Review: NITECORE P25 Smilodon (XM-L U2, 1x 18650 / 2x (R)CR123
38 replies [Last post]
UPz
UPz's picture
Last seen: 4 min 48 sec ago
Title: ★★★
P25 NITECORE Smilodon
LED: Cree XM-L U2
Battery: 1× 18650 / 2x CR123 / 2x RCR123
Modes: 8 (Turbo-High-Medium-Low-Micro-Strobe-SOS -Beacon) with memory.
Switch: Double, head electronic switch and the tailcap forward.
Price: TBA
Date: January 2013
Links:
Nitecore / Thread in ForoLinternas / RdL
PRESENTATION:
Nitecore surprised everyone with this just released new flashlight, a tactical, named P25 Smilodon.
Smilodon is the name of an extinct feline, also known as Sabretooth. Nitecore wanted to nickname her brand new tactical flashlight with the name of this terrifying creature, extinct for over 10,000 years.
Nitecore would initially provide some test units to a closed group of reviewers, which we had to keep secret the project to publish the analysis on the day of launch announcement of the flashlight, but unfortunately my unit arrived late for reasons beyond and the Nitecore announcement finally rushed, so this review comes slightly late.
This new flashlight will be the first of the new “Precise” range, dedicated to providing products for tactical, military and policial usage.
As usual this review sample comes naked, without any original packaging, accessories or spare parts, but thanks to the instruction manual of the flashlight I can point out that the package also contains a holster, landyard, titanium-plated clip , tactical ring, USB cable and o-rings and spare switch cover.
Besides this P25 will be sold in two colors, the “Black Law Enforcement” and “Military Grey”
FINISHING EXTERIOR:
The exterior of the P25 is really distinctive, with several details that give it a unique and genuine character.
I’ll start with the color, “Military Grey” in this case, it’s a nice HA III anodized with a matte gray reminiscent of “NATURAL HA”.
General lines of the P25 are quite similar to the Nitecore MH25 , with dimensions quite similar.
The flashlight head has a flat bezel, stainless steel, ultra clear lens with anti-reflective treatment and a smooth reflector considerable depth. The XM-L U2 is perfectly focused thanks to a black centering mechanism.
Outwardly, the head has several longitudinal grooves that prevent the flashlight from rolling on smooth surfaces. In the neck of the head, we have some of the most distinctive features of the P25: On both sides, we have two picatinny rails, as those found in assault rifles for attaching accessories to the weapon. These rails also provide an anchor point fast, and act as cooling fins.
These rails have, on one side, the button “two-stage” with backlit, and the opposite has the charge USB port, protected by a silicone gasket.
Inside, we have another novelty: The connection between the circuit and the positive pole of the battery is provided with a spring system with mechanical protection against the installation of batteries with reversed polarity. This double spring system seems optimal to withstand the recoil when we have the flashlight mounted in a weapon.
The tube is externally coated by a knurled central zone, and two tracks for the installation of the clip, which may be placed in both directions. The threads are perfectly machined raw aluminum being at its junction with the head and anodized tail plug, allowing the lock-out of the torch simply by loosening it. The laser engravings are all very crisp and clear, even in small letters.
Finally, the design of the tailcap is made to allow quick access to the switch forward, which has a black silicone coating with the letter N in its plane and clearly stands out from its base. On both sides, we have two raised crenelations with perforations for attaching a wrist strap, which also allow the flashlight in place without hindering tailstand momentary push access.
Inside, we can see how the set is removable, thanks to a bi-pin threaded washer.
OPERATION / UI:
The Nitecore P25 uses a double switch, with a tactical switch located in the tailcap, combined with an electronic switch, similar to the already seen in other models of the brand, in the head. The tailcap switch is responsible for switching on and off of the lantern, and has the ability to offer momentary switch function.
Head switch, similar to a camera shutter, can difference between a pulse or a complete press . Also this second button functions as battery status indicator, battery voltage indicator, charging status indicator and locator, thanks to its backlighting.
The sequence of modes consists of 5 main modes in the following order:
Micro-> Low-> Medium -> High-> Turbo
This group has memory, and always turn in the last mode, either from in tailcap switch button and from the head.
An interesting feature, not mentioned in the manual that I’ve discovered by accident is that we have a shortcut access to Turbo with a partial press maintained from any of those intensites.
The P25 also has Strobe, SOS, and Beacon hidden modes. These special modes are also accessible via the head switch, holding it down completely for more than a second.
