Review: A Closer Look at UranusFire -- A Sophomoric Review of UranusFire X10
43 replies [Last post]
Tecmo
Tecmo's picture
Last seen: 4 hours 1 min ago
Title: ★★★★★
A Closer Look at UranusFire:
 A sophomoric review of UranusFire X10
I know many people would rather not hear about it, but I think it is time to closely examine UranusFire. I figured I would be the one to tackle this taboo subject. Like ordering the "special" from the local Mexican restaurant, I wasn't sure what I was going to get when I ordered this. Time to get up close and personal with UranusFire. *note - UF usually refers to Ultrafire or Uniquefire, so I won't shorten UranusFire to that. Sometimes simply "Uranus" will be used.*
Manufacturers Specifications:
LED Type:XM-L
BIN:T6
Color:Cool White
Number of Emitters:1
Voltage Input:3.7~4.2V
Battery Configuration:1 x 18650 (not included)
Circuitry:2.5A
Brightness:800LM
Runtime:2 hours
Number of Modes:1
Mode Arrangement:N/A
Waterproof:Yes. IPX8, 30 minutes for 30 meters
Switch Type:Twist switch
Switch Location:Tail
Lens:
Acrylic lens
 Purchased from:  DX  http://dx.com/p/uranusfire-new-x10-cree-xm-l-t6-1100lm-white-light-flashlight-titanium-gray-1-x-18650-152927
Price paid:  $33.50
PROS:
  • Very bright
  • Waterproof
  • Looks good
  • Nice lower mode
  • Has a funny name
CONS:
  • Has a funny name
  • Gets very hot when not submerged
  • Twist to operate
  • Plastic lens
Technical Data:
The light measured 782 lumens on high and 170 lumens on low. It pulls 2.7 amps on high and .558 amps on low. Pretty impressive with the big plastic waterproofing reflector on the front! The throw is very good.  It measures 26600cd.
SIZE COMPARISON:
Left to right: Xtar 2600, UF-502B, Crelant 7G2CS, UranusFire X10, UltraOk 26650 light
If you still haven't decided if you want UranusFire for yourself or not, read on at your own risk!
A full view of Uranus shows that it is pretty big. It is fairly wide and has a lot of ridges. It is very dark and black.
The opening is very wide, and there is a thick covering over it.
Upon further inspection you can see three bumps. You might want to have them checked regularly.
This is what Uranus looks like sideways.
There is nothing soft on the tail end. Just a hard black thing sticking out. You have to strain and twist to get it started.
You can see how dirty the emitter is. It needs wiped badly. When it is getting doused with liquid all the time, you hate to get up in there and wipe it off; but it has to be done sometime. Even if it might hurt.
OH THE PAIN!
I would like to take a minute to discuss the heat which can be associated with UranusFire. You can try to hold it as long as you can, but eventually you just have to let loose. The buildup is just too much. When wet it is not so bad, but sometimes that doesn't even help. Just be careful!
You can see how thick it is around the opening.
Not runny or smeared as you may expect on a light such as this, my sample proudly represents UranusFire.
At one point, I thought I saw something protruding like a turtle head. I was afraid it would vent gas!! Luckily it was just my imagination. I would hate to see Uranus explode!
Here is a look up inside the tail. It is springy.
The rear of Uranus is well-lubed. It has two red rings around it.
The inside of Uranus is very wide and deep. It can fit pretty much anything you try to put in there. Even the big black ones.
Uranus is eventually going to get wet.
Here are some action shots:
Uranus really emits a lot into the toilet doesn't it?
When Uranus is getting wet, it really lights it up! A lot of juice is expelled when UranusFire is emitting; but usually only lasts about an hour!
You can see a lot of bubbles in the water with UranusFire.
When the wetness is finally over, Uranus starts to dry out. It helps if you wipe it clean.
Wet outside, but nothing penetrated the inside of Uranus.
It is still dry all around the hole.
A little moisture, but it all works out in the end.
CONCLUSION:
The Uranusfire X10 is a pretty capable little dive light. I was suprised by the output with that thick plastic lens on the front. I ran the light 10 minutes in the "bog" on high. Then it ran another 15 minutes in the tub on high. Then I twisted the tailcap turning it from high to low a few times, and let it run on low another 25 minutes before I removed it. It stayed completely dry inside. I am glad the light has a low mode under 200 lumens, it is actually useful. I don't like the way it turns on and off for everyday use, but I understand that is the nature of diving lights.
