Hey guys, I just started browsing Laserpointerforums and stumbled on this thread which lists most of the drivers that the community has built.
I was wondering if any of the gurus here will be able to chime in on the differences between laser diode and LED drivers? Are we able to use those laser drivers to drive LEDs?
Would it be safe to assume then that the FMT driver will be more efficient than a 7135-based linear driver (at the same output current) within the input voltage range of a single li-ion ?
There are a few laser drivers that work well at or below 3Amps…The price of a purpose designed laser driver makes it a poor option ( no pun). A Flexdrive is $30.00 if you can get one and its also 1/4 the size of a NJG driver.
Well I haven’t seen a buck/boost driver for LEDs like that FMT driver I linked in the first post - ~1.7A output current and small enough to fit in a P60 pill = yay!
All these laser drivers also seem small enough to fit anywhere!
The only downside is that they’re pretty much all single-mode only I guess. Oh well you can’t have it all
What I want to find is a simple, inexpensive flashlight driver to push 200-250mA to a bluray diode. I paid $20 for a flex drive and farged it up. Don't want to do that again.