The first to appear is the Strobe, and pressing lightly will alternate with the SOS and beacon mode. To return to the main sequence of modes, just full press the head switch again, or directly off from the tailcap switch. This secondary group modes “special” has no memory, and always starts on the Strobe.
Keeping the head switch pressed with the flashlight in Standby gives us quick access/shortcut to strobe (starts for a moment on memorized intensity mode and then quickly jump into strobe).
The flashlight also has a standby function, which is apparently off, but kept in memory mode selection and allows us to use the flashlight forgetting about the tailcap switch .
To access the standby function, we have to push the head switch to the bottom with the flashlight on.
While the lantern is in Standby, backlit button flashes every three seconds, helping you locate the flashlight in the dark.
To exit this function, just press the button all the way down, or turn off the from flashlight tailcap switch.
Another interesting feature is that the P25 has the ability to charge a 18650, through the integrated USB port on the opposite side of the head to the button.
Though the flashlight can be used with one or two RCR123/16340 or one 18650, the load is only possible for 18650. As in other flashlights capable of charging batteries, tailcap switch must be on for the work load.
During charging, the light that surrounds the head button flashes twice per second. If the system detects a problem, the indicator flashes quickly. This is usually due to improper installation of the battery or the tailcap switch not being activated.
Charging time will vary depending on the battery capacity, in my case approximately 7 hours to full charge a PCB tripped Panasonic NCR18650A 3100mAh, so I conclude that the charge current will be about 500mA. There’s no improvement on charging time, whatever charging system we use, as current is controled by the flashlight and not the adaptor plug.
Once fully charged battery, the switch light stays on and steady.
Due to use a USB port on the flashlight, we can use a charger, for example, a Smartphone to load into any outlet, without using the supplied USB cable.
Finally, this Nitecore P25 also has a sophisticated warning system remaining battery capacity:
With the flashlight on, the backlight of the button will blink once every two seconds while we have about 50% of the battery capacity. When the charge level approaches empty, the indicator flashes faster.
In addition, into the Standby function, with a slight touch on the head button indicator will show the battery voltage by a sequence of flashes, as seen for example in the Explorer range. Four flashes, pause for a second, and two new flashes tell us that the battery voltage is 4.2V. We can also know the voltage while charging using the same procedure.
This comprehensive user interface has a price: A parasitic consumption produced by the Standby function of about 0.8mA, but we can completely neutralize the flashlight from the rear switch or slightly unscrewing the tailcap threads.
The Nitecore P25 is a tactical light, but thanks to its user interface it is still civilian friendly.
With the switch forward, we control the only function of a tactical flashlight, momentary on.
To change modes, we have the head switch.
Locator ONLY works when the flashlight is on Standby, so it do not betray our position with the flashlight off from the tailcap switch.
Indicator level blinks ONLY works with the flashlight on, so it do not betray our position as this will only shows when the flashlight is on, and the light of the XM-L will call more attention than the flashing warning.
We have “shortcuts” to Turbo and Strobe, something very interesting for tactical use.
Then have the Standby function, in which we no longer consider the P25 as an instrument of combat, and becomes a civil flashlight more than complete.
In this role, we fully control the flashlight with head switch.
flicker is where the locator and the voltage indicator function.
Although a priori may seem complicated, the truth is that the user interface is really intuitive. Nitecore has done a great job combining the classic tactical switch, with its patented “two stage” switch, providing users multiple combinations for different environments.
CURRENTS & BATTERY LIFE:
Panasonic NCR18650A 3100mAh@4.2V:
  • Turbo: 2600mA
  • High: 1480mA
  • Medium: 350mA
  • Low: 100mA
  • Micro: 6mA
P25 regulation is quite good. Nitecore declares a time-controlled stepdown in Turbo mode after 20 minutes of continuous use, to protect the light from overheating. The truth is that, after a few minutes, the intensity begins to fall slightly, stabilizing after approximately seven minutes, where will hold for 13 minutes until does the real stepdown.
In High mode, there’s no stepdown and maintains the brightness regulation for approximately 140 minutes where the voltage is insufficient to sustain it.
All modes are achieved through regulated current, so no PWM.
BEAM PROFILE:
The beam profile is markedly P25 pitcher. Although unable to reach other flashlights with larger reflectors, we can see that the hotspot is clearly defined and has a relatively small size within the set of projection.
