Think I fried a driver, need mod help.
41 posts / 0 new
southland
southland's picture
Last seen: 1 week 2 days ago
Tried to upload pictures unsuccessfully. Just got this light and played around with it for maybe a minute. Noticed the led centering device was not really doing anything because of the large opening in the reflector(led end). Took out centering device to see how much brighter it would be and I think I shorted out the driver. The light will come on but has very low output, like moonlight mode. Driver seems to measure about 22mm. Tried screwing it out with needle nose pliers and then prying it out with a small screwdriver, can’t get it out. The pill screws into the reflector, the reflector screws into the host so it should do good at heat management. Anyway, how do I get the driver out and what is a good driver to use. This will be my first attempt at modding.
2× 18650 batteries, x-ml led
Is this a good solder station, Hobby King 936 ?
Pictures a few posts down and a link to the light.
Edited by: southland on 01/25/2013 - 16:59
devman
Last seen: 3 years 1 month ago
Asks me to sign into flicker and then says the photos are private.
Try a different site, like http://imgur.com/ ?
southland
southland's picture
Thanks devman, I fixed that.
scaru
scaru's picture
Last seen: 2 years 8 months ago
I can say that is a good soldering station, I can't see the pictures so I can't recommend on a way to fix it though.:(
southland
southland's picture
southland
southland's picture
Sorry about the image size, I don’t know what I’m doing. Removed the nonworking links. Thanks devman and scaru.
BIGWOOD
BIGWOOD's picture
Last seen: 1 year 1 day ago
I assumed you put the plastic led centering stator back and tried it again? Or Try a piece of paper with the center cut out to cover the solder points of the lead wires. The reflector may still be shorting out.
southland
southland's picture
I tried putting the centering the device back in, still not working. I believe the reflector touched both wires and shorted out when screwed down, will work at a moonlight mode.
garrybunk
garrybunk's picture
Last seen: 1 week 3 hours ago
For clarification, you tried turning the light on with the reflector removed and you still get the moonlight output, right?
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
NOTE: Moving my photos from PhotoBucket to Flickr. PM me or post in the thread if you can’t see my images and need me to fix or send a gallery link. PhotoBucket images should remain visible until November 2018.
dthrckt
dthrckt's picture
like any fun project, you need three hands
one to pull on the spring, a second to pry the driver out from the hole on one side, and the third to pry at the hole on the other side Smile
____________________
Girls can shoot!
southland
southland's picture
-Garry
With the light completely assembled with and without the centering device, moonlight only. There is no way to run it without the reflector, pill screws into reflector, reflector screws into host. Have to use the reflector to hold the pill in place.
southland
southland's picture
So do you think it’s a press fit, do you think it’s glued in place?
garrybunk
garrybunk's picture
southland wrote:
-Garry
Ah ok, oops - didn't think about that.
-Garry
BIGWOOD
BIGWOOD's picture
Looks like a press fit. Try prying it open with a mini flat head screwdriver.
In this case if it’s an odd sized driver (>17mm diameter), I would either desolder (or use a heatgun) all the parts off the driver and use it as a contact plate and buy a 17mm driver. Otherwise you can buy a 20-21-22mm contact plate. They’re cheap. Int Outdoor or Fancyflashlights (CNQG) carries them.
To get you started. To check if you actually fried your LED or driver, you can connect the battery using some lead wires directly onto the LED contact points to see if your LED is in fact fried. If it works, then it’s your driver. Just don’t blind yourself in the process. I don’t know how many time I’ve done that. LOL
southland
southland's picture
Tied powering the led with leads directly to a battery. The led is still in moonlight mode, must be the led or led and driver, while I’m at it I will still upgrade the driver also since this light looks like it is heat sinked good.
Halo...
Halo...'s picture
Last seen: 2 years 12 months ago
That is the cheapest soldering station I’ve seen. Tho shipping doubles the cost. To really know if its could be passable quality (safety wise) need to find someone who has done (or willing to do) a teardown, assess its design &/or take pictures so others can assess it.
A lot of cheap noname chinese AC electronics are made with horrible disregard for safety, laws & fire codes.
gords1001
gords1001's picture
Can you measure the driver? Is the light 1 or 2 18650?It looks like 2 * 18650, if that’s the case and the driver is 19-20mm, this is a real nice driver.
http://www.lck-led.com/constant-current-driver-board-modes-p-501.html?cP...
I’ve just fitted it to a host, and it’ll definitely be on the cards for any multi-cell xm-l builds I do.
keltex78
keltex78's picture
Fasttech has some larger diameter drivers available; if you find the right diameter, you may be able to find a decent driver there.
24mm driver, 2.4A for 2x Li-Ion cells, listed as no mode memory though: http://www.fasttech.com/products/1612/10001748/1127400-6v84v-5-mode-24a-led-flashlight-driver-tr-001
21mm driver - 2.8A for 2x Li-Ion cells, specs say no memory but I haven't been able to confirm that yet on mine: https://www.fasttech.com/products/1143100
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
dthrckt
dthrckt's picture
I haven’t seen a glued one (but they’re probably out there).
