DQG 18650 EDC--World's Smallest 18650 Flashlight
698 posts / 0 new
Orion
Orion's picture
Last seen: 6 years 6 months ago
photon1k wrote:
That titanium (looks green to me) is very nice looking. Are these still available to be ordered?
Yes, they can still be purchased : HERE
“It is a far, far better thing that I do, than I have ever done; it is a far, far better rest that I go to than I have ever known.” – Sydney Carton in ‘A Tale of Two Cities’ by Charles Dickens (1812-1870).
Kevin
Last seen: 7 years 5 months ago
Would someone post a couple of beam shots showing off those TIR optics please?
ohaya
Last seen: 2 years 6 months ago
Looks like mine are in town :)!
Edit: What’s weird is that I have two coming in, but they’ve arriving via different routes :)!
borstar_micke
Last seen: 3 years 4 days ago
Mine flickers a lot and skips modes when twisting it, only solution is to twist it really hard to closed every time I turn it on or change modes.
The threads were gritty and dry, but a little cleaning and grease solved that.
Otherwise it’s got the perfect size, fits the palm of my hand nicely, and it’s brighter and throwier than my SC52 on 14500:s.
My Maratacs or Itp:s are a lot better when it comes to that, smoother and more consistent in their mode-changing.
tolight
edit oops… confused with a different light altogether… sorry!
phantom23
phantom23's picture
Last seen: 1 day 10 hours ago
the wrote:
Quick throw figures:
- Olight S20 Baton ~3kcd
- DQG 18650 NW ~4kcd
- DQG 18650 CW ~5kcd
(measured at 2m, calculated back to 1m)
Thanks. Not I know I should stay away from all of them Wink
RedForest UK
RedForest UK's picture
Last seen: 11 months 6 days ago
Has anyone been able to confirm the buck only or buck/boost nature of the circuit?
Does it drop out of regulation at a particular input voltage or keep upping it until the 2.5v ‘low voltage protection’ kicks in?
fonzeka
fonzeka's picture
There is no boost and there seems to be no under voltage protection, at around 2.4V input it barely glows.
Tested with lab power supply and long cables and from 3.8V it gives the full ~1.9A on high, I tested up to 4.5V and it was the same current.
I got the XM-L2 version.
RedForest UK
Thanks for that. What voltage does it drop below 1.5 amps draw?
fonzeka
fonzeka's picture
Hmm can’t get a stable current reading and tell for sure.
If I try with 3.3V it seems to be to low for 1.5A but it’s fluctuating up and down.
It also seems to warm up very quick which makes forward voltage go down and make it pull more current.
Nake
Last seen: 4 years 1 month ago
subscribing
ohaya
I can’t believe this: Been waiting for these for so long, and they arrive at my house today, but REQUIRED SIGNATURE, and no one was home. AARGH! Now I have to wait for another night/day to get them :)!
tolight
I so love that when it works… and absolutely hate it when it doesn’t… at least you have a delivery tag… my mailbox had bills in it….
Suncoaster
Suncoaster's picture
Last seen: 2 days 15 hours ago
Location: Where the girls are green and the grass is pretty.
Got mine this morning, from the post office. :bigsmile:
This thing is almost my holy grail of lights.
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
MRsDNF
MRsDNF's picture
Last seen: 7 hours 29 min ago
Suncoaster wrote:
Got mine this morning, from the post office. :bigsmile: This thing is almost my holy grail of lights.
Almost? How does it compare to your TN31?
LQQK
N4UD
Suncoaster
It’s a lot smaller ! Wink
Assembled length = 9cm
Body is a simple 7cm ano tube closed at the tail.
6 front threads, an O-ring groove, no tailcap.
Some knurls, steps, and a clip groove and clip.
Very light.
4 coil 1cm high spring is jammed into the base.
The head is 2.5cm long, 2 threads screw on SS bezel, O-ring, TIR.
The pill and driver are behind a partition with the LED poking through a hole.
Colour: kind of olive green/khaki.
Tiny 18650, 3 mode.
Could be my next standard for EDC lights.
lionheart_2281
lionheart_2281's picture
Last seen: 1 hour 27 min ago
Very light.
Tiny 18650, 3 mode.
More of an EDC then a SC52 or the XIAOZHI?
Ric-CN
Ric-CN's picture
Last seen: 3 years 8 months ago
Hi Guys ,
Here is to inform you that the factory made a mistake when assemblying DQG 18650 O ring,Which makes the beam a bit ringy (as “the” said in his post).
Here is the right way to install Head-O-Ring.
Below is the Optic lens picture, The O ring should be installed to The “Green” position.
Could you please take out the head o ring and install it again? It will make the beam perfect.
It’s very easy. Only 2 steps
1. Take the Head O-Ring off
2. Install the O-ring to Right position.
Thanks
Ric
BTU flashlight; DQG Series Flashlight ; Torch Component
ohaya
Ric-CN wrote:
Hi Guys ,
Thanks
Ric
Are you saying that the O-ring is in one position (green?) and to move it to a different position (blue?)? It’s hard to see the lines on the interior of your drawing.
Edit: Or did you mean to move it from the blue position to the green position? FYI, I don’t have the lights yet, so can’t visualize it :).
InfinitusEquitas
InfinitusEquitas's picture
Last seen: 4 years 3 months ago
Wouldn't the ring in the blue position be a lot smaller though?
_the_
_the_'s picture
Last seen: 1 month 3 days ago
ohaya wrote:
Are you saying that the O-ring is in one position (green?) and to move it to a different position (blue?)? It's hard to see the lines on the interior of your drawing. Edit: Or did you mean to move it from the blue position to the green position? FYI, I don't have the lights yet, so can't visualize it :).
No. The O-ring was installed between TIR and bezel, but it should be between TIR and body.
I'm currently testing the effects of this change.. Please stay tuned.
=the=
djozz
djozz's picture
Last seen: 4 hours 52 min ago
My guess is that it means that now the o-ring is just in front of the tir but should be just behind the tir. (without having received the light Laughing)
(edit: you beat me to that _the_ )
_the_
_the_'s picture
Yes. That really helps! No visible rings and wider, smoother, more even flood. Smile
Before:
CW updated, NW original:
Both updated:
CW change as mouseover (mouse over for updated):
..and a bonus tint comparison DQG Tiny 18650 CW vs. Olight S20:
=the=
stevetexas
Last seen: 7 years 1 month ago
Unscrew bezel
Remove TIR lens
Take O ring off the groove on the front of the lens
Insert lens into bezel then drop O ring into place on the back of the lens
Put the bezel back on……done
Suncoaster
Yes, it’s much smaller than the Xiaozhi, but not as tactile (not tactical) as the C303.
I don’t have an SC52, but do have these:
DQG AA, 270-T80, Xiaozhi, Convoy S2, DQG Tiny 18650, UF-2100, C303, Ultrafire S5, Small Sun ZY-C1 (16340)
ohaya
DELETED
ohaya
Hi RIC,
Actually, so this brings up a question: The original place where the O-ring was had a groove, like it was meant to have an O-ring there. Since we’re removing the O-ring from the TIR lens, is the water-proofing still intact? Seems like water could enter from the front of the lens?
Thanks, and thanks also for these lights!
Jim
ohaya
BTW, the clip looks very nice!
myst999
Last seen: 2 weeks 6 days ago
Wow! Much nicer hotspot and flood area now Smile