The smooth reflector “ PDOT “avoids any ring on the projection, creating peripheral illumination also pretty good for this type of concept.
Tint of XM-L U2 is cold, but there are no shades of green as in other XM-L of the same bin. However if you can observe a tendency to bluish especially in low and micro modes, but only on bright white surfaces.
PERSONAL CONCLUSION:
A tactical flashlight, with advanced features but inherited part of the user interface of other lanterns mark using the same button, making it versatile and practical for almost all situations. We use only with the button through the standby function, or otherwise as any other tactical light combining the head switch and momentary tailcap switch.
Its aggressive aesthetics and striking shapes also add a great grip.
The USB charging function may seem unnecessary in such a single battery flashlights, but can be extremely useful because not using a “propietary” cable, so you can use any other supply system such as a Smartphone charger. Unfortunately this feature significantly lengthens the flashlight.
This Nitecore P25 certainly has the most comprehensive interface I’ve seen so far in any flashlight.
The only interface detail I noticed that I think can be improved, is the voltage warning in Turbo mode. Probably as a consequence of the huge current, the battery indicator starts signaling 50% with a flickering illumination blink every two seconds, just a few minutes of use even with the battery to 100%. I guess this is because the voltage drop when subjected to such discharge.
Laughing out loud I like:
  • User Interface.
  • Appearance.
  • Advanced Features.
  • Nitecore Quality
Sad I do not like:
  • Its length.__
__________________
UPz
UPz's picture
Title: ★★★
Under construction!
Under construction! Innocent
__________________
Ecko404
Last seen: 1 week 1 day ago
Title: ★★
Cool thx for the review!
This one is definitively my next light!
__________________
My collection
UPz
UPz's picture
Title: ★★★
Thanks Ecko404! Review is now
Thanks Ecko404!
Review is now complete, it only lacks beamshots that I plan to update during the week, when weather permits.
Cheers!
__________________
whokilledJR
whokilledJR's picture
Last seen: 10 hours 7 min ago
Title: ★★★★
Thanks for the review UPz!
Thanks for the review UPz! I’m about to buy my first nightcore light in a couple of weeks, not the same model but this may well be one of the next on my future hitlist. Referenced!
_the_
_the_'s picture
Last seen: 26 min 28 sec ago
Title: ★★★★★
Thanks for the great review!
Thanks for the great review!  Very thorough with quality photos. I really appreciate the time you put to these reviews!
Thank you once again!
__________________
=the=
My flashlight collection + links to my reviews and beamshots / My photo gallery
Disclaimer: Above post might contain referral links, but only to items that I myself have bought, tested & approved.
infinitusequitas
infinitusequitas's picture
Last seen: 1 hour 27 min ago
Title: ★★★
Thank you
Thank you for the great review.  Especially the description of modes, UI, and the picture of the micro USB port.
While the light looks fantastic, having just a silicone cover like that, makes it an automatic no go for me.
The approach they took previously, with the MH25, and the screw driven cover would make this light an absolute must buy item. Undecided
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 47 min 42 sec ago
Title: ★★★★★
That’s a looker. Thanks.
That’s a looker.
Thanks.
MattSPL
Last seen: 4 weeks 1 day ago
Title: ★★★★
Nice review, thanks
Nice review, thanks Smile
BetweenRides
BetweenRides's picture
Last seen: 1 hour 46 min ago
Title: ★★★★★
Excellent review, Upz! Thanks
Excellent review, Upz! Thanks for posting.
DARCANGEL
DARCANGEL's picture
Last seen: 2 hours 5 min ago
Title: ★★★★
Thanks for the review UPz,I
Thanks for the review UPz,I can't wait to get my hands on this light.I like everything about it especially the usb charging.I'm surprised they didn't put the XML2 in it,but hopefully they will on the production copies unless this is the final design.
kreisler
kreisler's picture
Last seen: 5 min 42 sec ago
Title: ★★★★★
Thanks for review, great
Thanks for review, great job!
i think my next flashlight is gonna be a nitecore, cha!!
__________________
*FMI* i have 4 pending orders (=1*E09 +1*USPS +1*DO +1*WB).
deletions, dis**iminatory, harmless,
**eisl
UPz
UPz's picture
Title: ★★★
Thank you very much for your
Thank you very much for your kind comments!
I’ve added a few beamshots in the underground tunnels, and also a visual reference of the modes arrangement.
