DQG 18650 EDC--World's Smallest 18650 Flashlight
698 posts / 0 new
pod7381
Last seen: 6 months 1 week ago
I’m a little confused. Are we using BOTH white o-rings. The one wrongly installed at the factory AND the one that came loose in the box? The first one going behind the lens instead of in the groove in front of the lens. And the second one going on the threads connecting the upper body to the bezel as shown in Ohaya’s picture?
ohaya
Last seen: 2 years 6 months ago
I think it’s not both, but rather move the one that is on/around the TIR lens to the threaded area, but then, there’s the question I posted about what waterproofs the lens/bezel area.
Apparently when the O-ring was around the TIR lens, it was causing some rings on the beamshots.
xevious
xevious's picture
Last seen: 6 hours 3 min ago
the wrote:
The values above are precise measurements for both of my lights: Black is 19.0mm and the other is 18.7mm
fonzeka wrote:
Inside diameter of my Ti coloured is also 18.7mm. The battery tube is exactly 70mm deep and the bottom spring adds at least 1mm.
Thanks for the measurements. Well that’s bizarre—the black version has a larger tube diameter?? Why would they bother to machine a different tube for the outer coating? Unless it was outsourced and the manufacturer allowed some variance in the boring.
djozz
djozz's picture
Last seen: 3 hours 38 min ago
ohaya wrote:
pod7381 wrote:
I'm a little confused. Are we using BOTH white o-rings. The one wrongly installed at the factory AND the one that came loose in the box? The first one going behind the lens instead of in the groove in front of the lens. And the second one going on the threads connecting the upper body to the bezel as shown in Ohaya's picture?
I think it's not both, but rather move the one that is on/around the TIR lens to the threaded area, but then, there's the question I posted about what waterproofs the lens/bezel area. Apparently when the O-ring was around the TIR lens, it was causing some rings on the beamshots.
 I do not have the light yet, but I'm sure the o-ring does not go around the threading (photo is wrong), but goes around the underside of the tir. When the bezel is screwed on it sits on top of the head part, not around it.
pod7381
djozz wrote:
ohaya wrote:
I think it’s not both, but rather move the one that is on/around the TIR lens to the threaded area, but then, there’s the question I posted about what waterproofs the lens/bezel area. Apparently when the O-ring was around the TIR lens, it was causing some rings on the beamshots.
 I do not have the light yet, but I’m sure the o-ring does not go around the threading (photo is wrong), but goes around the underside of the tir. When the bezel is screwed on it sits on top of the head part, not around it.
OK, so the white o-ring that came in the box is just a spare and is not needed on the threads.
Thanks djozz
ohaya
Hi,
Oh. You’re right. That makes more sense plus answers my question (also matches RIC’s original drawing, I think):
ohaya
Thanks djozz
I got two lights, and there’s one extra white O-ring, and a different number of the smaller black O-rings in the boxes.
_the_
_the_'s picture
Last seen: 1 month 1 week ago
ohaya wrote:
Hi, Oh. You're right. That makes more sense plus answers my question (also matches RIC's original drawing, I think)
Exactly. That's how I did it. This way the TIR is located slightly higher / further away from emitter, and it works! Plus the construction is still water tight, even more than the original. Smile
=the=
ohaya
Hi,
I got two of these lights, and, FYI, one of them, the black one, already had the O-ring in the right place. I only had to move it one my Titanium one.
JohnnyMac
JohnnyMac's picture
ohaya wrote:
stevetexas wrote:
Unscrew bezel Remove TIR lens Take O ring off the groove on the front of the lens Insert lens into bezel then drop O ring into place on the back of the lens Put the bezel back on......done
Hi, Thanks. For those "visualization-challenged" like I am, here's what the front of the light looks like with the white O-ring *correctly* installed (I think). !! Jim Edit: P.S. You can see the front bezel with the TIR lens in it in the background. Just pull the TIR lens out, and you'll see the white O-ring on there (INCORRECTLY). Remove the white O-ring, and put it on the light as shown in the pic above.
