Test / Review: Panasonic NCR18650B Protected 3400mAh (Green)
49 replies [Last post]
HKJ
HKJ's picture
Last seen: 21 sec ago
Title: ★★★★★
DSC_1075
Official specifications:
  • Original Panasonic (Industrial) products, Made in Japan
  • Capacity: 3400mAh (Min 3250mAh)
  • Charging volt: 4.2v
  • Max charge current 0.7C 2A
  • Recommend discharge current 1C 2.9A
  • Discharge Termination Voltage: 2.5V
  • Protection kicks in : 2.75v and 4.2v
  • Over-Charging / Draining at 4.2v / 2.75v
  • Protection Circuit installed
  • Weight : 47g
  • Size 18.50mm x 70.5mm (Larger than non-protected)
  • The voltage of full charge & empty condition is 4.2v & 2.75v respectively
The above specifications is from the dealers website and there is a few errors in it!
Panasonic%20NCR18650B%20Protected%203400mAh%20(Green)-info
This battery is not made by Panasonic. The cell inside the battery is from Panasonic, the protection cirucit and the assembly work is done by somebody else.
Notice the length of the battery, it is the longest 18650 I have seen to date.
DSC_1073 DSC_1074
DSC_1076 DSC_1077
DSC_1078
DSC_1079
Panasonic%20NCR18650B%20Protected%203400mAh%20(Green)-Capacity
The capacity looks very good as expected for a Panasonic 3400 mAh battery.
Panasonic%20NCR18650B%20Protected%203400mAh%20(Green)-CapacityTimeHours
Panasonic%20NCR18650B%20Protected%203400mAh%20(Green)-Energy
Panasonic%20NCR18650B%20Protected%203400mAh%20(Green)-PowerLoadTime
Panasonic%20NCR18650B%20Protected%203400mAh%20(Green)-TripCurrent
The protection at 6.5A makes it very difficult to overload these batteries, but is high enough for any normal use.
Panasonic%20NCR18650B%20Protected%203400mAh%20(Green)-Charge
Conclusion
This is a very good battery, except for the length. Only buy it if you know you equipment can use a very long battery!
Notes and links
__________________
My website with reviews of flashlights, chargers and batteries: http://lygte-info.dk/
PierCC
Last seen: 7 weeks 16 hours ago
Title: ★★
thank you very much, as
thank you very much, as always, for these very useful information
kreisler
kreisler's picture
Last seen: 23 min 50 sec ago
Title: ★★★★★
Thanks you very much!!There
There are many products of Protected NCR18650B on the market! How many do we know? Enerdan, KeepPower, Eagletac, XTAR, Efest, ..
__________________
*FMI* i have 2 pending orders (=1*WB +1*DO).
deletions, dis**iminatory, harmless,
**eisl
HKJ
HKJ's picture
Title: ★★★★★
kreisler wrote:There are many
Yes, but they are not sold with that name on them and there is also small differences between the batteries.
__________________
1div0
1div0's picture
Last seen: 3 hours 17 min ago
Title: ★★
Thank you!
Thank you for conducting your tests and sharing your findings.  Smile
NightCrawl
Last seen: 2 hours 27 min ago
Title: ★★★★★
I just compared some of the
I just compared some of the -B cells in HKJs comparator and it seems that - so far - the AmpMax and Keeppower perform best. Probably both made by Keeppower. Just like the one from Intl-Outdoor, but it doesnt perform as good. I wonder why that is..
Oh, and do you have a bare -PD cell up for tests?
HKJ
HKJ's picture
Title: ★★★★★
NightCrawl wrote:I just
Me too, I do not get the same result.
Generally there are two differences:
Capacity, this can be due to age of the cell. I.e. do I get a fresh battery and test it immediately when I receive it, or is it a couple of month old before it is tested.
Voltage at high load, this often depends on the protection circuit. I.e. a 12A protection will often have higher output voltage than a 5A protection.
There can also be production tolerances between different batches of cells.
No, but I expect to receive another protected one and will probably test it up to 10A.
__________________
NightCrawl
Title: ★★★★★
Or Keeppower saves the
Or Keeppower saves the premium circuit for the premium brands and the little less (but still very) good ones for budget brands like IO.
I guess you are gonna receive the one from IO? A comparison with the unprotected one would be really cool though.
HKJ
HKJ's picture
Title: ★★★★★
NightCrawl wrote:Or Keeppower
That theory does not fit.
I will call the performance of these two batteries virtual identical.
The lowest trace (i.e. the 5A) is the best to see differences in protection.
__________________
NightCrawl
Title: ★★★★★
Yes, the 5A trace is
Yes, the 5A trace is different but the capacity is the same. So that would be a different PCB. Why doesnt my theory fit then?
HKJ
HKJ's picture
Title: ★★★★★
NightCrawl wrote:Yes, the 5A
The 5A track is the same for the two batteries, except at the start and that has nothing to do with the protection.