Some are soldered in place, but it doesn’t look like yours is.
I HAVE had some that are pressed in place so well that I broke the board getting them out. I didn’t care since I wanted to get rid of strobe anyway…
if you find yourself using a lot of force, you might want to unsolder the leads from the emitter. some times tugging on them will pull the traces off the star.
I have an AOYUE 936 soldering station. great for soldering leads and adding chips to drivers. I paid $35 shipped from US ebay seller.
http://www.ebay.com/sch/i.html?_trksid=p3872.m570.l1313&_nkw=AOYUE+936&_...
Girls can shoot!
garrybunk
garrybunk's picture
PilotPTK recommended that Hobby King soldering station and that was enough fo me to order! Haven't used mine yet. They carry it in the US Warehouse so that's a plus!
Sometimes drivers are soldered in the inside (solder joint inside the pill where you can't see it) like on the Trustfire F20.
-Garry
moderator007
moderator007's picture
Last seen: 9 min 50 sec ago
I just got the solder station from hobbyking 2 days ago. Works good for what time I have used it. Done a few soldering test and is a lot better than my irons. Heats up quicker than my 30 watt soldering irons. Maybe 1 minute or so. Has a switch on the side that you can turn the iron off when done instead of having to unplug it. I have not took it apart to check the quality of the insides. From what I gather its a copy of the well liked hakko 936. The tip that comes with station is a bit small for normal soldering probably works good for smd work. You can find extra tips on flea bay for a couple bucks look up (936 tips) the hakko uses the same size tips as this one.
As for the quality there is a couple of reviews over at hobbyking that feel the soldering station is ever bit as good as the hakko. Some where professionals that use the station on a daily basis.
If you can get the driver out post up a pic of the component side.
dthrckt
dthrckt's picture
looks just like mine except the name – and the stand actually looks better.
oh, and half the price :_(
Girls can shoot!
southland
southland's picture
The cheapest Aoyue 936 is now over $60.50 shipped on ebay. Think I will go with the Hobby King, might only use it a couple of times. The board has a diameter of 22mm and the host runs 2× 18650 batteries. Since the led seems to be fried also, which led should I get, preferably one with leads if they come with and without. Also what else is needed, I know soldering wire and flux or should I use the combo wire with a flux core. Should I buy some lead wire, what kind? What about thermal glue, what brand? Thanks everyone for all the help.
dthrckt
dthrckt's picture
i think you can find the 936 for $35 or so but i’d go w/ the hobby king, too
hobby king has silicone wire, great for leads
i use flux core solder and a jar of flux
Girls can shoot!
southland
southland's picture
@dthrckt, what brand and size solder, what about thermal glue brand or do I need it?
moderator007
Radio shack 60/40 rosin core solder or silver-bearing solder, the smaller the diameter the better. Get some flux while you are there and make soldering easier.
For the led cree xml you choose bin and tint. Fasttech should have some to look at. 20mm pcb.
Thermal glue for the led fasttech FUJIK or if you want high quality Artic Silver thermal epoxy. Note: Epoxy does not come off easily the silicone Fujik comes of much easier for future modd’s.
Silicone high strand count wire can be had at epbuddy in the states. Ordering from hobbyking makes the order come from china if your going to order the soldering station from the US warehouse. 22AWG should work fine.
To glue the driver in you will need some kind electrically conductive epoxy. I have never used any so maybe someone else can comment on this.
texaspyro
60/40 solder is not a good alloy for general purpose work. You want 63/37 rosin core solder.
southland
southland's picture
Removed the circuit board but tore it up in the process. The driver is 22mm and I can only find a 21mm contact plate(hoy) on fancyflashlights and intl-outdoor. Can I use a 21 and solder around the edges?
viffer750
Last seen: 2 years 5 months ago
a very similar driver: http://dx.com/p/3v-12v-2500ma-5-mode-led-driver-board-162784
unique engrish language... Smile
moderator007
I have to disagree. Info on solder here. 60/40 and 63/37 have the same compounds tin and lead. 60/40 is probably the most commonly used for hand soldering. The only difference being 63/37 melts at exactly 361°F making it eutectic. 60/40 melts at a range of 361°F to 374°F. Eutectic alloy is probably well suited for printed circuit boards, it does have its advantages like a lower precise melting point and no plastic phase. Soldering a wire to a driver or led 60/40 rosin core will work fine. This is the stuff I use 60/40 rosin core solder .032 diameter 8.0 oz. spool.
texaspyro
moderator007 wrote:
I have to disagree.
You can disagree.. but you’re wrong. Wink Unless you gave a very specific requirement, you really want to use 63/37.
Once upon a time I was certified for soldering on equipment destined for manned space flight and other hyper-critical things… I know my solder fu quite well.
