to the pad where one of the pins should be. I don't know about the clearance.
Those stars don't look like any connections to anything, just unmasked copper (gold plated), esthetics only.
MattSPL
Here’s the driver of my Shadow SL3
Hikelite
MattSPL wrote:
Here's the driver of my Shadow SL3 !http://farm9.staticflickr.com/8359/8345574235_d9b3a28f82_z.jpg![/quote]
That's 4560mA. You have exactly 50% more current, but I  doubt you have 50% more brightness compared to 3040mA.
I initially thought you soldered those extra 4 chips yourself, but did you?
MattSPL
Hikelite wrote:
MattSPL wrote:
Here’s the driver of my Shadow SL3 !http://farm9.staticflickr.com/8359/8345574235_d9b3a28f82_z.jpg!
That’s 4560mA. You have exactly 50% more current, but I  doubt you have 50% more brightness compared to 3040mA.
No, this is how the SL3 comes. It is 4.5A as standard.
Do you think it’s possible to stack chips to increase the current?
scaru
scaru's picture
No, this is how the SL3 comes. It is 4.5A as standard. Do you think it's possible to stack chips to increase the current?[/quote]
Yes, it definitely is. So all you would have to do is stack a chip on top of every current chip and you will get a 9 amp one. Smile
Hikelite
Yes it's possible to stack some more chips.
Sorry I looked only at the driver and I didn't realize you have written "Shadow SL3", I thought it was the JM26 driver.
Anyway, as I was suspecting there are 4 empty places on the JM26's driver, not 3.
dthrckt
dthrckt's picture
oh man
i might have to buy an sl3
that’s the best news i’ve heard in awhile
____________________
Girls can shoot!
MattSPL
Great news, thanks Smile
So can I stack any number of chips in any position? Like just one chip anywhere, or an extra chip on each chip?
Cheers
Matt