__________________
NightCrawl
Title: ★★★★★
Okay. So there is a
Okay. So there is a difference in the cell?
HKJ
HKJ's picture
Title: ★★★★★
NightCrawl wrote:Okay. So
That dip at the start might be due to temperature (The cell need to heat up a bit, to get full performance), my testing lab does not have a tightly controlled temperature, it will vary a few degrees.
__________________
NightCrawl
Title: ★★★★★
Thats plausible. Thanks for
Thats plausible. Thanks for enlightening me. Smile
jpil
Last seen: 2 days 22 hours ago
Title: ★★★
sb56637
sb56637's picture
Last seen: 7 hours 47 min ago
Title: ==Administrator==
Thanks very much! Frontpage’d
Thanks very much! Frontpage’d and Sticky’d.
__________________
Rusty Joe
Rusty Joe's picture
Last seen: 6 hours 58 min ago
Title: ★★★★★
Where can I get these
Where can I get these batteries??
Kingsley831
Last seen: 5 weeks 6 days ago
Title: ★★
good share
thanks a lot for your information, the batteries look great.
ri chevy
Last seen: 11 hours 35 min ago
Title: ★★★
HKJ posted in his
HKJ posted in his graph.
HKEquipment Wink
luvlites
Last seen: 1 day 10 hours ago
Title: ★★★
HKJ wrote:This is a very good
HKJ, will these fit in the TN30 & TN31? Thanks.
Rusty Joe
Rusty Joe's picture
Title: ★★★★★
Any known fav lights that
Any known fav lights that these positively won’t fit in? I know Hi-Max’s won’t fit in 501Bs, but I’ve not seen too many batteries that are so big that they don’t work in most lights.
HKJ
HKJ's picture
Title: ★★★★★
luvlites wrote:HKJ wrote:This
The diameter is to large, but they do fit in length.
__________________
HKJ
HKJ's picture
Title: ★★★★★
Rusty Joe wrote:Any known fav
Rusty Joe wrote:
Any known fav lights that these positively won't fit in? I know Hi-Max's won't fit in 501Bs, but I've not seen too many batteries that are so big that they don't work in most lights.
I would expect there are many light, but I have not tested.
__________________
jpil
Title: ★★★
Rusty Joe wrote:Where can I
http://www.fasttech.com/products/0/10001980/1141104-panasonic-ncr18650b-…
Sirius9
Sirius9's picture
Last seen: 46 min 46 sec ago
Title: ★★★★
jpil wrote:Rusty Joe
jpil wrote:
http://www.fasttech.com/products/0/10001980/1141104-panasonic-ncr18650b-protected-rechargeable-3400mah
Distributor On CNY Holiday Frown
skyrider1
Last seen: 3 hours 53 min ago
Title: ★★★
I think fasttech has them in
I think fasttech has them in stock though. I ordered a set a week and half ago and just got them. Got another set coming in.
light junkie
Last seen: 7 hours 15 min ago
Title: ★★
so which battery is better?
Again. I. Advance I apologize but if I had to pick between the keeppower black 3400 maH protected or these Panasonic 3400 maH protected which is a better performer?
Toph
Last seen: 58 min 12 sec ago
Title: ★★
I have these Batteries, they are a tight fit, but they fit both the TN30 and TN31.
__________________
Damn Addictions
Shadowww
Last seen: 1 hour 28 min ago
Title: ★★★★★
light junkie wrote:Again. I.
Keeppower, without a doubt
sorotantaz
sorotantaz's picture
Last seen: 3 min 47 sec ago
Title: ★★
Shadowww wrote:light junkie
Shadowww wrote:
Keeppower, without a doubt !http://qs.lc/p/wn2.png!
i thought keeppower also use panasonic cell.
so the protection circuit does the difference?
Shadowww
Title: ★★★★★
sorotantaz wrote:so the
Yup. Better PCB has lower internal resistance, and therefore less voltage drop.
Hikelite
Last seen: 7 hours 18 min ago
Title: ★★★★★
Shadowww wrote:sorotantaz
I guess the clear PVC concept pays off.
sorotantaz
Title: ★★
 Hikelite wrote:Shadowww
just ordered myself a pair of panasonic 18650 just like in the review but with 3100 mAH.
little bit regret however the price spread between the two brands can reach $5 for the same capacity.
mind to elaborate with your post of clear PVC pays off?