I guess Uranusfire really wasn't so bad after all. In fact, I recommend it for anyone looking for that sort of thing. Just don't drink the water. Wink
Flomotion
Flomotion's picture
Last seen: 10 hours 22 min ago
Title: ★★★★
R U Sirius?
I’m toadally put in orbit by the Uranus toilet specimen finder.
__________________
Flomotion
Ouchyfoot
Ouchyfoot's picture
Last seen: 11 min 43 sec ago
Title: ★★★★★
That’s the most fun I’ve had
That’s the most fun I’ve had reading a review in a while. Big smile
Dale
Dale's picture
Last seen: 2 hours 46 min ago
Title: ★★★★★
I cant stop laughing…
__________________
        The Flashlight Emporium        My Light Curio
bald1
Last seen: 13 hours 38 min ago
Title: ★★
Perfect follow on
to today’s news report about the merits of passing gas on airplanes! hahahahahahahahahahaha
Why you should pass gas on airplanes
Pulsar
Pulsar's picture
Last seen: 1 hour 13 min ago
Title: ★★★★★
note to self: if tecmo is
note to self: if tecmo is trying to sell uranusfire, do not buy uranusfire
very entertaining review, but it would have been sooo much better if you did refer to it as uranus threw the whole review Drunk
Richie086
Richie086's picture
Last seen: 24 min 5 sec ago
Title: ★★★★★
That was the funniest and
That was the funniest and best review I’ve ever read. Thank you for taking the time to put all this together.
BTW, it’s actually a really beautiful light. If I get one, the first thing will be to add grip tape to the name on the handle.
__________________
Richie
Pulsar
Pulsar's picture
Title: ★★★★★
the name is the best part. i
the name is the best part. i kind of want to buy one just to say i have one
apt323
apt323's picture
Last seen: 3 hours 52 min ago
Title: ★★★★★
You and I and alot others
You and I and alot others already have a Uranus but some are just bigger then others
Nice review thanks showing us Uranus………. Big smile
JohnnyMac
JohnnyMac's picture
Title: ★★★★★
When i first saw you were
When i first saw you were going to review Uranus i figured it would be just another crappy review. I really appreciated the in depth look at Uranus. I was surprised that as large as Uranus is, you could only insert a single 18650 in its opening. Sheryl Crow would be proud of you for being able to clean Uranus with less than 4 squares of tp after it spent a good 40 minutes in the toilet. Uranus really excretes a large output compared to a light I have which looks identical to Uranus. I can't help butt wonder how many others here have sampled Uranus but are too embarrassed to admit it. After reading this review I wouldn't hesitate to use Uranus and would be proud to tell others,  "that's right. I tried Uranus and loved every bit of it!". And if they scoffed at the idea I would offer them Uranus and encourage them to use Uranus hard. I'm sure it could hold up to the most rigorous abuse.
Thanks again for the enjoyable review. Uranus is really enticing!
SashiX
SashiX's picture
Last seen: 3 days 11 hours ago
Title: ★★★★★
Tecmo wrote:A Closer Deeper
Tecmo wrote:
A Closer Deeper Look at UranusFire…
Big smile Uranusfire was sucked by black hole Big smile
Nice review, tecmo Wink
__________________
mizjif
mizjif's picture
Last seen: 9 hours 16 min ago
Title: ★★★★★
LMAO!!! Oh man. I lol’d so
LMAO!!! Oh man. I lol’d so hard. That was awesome. Thankyou for this in-depth look at Uranusfire.
FlashPilot
FlashPilot's picture
Last seen: 11 hours 23 min ago
Title: ★★★★★
HAHAHAHA! I laughed all
HAHAHAHA! Laughing out loud Laughing out loud I laughed all the way through your review. Very humorous and quite tastefully done. 2.7A is quite respectable and I like the higher quality double red orings that are shared with many other high-dollar dive lights. Just keep silicon lube on them and they should last a busy season of salt-water diving. How is the beam pattern at intermediate to longer ranges?