__________________
Pinetreebbs
Pinetreebbs's picture
Last seen: 2 hours 15 min ago
Title: ★★★
The EC25's Big Brother?
A through and interesting review. It appears to be the big brother of the Nitecore EC25.
Thank you UPz
sb56637
sb56637's picture
Last seen: 4 hours 15 min ago
Title: ==Administrator==
Very nice! Thanks a lot!
Very nice! Thanks a lot! Frontpage’d and Sticky’d.
__________________
whokilledJR
Title: ★★★★
Really is a good time to
Really is a good time to order this light, considering it seems to go north of $100 yet fasttech is selling it for $62 with BLF coupon code. I’ve ordered mine.
whokilledJR
Title: ★★★★
Hi Upz, just a question. How
Hi Upz, just a question. How does the Rofis, Balder Se-2 and nitecore P25 compare to each other in build quality? Are they comparable?
UPz
UPz's picture
Title: ★★★
whokilledJR wrote:Hi Upz,
Hi whokilledJR,
The P25 build quality is superb. Maybe the Rofis TR31C is very close to the fit and finish of the P25, but the Nitecore has a better feel IMHO. The SE-2 is overall good flashlight, but it’s way more economic than the other two to compare.
Thanks for the comment!
__________________
whokilledJR
Title: ★★★★
UPz wrote:whokilledJR
UPz wrote:
Hi whokilledJR,
Thanks Upz, now I’m even more excited to receive it. Big smile
UPz
UPz's picture
Title: ★★★
Already ordered?
Already ordered? Laughing out loud
__________________
whokilledJR
Title: ★★★★
UPz wrote:Already ordered?
UPz wrote:
Already ordered? :D
Sure did. Tongue
bugi
bugi's picture
Last seen: 21 hours 24 min ago
Title: ★★
whokilledJR wrote:UPz
whokilledJR wrote:
UPz wrote:
Already ordered? :D
Sure did. :p
x2
Destination – Slovenia (Republic of)
The item (RCxxxxxxxxxHK) will leave Hong Kong for its destination on 10-Feb-2013
Laughing out loud cant wait…
whokilledJR
Title: ★★★★
bugi wrote:whokilledJR
bugi wrote:
whokilledJR wrote:
UPz wrote:
Already ordered? :D
Sure did. :p
x2
Destination – Vietnam
The item (RCxxxxxxxxxHK) arrived at its destination country on 7-Feb-2013.
Race is on sonny. Wink
Kokopelli
Kokopelli's picture
Last seen: 5 days 2 hours ago
Title: ★★★★★
What do you guys say, P25,
What do you guys say, P25, Rofis TR31 or Fenix TK22? All have their own pluses and minuses.
Sirius9
Sirius9's picture
Last seen: 43 min 35 sec ago
Title: ★★★★
Does someone recognise the
Does someone recognise the laser with mount that is shown in next picture and more importantly do you know where can I buy it Smile
UPz
UPz's picture
Title: ★★★
Hello:I don’t have the TK22,
Hello:
I don’t have the TK22, but I have the TR31C & the P25:
The Rofis is a more simple and basic flashlight compared to the P25.
Both have built-in chargers, but the Rofis uses a “propietary” plug, and the Nitecore adopts a MicroUSB plug, which I consider to be WAY more usefull (ie: You don’t have to carry the specific cable, any smartphone charger or microUSB cable will charge it).
Also, being the user interface in the P25 is one of the most complete I’ve ever seen, you can use it without any “advanced” features right away.
IMHO P25>TR31C
Cheers! Big smile
__________________
Kokopelli
Kokopelli's picture
Title: ★★★★★
Wow, thanks UPz. I ordered
Wow, thanks UPz. I ordered P25. As you’ve said, it gives you many reasons for choosing it, while I can only say a Fenix / Rofis may be stronger, which has never been an issue for me.
UPz
UPz's picture
Title: ★★★
You’re welcome. Please, don’t
You’re welcome.
Please, don’t forget coming back and reporting your impressions when you get your Smilodon.
Best regards!
__________________
whokilledJR
Title: ★★★★
Upz, this P25 is something
Upz, this P25 is something special. Lately I’ve been trying not to post impressions too early after receiving a new light as I’ve been guilty of over-hyping certain lights thanks to a previous lack of experience and new light enthusiasm. But I can already say this light is my favourite single emitter light. Here are some of the things I like about it:
• Quality and build is top notch
• Visual aesthetics can’t be beat
• feels great in hand (good knurling and well balanced weight)
• has a very nice beam profile
• UI is fantastic
• love the flashing button standby mode, so convenient at night when you need a house light. Also gives the light a real high tech feel and look.
