Test / Review: Efest 18650 3400mAh (Black)
9 replies [Last post]
HKJ
HKJ's picture
Last seen: 4 hours 53 min ago
Title: ★★★★★
Protected button top
DSC_1357
Official specifications:
  • Nominal Capacity: 3400mAh (0.2C, 2.50V discharge)
  • Minimum Capacity: 3250mAh(0.2C, 2.50V discharge)
  • Charging Voltage: 4.2 ±0.05 V
  • Nominal Voltage: 3.6V
  • Charging Method CC-CV (constant voltage with limited current)
  • Charging Current: Standard charge: 170mA, Rapid charge : 3400mA
  • Charging Time: Standard charge : 3hours, Rapid charge : 2.5hours
  • Max. Charge Current: 3400mA(ambient temperature 25°)
  • Max. Discharge Current: 6800mA(ambient temperature 25°)
  • Discharge Cut-off Voltage: 2.50V
  • Cell Weight: 55g max
  • Cell Dimension: Height : 69.75mm max, Diameter : 18.57mm max
  • Operating Temperature: Charge : 0 to 45°, Discharge: -20 to 60°
Efest%2018650%203400mAh%20bt%20(Black)-info
DSC_1340
DSC_1358 DSC_1359
DSC_1360
DSC_1361
DSC_1362
Efest%2018650%203400mAh%20bt%20(Black)-Capacity
The protection does prevent a full 5A discharge curve on one of the batteries. The difference in protection between the batteries is also the reason for the curves not overlapping at the higher currents.
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
Efest%2018650%203400mAh%20bt%20(Black)-CapacityTimeHours
Efest%2018650%203400mAh%20bt%20(Black)-Energy
Efest%2018650%203400mAh%20bt%20(Black)-PowerLoadTime
Efest%2018650%203400mAh%20bt%20(Black)-TripCurrent
Efest%2018650%203400mAh%20bt%20(Black)-Charge
Unprotected flat top
DSC_1351
  • none found
Efest%2018650%203400mAh%20ft%20(Black)-info
DSC_1340
DSC_1352 DSC_1353
DSC_1354
DSC_1355
DSC_1356
Efest%2018650%203400mAh%20ft%20(Black)-Capacity
The unprotected version has exactly the same very good performance as other batteries with the same cell.
Efest%2018650%203400mAh%20ft%20(Black)-CapacityTimeHours
Efest%2018650%203400mAh%20ft%20(Black)-Energy
Efest%2018650%203400mAh%20ft%20(Black)-PowerLoadTime
Efest%2018650%203400mAh%20ft%20(Black)-TripCurrent
Efest%2018650%203400mAh%20ft%20(Black)-Charge
Conclusion
Both batteries are very good, the slightly low protection limit is only a problem in special applications (Discharing a 3400mAh battery in less than 40 minutes is not normal usage), not for regular usage.
Notes and links
__________________
My website with reviews of flashlights, chargers and batteries: http://lygte-info.dk/
Ramblings
Ramblings's picture
Last seen: 50 min 17 sec ago
Title: ★★★
Muchas, muchas gracias.
Whatever would we do without your battery reviews.
Much appreciation from just the average flashaholic.
__________________
You are the light of the world. Like a city on a hill, you cannot be hidden.
People do not light a lamp and then hide it away, instead they put it where it gives light to the whole house.
In the same way, let your light shine.
CM2010
Last seen: 2 weeks 4 days ago
Title: ★★★
Good work, as always.
kreisler
kreisler's picture
Last seen: 4 hours 7 min ago
Title: ★★★★★
thanks!!
thanks!! Smile
__________________
*FMI* i have 2 pending orders (=1*E09 +1*USPS).
deletions, **eisl, dis**iminatory, harmless
vēer
vēer's picture
Last seen: 9 hours 9 min ago
Title: ★★★★★
Thanks, good to see that
Thanks, good to see that Efest are making ,as Ezarc corrected my wrong choice of words, distributing decent batteries, makes me much more confident in my protected 2600mAh ones Laughing out loud!
HKJ, youre at your best, as usual Wink!
__________________
http://www.apocalypsetools.com/ EDC, tools, devices and gadgets reviews
SashiX
SashiX's picture
Last seen: 3 days 21 hours ago
Title: ★★★★★
vēer wrote:Thanks, good to
vēer wrote:
Thanks, good to see that Efest are making decent batteries, makes me much more confident in my protected 2600mAh ones Laughing out loud!
I’d say they (as many others brands too, of course) “choose” decent batts to put their wrap on them Big smile
Anyhow, good cell and good review as always Wink Beer
__________________
sb56637
sb56637's picture
Last seen: 3 hours 26 min ago
Title: ==Administrator==
Thanks a lot! Frontpage’d and
Thanks a lot! Frontpage’d and Sticky’d.
__________________
Suncoaster
Suncoaster's picture
Last seen: 14 hours 54 sec ago
Title: ★★★★
Thanks HKJ. Appreciate all
Thanks HKJ.
Appreciate all your reviews.
__________________
“I disapprove of what you say, but I will defend to the death your right to say it.” Voltaire. Evelyn Beatrice Hall.
"Especially DIY cheeses, more embodies the cylinder faithful love the barrel of heart and spirit of innovation, on the strength of shocking and surprised! "
balloonix
Last seen: 13 weeks 5 hours ago
Title:
Thanks to HKJ
Like everytime a perfect review. I ordered 2 pcs of those batteries some weeks ago and made some tests with the same results. Maximum current was 5.8 Amps and cut off was 2,30V. For user im EU it is a good choice because the batteries where delivered from a warehouse in the EU.
applevalleyjoe
Last seen: 7 weeks 6 days ago
Title: ★★
Can you get these batteries
Can you get these batteries in the US and if so, where and how much?
Comment viewing options
Select your preferred way to display the comments and click "Save settings" to activate your changes.
