Xm-l 14500s
9 posts / 0 new
Langcjl
Langcjl's picture
Last seen: 1 year 12 months ago
Xm-l 14500s
Are there any budget 14500 xm-ls yet?
Piers said " ....but who wants enough light, when you have the option for far too much "
Don
Don's picture
Last seen: 2 years 11 months ago
There probably shouldn't be. With the current an XM-L wants for full output you are way beyond what is safe for a lithium cobalt 14500. That would be an IMR or LiFePO4 cell only device.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
ezeqdb
Last seen: 5 years 10 months ago
Anyway, it could be regulated to 2A, and still be very bright and safe Undecided
"no le temo a la oscuridad, la oscuridad me teme a mí"
Don
Don's picture
That's still above what is wise for LiCo cells. My homemade one pulls 1.8A from a LiCo 14500. If I could find where I put it, I'd check the current with the IMR cell in it.
srfreddy
Last seen: 7 years 6 months ago
You should really only be pulling 1.4 amps off a LiCO....
cessnapilot
cessnapilot's picture
is there a thead anywhere on the different battery chemistries?  Are my trustfire flame batteries lico?
Don
Don's picture
Unless it clearly says different, all lithium batteries are lithium cobalt chemistry. It gives the most energy storage of the various lithium chemistries so is the most common. Lithium polymer cells are also lithium cobalt I believe. IMR cells which can be persuaded to go boom but you have to work at it, are lithium manganese. Lithium iron (LiFePO4) cells can't be persuaded to go boom though no doubt someone, somewhere has succeeded in doing it.
The Wikipedia stuff on rechargeable batteries is not bad at all. Better than many an article there.
http://en.wikipedia.org/wiki/Rechargeable_battery
http://en.wikipedia.org/wiki/Lead-acid_battery
http://en.wikipedia.org/wiki/Nickel-cadmium_battery
http://en.wikipedia.org/wiki/Nickel-iron_battery
http://en.wikipedia.org/wiki/Nickel-metal_hydride_battery
http://en.wikipedia.org/wiki/Nickel-zinc_battery
http://en.wikipedia.org/wiki/Lithium_ion_battery
http://en.wikipedia.org/wiki/Lithium_ion_polymer_battery
There are other technologies such as sodium-sulphur batteries but you aren't going to see them in a light since they need to be at above 350C to operate.
srfreddy
lifipo4.... hm.... lets see, how about shorting 2 differently charged ones in parallel? And then hammerering then open with a chisel while you're at it? Laughing
Don
Don's picture
While "warming" them with a welding torch Wink