• Anodizing feels and looks very tough
Beam profile and reflector looks and performs very similar to the Shadow JM07, which means it also makes a great cycling light. Not a compact thrower and doesn’t throw as well as a C8, and you wouldn’t expect it to as the reflector diameter is smaller. More of a beam for all purposes and a very smooth beam at that, with a decent amount of spill. I love the UI, moon mode adds some real class and you can skip all modes and go straight to turbo with a half press and hold. Some people have commented the UI is too complicated, which I can disagree with now that I have it in hand. The advanced UI features are there only if you want them. Otherwise, the side switch basically operates like a reverse tail switch, half press to cycle through modes, full switch to turn on/off(standby mode).
Some cons:
• Tailcap doesn’t seem to align with the rest of the body
• Awkward due to its length to edc
• Half press and hold to skip modes for turbo, would be nice to be able to half press and hold to go back to the last mode.
The tailcap mis-alignment isn’t eye catching and doesn’t seem to bother me or take away from the visual asthetics, so it’s hardly a con. At $62 from fasttech this is a good buy, cheaper and probably better value than a lot of the $100 premium lights out there.
whokilledJR
Title: ★★★★
Just took the P25 out for a
Just took the P25 out for a night ride, it is indeed a very good thrower for a bike light. Stopped for a while to shine it around some rice paddies against the C8. It performed very well against my C8, in fact it was kind of hard to tell the difference in throw.
Kokopelli
Kokopelli's picture
Title: ★★★★★
It has the reflector of EA4.
It has the reflector of EA4. I didn’t believe it would throw much with the fact that it only had a 40mm head. An already deep Thrunite TN11 isn’t as throwy as an EA4. So P25 should be a real thrower indeed. Maybe even better than those classic c8s built for XRE but not tweaked for XML.
Sirius9
Sirius9's picture
Title: ★★★★
no one knows anything about
no one knows anything about the laser? Sad
bugi
bugi's picture
Title: ★★
Sirius9 wrote:no one knows
http://www.aliexpress.com/store/product/Adjustable-Mini-Red-Dot-Laser-Si…
Something like that?
(inače ima toga ne ebayu i aliexpresu kolko hočeš Smile )
Sirius9
Sirius9's picture
Title: ★★★★
bugi wrote:Sirius9 wrote:no
bugi wrote:
http://www.aliexpress.com/store/product/Adjustable-Mini-Red-Dot-Laser-Si... Something like that? (inače ima toga ne ebayu i aliexpresu kolko hočeš Smile )
not quite there but that one is very close Smile
Now I know where to search, thanks Wink
(ebay mi je pomalo nesiguran!)
whokilledJR
Title: ★★★★
Hmm, just realised the
Hmm, just realised the holster for my P25 is too small, apparently this is a known issue for the first batch of P25’s and nitecore is directing customers do go to their sellers to get a replacement sent out.
Thread here from candlepower forums, I’ve just sent fasttech a message:
http://www.candlepowerforums.com/vb/showthread.php?355440-Nitecore-P25-H…
Sirius9
Sirius9's picture
Title: ★★★★
Let as know how it turns
Let as know how it turns out.
I was just planning to get P25 from FT, this week...
bugi
bugi's picture
Title: ★★
All P25 from first batch have
All P25 from first batch have wrong holsters. Nitecore have sent right holsters to their distributors. When I contacted FT, they answerd, that they will include free correct holster with my next order. And they did!! Smile
terrafirma
Last seen: 1 week 9 hours ago
Title:
Nitecore P25
Yeah agree I just got this last week and love it. The beam and throw are impressive for a single emitter. The USB charging is a big plus, don’t know why the rubber seal is a no no for some users? It’s small enough to carry when you need a throw light for lots of applications. For the money I am extremely happy and becoming a fan of the Nitecore products.
falco
Last seen: 58 sec ago
Title: ★★
Just wanted to make sure.
Just wanted to make sure. You can use any micro usb cable and adapter (say from an android tablet) to charge this flashlight and it will be safe?
Comment viewing options
Select your preferred way to display the comments and click "Save settings" to activate your changes.