Jim, please delete your post or picture so it doesn't confuse people with the incorrect information.  Wink
lionheart_2281
lionheart_2281's picture
Last seen: 4 hours 7 min ago
Suncoaster wrote:
lionheart_2281 wrote:
Suncoaster wrote:
Could be my next standard for EDC lights.
More of an EDC then a SC52 or the XIAOZHI?
Yes, it’s much smaller than the Xiaozhi, but not as tactile (not tactical) as the C303.
I don’t have an SC52, but do have these:
DQG AA, 270-T80, Xiaozhi, Convoy S2, DQG Tiny 18650, UF-2100, C303, Ultrafire S5, Small Sun ZY-C1 (16340)
Great size comparison, thanks for the awesome pic
MRsDNF
MRsDNF's picture
Last seen: 6 hours 22 min ago
+1 to the above. It puts it in perspective very well. Thanks Suncoaster.
Firelight2
Firelight2's picture
Last seen: 1 hour 11 min ago
My black DQG 18650 with neutral T6 arrived today.
Initial thoughts:
*Very lightweight and small for an 18650 light
*Feels good in the hand. Nice size and quite grippy.
*Very nice beam pattern with good tint.
*The clip was VERY hard to remove. That sucker didn’t want to come off at all. I had to pry it off with a screwdriver. This caused a few scratches to the anodizing around the top edge of teh clip slot. Even though this isn’t a screwed on clip, if you use it for pocket carry I think there is very little chance the clip would come off accidentally.
*Upon receiving the light, the bezel o-ring needed to be reinstalled as it was in the wrong position. This was expected based on the earlier notice from Ric.
*The head turned extremely easily when I received the light. Close inspection revealed that there was only 1 o-ring between the head and the body even though there was a second slot. I grabbed one of the spare black o-rings from the box and stuck it in this slot to give much better tension between head and body.
*It is hard to reliably change modes without 2 hands. One-handed operation seems to often result in jumped modes.
*I haven’t tested it yet, but I doubt this light will work with flat top cells.
ohaya
JohnnyMac wrote:
ohaya wrote:
stevetexas wrote:
Unscrew bezel Remove TIR lens Take O ring off the groove on the front of the lens Insert lens into bezel then drop O ring into place on the back of the lens Put the bezel back on……done
Hi, Thanks. For those “visualization-challenged” like I am, here’s what the front of the light looks like with the white O-ring correctly installed (I think). !! Jim Edit: P.S. You can see the front bezel with the TIR lens in it in the background. Just pull the TIR lens out, and you’ll see the white O-ring on there (INCORRECTLY). Remove the white O-ring, and put it on the light as shown in the pic above.
Jim, please delete your post or picture so it doesn’t confuse people with the incorrect information.  Wink
Done.
Firelight2
Do NOT attempt to use flat top cells in this light.
I just tried a Zebralight brand 18650 in it.
Not only did it not work, but the cell is now completely stuck and cannot be removed. I may have to toss this brand new light. YUCK!! Tired
RedForest UK
RedForest UK's picture
Last seen: 11 months 1 week ago
Try the taping to a hammer trick.
Firelight2
Whew!
I managed to remove the battery, but it was tough. I soldered a strip of tin to the end of the cell as a handle, then used pliers to grip the handle and remove the cell. It took some effort, but it worked.
Aaronhome27
After seeing so many that got good units I am a little irritated as if the first 100 were just rushed out the door. As stated earlier I have all kinds of little quircks with mine that many folks do not. I did replace the O-Ring as the diagram shows and it did fix the rings. The issue there with mine was as soon as I took my metal ring off the debris from the optics where if was forced together and ultimately crashed, fell into the optics. pretty irritating. I hope everyone else gets a good one. For now I will reserve further judgement till I get a reply back.
I may do one better and put together a video review to post on it as soon as I get time.