The black wicker makes for a great high-tech looking background! Good idea, and it took a while for me to figure out what the hell it was. Thanks again for the great review.
texaspyro
Last seen: 2 hours 30 min ago
Title: ★★★★★
I look forward to seeing the
I look forward to seeing the review of Uranus frontpaged backdoor’d and (ewwww) sticky’d… Crazy
panthervision23
Last seen: 12 hours 39 min ago
Title: ★★
You do have a good collection
You do have a good collection of flashlights. Crown
__________________
LED is the future. led performance
DenBarrettSAR
DenBarrettSAR's picture
Last seen: 6 hours 47 min ago
Title: ★★
This was funny and fun to
This was funny and fun to read at the same time. Big smile I think though the Chinese needs to ease off of abusing the name “fire” for flashlight brands. I think it should have stopped at Surefire, Trustfire, and Ultrafire.
Those three were good and sounded ok, but then came along Uniquefire, Fandyfire, Sandyfire, Pailfire, and now Uranusfire ? The only Uranusfire i know of is when i eat really spicy chilly. Tired
__________________
A Lumen-addict and Flashaholic
djozz
djozz's picture
Last seen: 1 hour 32 min ago
Title: ★★★★
Fun read, thanks for the
Fun read, thanks for the review, and that is one nice clean toilet you have!
Tecmo
Tecmo's picture
Title: ★★★★★
I’m glad everyone liked
I’m glad everyone liked reading about Uranusfire! Smile
I took lux measurements: 26600cd
Nice and throwy with an even beam. No rings. I thought I was just getting a crappy light to review, but it turned out nice. I’ll have to invent a use for it (which has nothing to do with Uranus).
jmpaul320
jmpaul320's picture
Last seen: 1 hour 6 min ago
Title: ★★★★★
LOL whats next… ballfire?
LOL
__________________
TN31mb 431k lux
Dereelight Xsearcher XPE2 de-dome @ 3A 380k lux
VPT3 SBT90MB Aspheric 362k lux
VPT3 SBT90MB 304k lux
SR90 SBT90MA - 245k lux (sold)
Chrome Plated Mag458 127k lux (& >12,000 bulb lumens!)
HD2010 XML2 65k lux (sold)
southcovekayak
Last seen: 1 hour 24 min ago
Title: ★★★
just hoping..
Just hoping we don’t see this particular specimen for sale anytime soon…!
Richie086
Richie086's picture
Title: ★★★★★
Tecmo, if you were happy with
Tecmo, if you were happy with the retailer you purchased from, can you post a link in your OP. Thanks.
__________________
Richie
Tecmo
Tecmo's picture
Title: ★★★★★
Richie086 wrote:Tecmo, if you
Oops, forgot some little details huh? Yeah it was purchased at DX. I had a gift card and I’ve been wanting to check out the quality of Uranusfire for a while Wink Dive lights seem expensive, it was $33.50 but it does the job. OP updated, but here is the link.
http://dx.com/p/uranusfire-new-x10-cree-xm-l-t6-1100lm-white-light-flash…
Chicago X
Chicago X's picture
Last seen: 1 min 2 sec ago
Title: ★★★★★
He said "turtle head."
Tongue Out
__________________
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
dthrckt
dthrckt's picture
Last seen: 3 min 24 sec ago
Title: ★★★★★
informative, and I
informative, and I LOL’d.
needed that today
thanks
__________________
I Like Guns, too
Richie086
Richie086's picture
Title: ★★★★★
Tecmo, Thanks for the link.
Tecmo,
Is this the same light Bang Good.com has? They list it as 1000 lumens having put it into an integrating sphere wth a similar twist switch at the tail. The cost with the BLF discount coupon of 10% comes to $17.08 delivered. So it would seem to be as properly driven as yours.
http://www.banggood.com/Wholesale-Ultrafire-Cree-Xml-T6-Mirror-Reflector…
__________________
Richie
Pulsar
Pulsar's picture
Title: ★★★★★
hehehe… bang good,
hehehe… bang good, uranus…..fire. Drunk
lol, ever get that feeling your 13 again?
edit: sorry, i couldnt help myself
edit again: “we bang good long time uranus, we sell”
(im going to try and keep my juvenile self to this post) Big smile
Richie086
Richie086's picture
Title: ★★★★★
Pulsar wrote:hehehe… bang
LOL, I knew it was going to add fuel to the fire as soon as I started to type the Bang-good link Big smile
__________________
Richie
That Ninja Guy
That Ninja Guy's picture
Last seen: 22 hours 50 min ago
Title: ★★★★
I think you had a little too
I think you had a little too much fun. Laughing out loud
Thanks for the interesting review. Smile
texaspyro
Title: ★★★★★
Richie086 wrote:I knew it was
Would that be fuel to the Uranusfire?
