Fenix ARB-L2 Review by old4570 |
Link to manufacturers product page http://www.fenixlight.com/viewnproduct.asp?id=112 |
Multimeter reads the actual Voltage of the battery rather than relying on the Chargers interpritation . |
Wow , fits the Tr001 charger , so not overly long for a 18650 . Yes I still use my TR-001 after all these years . |
The Fenix battery really does try to discharge as much current above 3v as possible , which is very nice I must confess . 1A - Gave some 2503mAh capacity 2A - Gave some 2539mAh capacity 3A - Gave some 2559mah capacity A very stable and some what uniform result across a large variation in discharge . This is a somewhat expensive battery , but from the results so far looks to perform well . I will update after doing some discharge for current [ Max Amp readings ] . |
Those pictures are a little large.. :D
Thanks for the review. :) BAK inside IIRC?