Hikelite
Title: ★★★★★
sorotantaz wrote: Hikelite
It's not branded, but you can see the Panasonic original battery wrap underneath. No matter what protection circuit is used, the cell will be bought in masses for being Panasonic.
spaceboy
Last seen: 4 hours 57 min ago
Title: ★★
These fit in the Sipik sk98
These fit in the Sipik sk98 and Aleto 26650 jumbo sipik (with 18650 sleeve)
light junkie
Title: ★★
Fasttech
Fasttech has BBC them but now the Keeppower 3.6 volt 3400 mAH are now the top dawg from hat I have been told.
spaceboy
Title: ★★
light junkie wrote:Rusty Joe
Keeppower will be more expensive though, yes?
picrthis
picrthis's picture
Last seen: 1 hour 12 min ago
Title: ★★★
I have put in a request a few
I have put in a request a few days ago for FastTech to start carrying the keeppowers 3400mAh, they told me this morning “we will update you when it’s here”
_
Others on here may wish to do the same, the more requests maybe the better chance they actually will carry them soon, but it does sound like from their reply they will carry them. I gave them a link to a competitor for the product that shows the price and graphs showing how good the batteries actually are.
I think FT will gives us a better price and a much quicker turn-around time for USA customers.
https://support.fasttech.com/general/RQST
__________________
Fenix TK12, TK15, TK21-U2, Olight M20S, M21 EagleTac T20C MKII XPG/XML(720lm), TX25C2-XML2, SX25A6-XML2 CW Maelstrom G5, X7 Spark SL6-800CW/740NW, SL5-220CW/190NW/210CW/180OW Xeno CUBE Model #E11 V7 XPG/XML CW/NW E03 V2 CW/NW Skilhunt Defier X3 ZL SC600, S6330 Scorpion v2 w/Turbo Head CW/NW, Xtar R01, SkyRay STL-V2, 3800-Rev2 3-mode, G6, 818, 850, KING Gold & Black CW/NW UltraFire UF-980L, WF504B TrustFire X8, C8, TR-3T6 (3x18650), X9, J12, J18, X100 Aurora C6 Jetbeam BC40 CW/NW ShiningBeam S-Mini XPG/XML Nitecore TM11 CW/NW, TM26, EC25W/CW, P25, EA8, MH25 Shadow JM07 Pro CW/NW DRY CW/NW
Li-Ion chargers: Pila IBC (Swiss Designed & Engineered) the Gold Standard (UL). Xtar SP2 & VP1, Soshine SC-S1max V3 for a budget charger use Nitecore i4/i2 EagleTac & KeepPower 18650 3400mAh Panasonic UL button top cells
light junkie
Title: ★★
yep
About 5-7.00 USD
spaceboy
Title: ★★
How much better are the
How much better are the Keeppowers?
HKJ
HKJ's picture
Title: ★★★★★
spaceboy wrote:How much
The battery inside is, of course, the same. The Keeppower protection circuit has slightly less voltage drop and considerable higher current limit (If this is good or bad can be discussed).
The Keeppower is 1 to 1.5 mm shorter, this can be very significant!
__________________
PyTech
PyTech's picture
Last seen: 18 min 36 sec ago
Title: ★★★
Thanks for the review.
__________________
-Sean
DasEtwas
Last seen: 14 min 5 sec ago
Title: ★★
http://www.fasttech.com/products/1420/10001980/1141104
http://www.fasttech.com/products/1420/10001980/1341105
Anybody knows the difference between these two types, beside one is cheaper? Which should I buy?
Shadowww
Title: ★★★★★
1st option is protected. If
If you have to ask, it’s the one you should buy.
HKJ
HKJ's picture
Title: ★★★★★
DasEtwas
DasEtwas wrote:
http://www.fasttech.com/products/1420/10001980/1141104 http://www.fasttech.com/products/1420/10001980/1341105 Anybody knows the difference between these two types, beside one is cheaper? Which should I buy?
With or without protection.
__________________
DasEtwas
Title: ★★
Look at the pictures and read
Look at the pictures and read the description/listing guys Wink They are BOTH protected
HKJ
HKJ's picture
Title: ★★★★★
DasEtwas wrote:Look at the
I looked at the heading, it does only say protected for one of them.
But you are right, both batteries has photos that shows a strip and a black extension at the bottom.
Except the photo with batteries in a box, there they do not have the black extension.
__________________
sorotantaz
Title: ★★
HKJ wrote:DasEtwas wrote:Look
it has been discussed in the respective product page and haven’t got a response from FT. there is customer opens a ticket about it..
MRsDNF
MRsDNF's picture
Last seen: 56 sec ago
Title: ★★★★★
These are advertised as 4.35
These are advertised as 4.35 volts.
__________________
My current and or voltage measurements are only relevent to anything that I measure. Budget light hobby proudly sponsored by my Mastercard and unkowingly paid for by a hard working wife.
HKJ
HKJ's picture
Title: ★★★★★
MRsDNF
MRsDNF wrote:
"These":http://www.fasttech.com/products/1420/10001980/1341105 are advertised as 4.35 volts.
That is obvious a mistake, that a couple of sites made when the battery was new.
__________________
Comment viewing options
Select your preferred way to display the comments and click "Save settings" to activate your changes.
