Review: ThruNite Archer 1A
ThruNite Archer 1A
Summary:
- LED: CREE XP-G2 LED with a lifespan of 20+ years of run time.
- Max 178lumen output using 1 x 1.5v AA battery.
- Firefly:0.2lm.249hours; Low:24lm.6hours;Mid80lm.1.5hours;Max Output:178lm.58minutes;Strobe:178lm.2.5hours.
- Working voltage:0.9v to 4.2v.
- Removable steel pocket clip.
- Max run time:249hours(Firefly mode)
- Max beam distance:184meters.
- Peak beam intensity:2993cd.
- Impact resistant:10meters.
- Waterproof to IPX-8 Standard
- 104.14MM LENGTH,22.10mm bezel diameter.
- Weight: 60g without battery.
- Aircraft grade aluminium body structure.
- premium type III hard anodized anti-abrasive finish.
- Ultra-clear tempered glass lens with anti-reflective coating.
- Momentary forward click tactical switch.
- programmable memory function
- Strobe mode for tactial and emergency use.
- Low,medium and high modes to balance power consumption and light output.
- Smooth reflector for max light output.
- Highly focused beam for maximum distance
- Stainless steel front striking bezel.
- Tactical knurling for firm girp.
- Streamlined body design
- Reversed polarity protection.
- Durable T-shaped thread.
- Intelligent highly efficient circuit board design for max performance and long run time.
Nice review ezarc. I have the older Neutron 1A. It really is a very nice solid light. I love the low low and useful modes.
Nice review. Thanks for sharing!
Thanks for the review, i very much enjoyed the pictures
Just so you know, the reason it looks that way is the plates on the side prevent the battery from making a connection if you put it in backwards, a.k.a. it is mechanical reverse polarity protection.
Hard to see in the photo, but those two outside plates would have to be slightly above the center one to prevent – end of AA battery from connecting.
So, I’ll assume the 2 outside plates are slightly raised above the center one..
Forgot to mention…Very nice review ezarc.
My first reaction though, is this is one very LARGE single AA flashlight..??? Dunno..seems odd.
Yep, at least that is how it works on my LD20.
nice review but damn that’s big
Thanks very much! Frontpage’d and Sticky’d.
nice light. This led me to picking up a neutron 1c
Quote Kreisler: “0.20mm difference in height i dunno whats that in ounces sorry”
mm to ounces? Good one Kreis..
Thanks for the review ezarc. The threads on this light are the squarest I've ever seen.
Beamshots added to the 2nd post.
Well done, ezarc
How about runtimes, have you tested any? Amp draw?
Also, this light looks so huge, it could be 2xAA rather than 1xAA, how big 2xAA Archer should be?!
Thanks veer.
I haven’t tested run times and unfortunately I don’t have a DMM.
Here kreisler has some detailed specs, it looks like it draws 2.1A on a eneloop.
Weird thing is – Archer and Saber have almost the same lumens output on high, difference is less than 10lm, yet Archer, according to TN, runs for less than one hour on high while Saber can do 1.5h on high.
As I said in your Saber’s review, I would like to see Archer vs Saber beamshot comparison in the same environment, Im not sure whether Archer had better throw/was brighter than Saber or not.
Perhaps it has to do with reflector solely?
NIce beamshots, greatly improved
Thank you ezarc !
mm to ounces? Good one Kreis.. :D
It’s easy to convert millimeters to ounces. The are 553 inches in a pound. Divide that by 12 (these are Troy ounces remember) and you get 46.083333333. Take that and convert to metric. Now we have 896.7373. Divide that by 100 and multiply back to 16 to get standard ounces. Take that figure convert to the original “0.20mm” and we get 1.047cabbage8483 millimeters to the standard English banana ounce.
Received my two units from the group buy and am a bit disappointed. Both had tool marks and loose burrs when I removed the tail cap. I had to clean out the battery compartment to make sure no burrs were inside. Also, the tail caps looked like they was assembled without proper tools. One had severe gouge marks while the other had deformed pinholes. There’s also a small spot on one of the bodies missing anodizing which wouldn’t be very noticeable if it wasn’t silver on an otherwise all black body.
The two that I have also show slightly different beam patterns with one exhibiting a more defined ring effect than the other. I’ll be contacting Thrunite to see if this is accepted as normal or if this is outside their quality standards. Compared to the Solarforce L2P I recently bought, these two Archers are certainly a step or two down in terms of quality.
I messaged the owner of ThruNite with the link to your post, he said they will replace it for you. I’ll PM you the contact details.
No doubt the design is fantastic for an AA/14500 light. I also prefer the forward clicky switch combined with the twist head for mode changes. Since it has mode memory, I can set up the flashlight to be whatever I need it to be and then just grab it and click the switch when I need it.
I’m just disappointed with the quality and workmanship. It was very apparent since I bought two of them and could compare them side by side.
On another note, the o-ring that’s installed on the body is a bit oversized for the flashlight body. It is very easy to pinch when screwing own the tailcap. One of the lights I received had a pinched o-ring right out of the box. Everyone should take care when reassembling this light to ensure the o-rings aren’t pinched or torn.
Just spotted on the USPS web site that mine has arrived in town. Hoping the @#$%^ contract postal delivery guy comes to my door to obtain a signature. He ought to as I had the local postmaster chew him out good last month for doing his lazy “leave a notification slip in the mailbox and run” routine. It’d save me a drive out of the hills in to town. Also hoping that the torch is problem free given CharT’s post above.
Received today my ThruNite Archer 1A!!
I am very impressed with the looks, body machining, style and finishing! The modes the brightness and the beam spot are just perfect for my taste. The XP G2 led makes a difference!
By far, the best thrower out of my twenty other 1xAA flashlights!! And the brightest one, second only to my Zebra SC52, however i want to see the actual difference when it gets dark.
I liked very much the way the clip head is hidden under the body of the flashlight!! Brilliant!! You can easily remove the clip with no fear of showing any damage or scratch on the body.
The nice and quality holster and the moonlight mode were the cherry in the pie
I will come back with some more nice photos!
Good job ThruNite and thanks for group offer
Got it. Everything looks just fine!
I knew it would be bigger than my L3 Illumination L10 but it surprised me as to just how much bigger. It is basically the same size as my Inova X5T…just ~3/8” shorter. It really is BIG for a 1xAA torch. Heck it isn’t much smaller than my Fenix PD32-R5
Nice! You guys are making me regret not spending a little extra for the Archer instead of getting a Saber. Hopefully the only difference will be the stainless bezel and switch. I'm hoping my BLF Saber will have the same reflector as the Archer.
i am still waiting for my new o-rings from Fasttech.
will ask them to resend the order.
Curious…. what size o-rings did you order?
Gesh
I’ve had this light a whopping 3 days. First NiMh battery swap through the tail end and I have an O-ring in two pieces. This is absolutely unsatisfactory! Getting two spares with the torch isn’t gonna cut it. I’m NOT happy.
I got my archer yesterday (it is big but I like it) and after some playing around with it I must say I really like the UI, it is the first UI I to date in which I actually like that it has memory.
i revised the section on Archer 1A o-rings in my flashlight presentation thread
Still waiting for my Archer 1A that I ordered through the group buy. The UI seems strange based on what I’ve read, but I’m looking forward to it as everything seems to indicate this is a quality light.