Tecmo
Tecmo's picture
Title: ★★★★★
$17? I feel like I got
$17? I feel like I got reamed!
That looks like a DONGRUI DR-937
http://kaidomain.com/product/details.S021112
It is $35 on KD so that looks like a good deal. The reflector on the X10 is about 40mm with a 58mm head. I don’t think the one you linked to will throw as well, but I can’t find any specs for it.
Richie086
Richie086's picture
Title: ★★★★★
texaspyro wrote:Richie086
ROFL
__________________
Richie
Richie086
Richie086's picture
Title: ★★★★★
Hey Tecmo, I just enlarged
LOL, it’s been really hard to be serious in this thread, but I’m trying to hold it together here.
Hey Tecmo, I just enlarged the photos from both sites and both have the same bezel and model DR-937 by DONGRUI
They seem to be the same light and same amount of cooling fins too.
__________________
Richie
JohnnyMac
JohnnyMac's picture
Title: ★★★★★
Chicago X wrote:He said
Tongue Out
Heheheh...I have one licking my shorts right now.
jfalk1
Last seen: 16 hours 9 min ago
Title: ★★
Wonderful
read..thanks
cone
cone's picture
Last seen: 2 hours 9 min ago
Title: ★★★★★
Bravo, Tecmo! Bravo!
daveam
Last seen: 6 hours 54 min ago
Title: ★★
Might as well get yourself
Might as well get yourself one of these as well. Sorry, couldn't resist.
__________________
DAM
kronological
kronological's picture
Last seen: 4 hours 52 min ago
Title: ★★★
A sphincter says what?
__________________
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
That Ninja Guy
Title: ★★★★
It’s been bugging me…
It’s been bugging me… soph_o_moric
Sorry, I’m just anal. Big smile
sb56637
sb56637's picture
Last seen: 11 min 16 sec ago
Title: ==Administrator==
Thanks very much for the
Thanks very much for the review! Frontpage’d and Sticky’d.
__________________
DX official
DX official's picture
Last seen: 6 hours 24 min ago
Title: ★★★
Well, it had to happen sooner or later....
Love the review!
Obviously, the manufacturer didn’t consult our English copywriter before branding this little gem. But what’s in a name anyway?
If Urnanus gets the job done….then its ok in my book.
__________________
Leading B2C. Getting your desired products with free shipping from Dealextreme.
DX official community at BLF.    DX appreciates your opinion, 3 lucky ones will be rewarded.
Suncoaster
Suncoaster's picture
Last seen: 4 hours 10 min ago
Title: ★★★★
Uranusfire could be your
Uranusfire could be your number two light.
__________________
“I disapprove of what you say, but I will defend to the death your right to say it.” Voltaire. Evelyn Beatrice Hall.
"Especially DIY cheeses, more embodies the cylinder faithful love the barrel of heart and spirit of innovation, on the strength of shocking and surprised! "
Toph
Last seen: 13 hours 25 min ago
Title: ★★
Well Done ...
This has been the Best Review i have read in a long time, Funny but yet still gets to the bottom of things in the end. Love your Work, here’s to more of it. In fact alot of the comments following the Review were just as Entertaining as the Review itself, You should all take a Bow (just not in front of some of the people who commented on uranus {No Names}). This has turned an otherwise bad day into one where i find myself PMSL. Thanks to you All. Cheers
__________________
Damn Addictions
Rusty Joe
Rusty Joe's picture
Last seen: 28 min 22 sec ago
Title: ★★★★★
Good review, Tecmo, and funny
Good review, Tecmo, and funny (well, I was cringing at points). I just hope you disinfected that poor little light and put the lanyard in the washer. He’s been traumatized, no doubt. Even those from Uranus need love and care.
kronological
Title: ★★★
Suncoaster wrote:Uranusfire
Funny!
__________________
Comment viewing options
Select your preferred way to display the comments and click "Save settings" to activate your changes.