Slapped a quick video together anyway. As you can see in the video the Sanyo UR18650ZT do fit till they get 3/4 of the way down the tube where the machining is not complete. Also I show tapping the light to switch modes, it looks like I am hitting it hard somewhat but I am not. The noise you hear is the battery rattling around in the tube. Also if you look at the end of the video you can also see the white crush ring on the optics where it was crushed during final assembly I imagine. I did not take time to show the other issues or the debris in the optics from loosening the optics to install the O-Ring correctly. Like I said, I believe I may have gotten the lemon. i did post this on another forum but figured I might as well add it here as well.
DQG 18650 EDC
ohaya
Initial thoughts:
Hi,
Where’s that 2nd slot for the O-ring? I don’t see it on either of mine… or may be I’m just mis-seeing it? Pic would be nice?
PewPew
Last seen: 7 years 5 months ago
Don’t have one in hand yet, but to fix the bump-for-mode-change problem, could you reach down there with some hemostats or long needle nose pliers and stretch the spring a little? I imagine the mode change is coming from the battery bouncing just enough to break contact.
xevious
xevious's picture
I’m glad I held of on buying one of these. Best to give it a few months so they can work out the kinks and produce a light that has gone through sufficient quality control.
Aaronhome27
I was able to pull the spring and stretch it a bit but it is pretty weak and it really didn’t do it much good. I also sanded the tube down to allow the Sanyo to slide in. The light will not allow any of the protected cells 69 +mm in length as well. They are too long. That leaves out the Panasonic and Sanyo 2800+mah protected batteries it was originally said to be compatible with.
ohaya
ohaya wrote:
Initial thoughts:
Hi,
I figured out where that slot for the 2nd O-ring is. Pic below. The head feels much more secure after adding the 2nd O-ring, and it doesn’t turn on everytime you touch it now.
Also, BTW, the small, black O-ring is the one that goes on both the 1st and 2nd slots, not the larger white O-ring. FYI, one of my lights had NEITHER the 1st or 2nd O-ring:
I took the picture with the Ti one, because you can’t really see the O-rings on the black one.
Edit: The threads and the O-rings are as dry as dust – I’ll be putting some grease on now…
tolight
Last seen: 6 years 6 months ago
I still have not received my light… and my tracking still does not work.
Is there anyone else who’s experiencing the same thing?
Also, I just checked the FF website and the original list of names is no longer there… including mine… should I be worried?
Anyone know what’s going on?
Thanks!
ohaya
Thanks!
Hi,
I don’t know, but they may have eliminated the list because they’re done shipping the pre-orders. Maybe if you see RIC online, you can PM him, or email him via their website?
tolight
Thanks!
Hi,
Thanks for the suggestion… I emailed him earlier with a previous query but got no answer… will try pm as well…
MosesM
MosesM's picture
Weird there’s so much quality variances….My Keeppower 18650 3400mAH batteries fit in my black DQG 18650 w/ XM-L2 without a problem. The head on mine is nice and tight even with only one o-ring.
Well I’ve had this light for two days now and am still amazed that it’s the same size as my larger single CR123 lights e.g. HDS Clicky, SF E1L…
Chicken Drumstick
Last seen: 14 hours 35 min ago
Anyone in the UK got theirs yet?
My tracking does work on Singpost. Says it shipped to the UK on the 30th April and arrived on the 3rd of May – hooray. Sadly 7 days later from touching down in the UK and no sign of it Sad
djozz
djozz's picture
Mine arrived today in Amsterdam, hooray! Laughing . And I am delighted, it is just as nice as I came to expect, I think it looks extremely cool. I am lucky to have gotten one that isn't faulty. The finish is a nice matt black, it came with the white o-ring in the wrong position, with the two black ones in place, one spare white o-ring and two spare black ones. Threading was dry, cleaned it a bit and lubed it with a little silicone grease, one-handed operation works fine. The neutral led is quite cool, rough guess 5500K.  I think this will be a good bike-light too.
Chicken Drumstick
Mine arrived today!!!
Not exactly trouble free, but I do like it.
Review here: http://budgetlightforum.com/node/21432
