Test / Review: Efest IMR18650 2000mAh (red)
3 replies [Last post]
HKJ
HKJ's picture
Last seen: 1 hour 45 min ago
Title: ★★★★★
V1 Flat top
DSC_1005
Official specifications:
  • Efest IMR 18650
  • Brand: Efest Model: 18650 V1
  • High Drain battery
  • Capacity:2000mah Material: Li-Mn
  • Positive Pole: flat top
  • Sizes: 18.11(L)*65.02(W)mm
Efest%20IMR18650%20V1%202000mAh%20(red)-info
Internal resistance is calculated between 4A and 5A
DSC_0790
DSC_1006 DSC_1007
DSC_1008
DSC_1009
Efest%20IMR18650%20V1%202000mAh%20(red)-Capacity
Acceptable performance up to 7A, but they have problems with 10A.
Efest%20IMR18650%20V1%202000mAh%20(red)-CapacityTimeHours
Efest%20IMR18650%20V1%202000mAh%20(red)-Energy
Efest%20IMR18650%20V1%202000mAh%20(red)-PowerLoadTime
Efest%20IMR18650%20V1%202000mAh%20(red)-TripCurrent
Efest%20IMR18650%20V1%202000mAh%20(red)-Charge
V2 Button top
DSC_1000
  • Nominal Voltage: 3.7v
  • Battery Model: 18650v Capacity: 2000mAh
  • LiMn High Drain battery
  • Positive: Nipple Top
  • Cycle Life: 500 Cycles
  • Max Charging Rate: 4.5amps
  • Sizes: 18.10(L)*66.06(W)mm
Efest%20IMR18650%20V2%202000mAh%20(red)-info
DSC_0790
DSC_1001 DSC_1002
DSC_1003
DSC_1004
Efest%20IMR18650%20V2%202000mAh%20(red)-Capacity
Acceptable performance up to 5A, but they have problems with 7A and 10A.
Efest%20IMR18650%20V2%202000mAh%20(red)-CapacityTimeHours
Efest%20IMR18650%20V2%202000mAh%20(red)-Energy
Efest%20IMR18650%20V2%202000mAh%20(red)-PowerLoadTime
Efest%20IMR18650%20V2%202000mAh%20(red)-TripCurrent
Efest%20IMR18650%20V2%202000mAh%20(red)-Charge
Conclusion
These batteries are supposed to be IMR cells, but their performance it not good at high currents.
At 5A and below they do have an acceptable performance.
Notes and links
The batteries was supplied by Efest for review.
__________________
My website with reviews of flashlights, chargers and batteries: http://lygte-info.dk/
sb56637
sb56637's picture
Last seen: 11 min 58 sec ago
Title: ==Administrator==
Thanks very much for the
Thanks very much for the review! Frontpage’d and Sticky’d.
__________________
That Ninja Guy
That Ninja Guy's picture
Last seen: 23 hours 46 min ago
Title: ★★★★
Interesting, thanks for the
Interesting, thanks for the review HKJ.
SashiX
SashiX's picture
Last seen: 3 days 12 hours ago
Title: ★★★★★
Strange, but all button top
Strange, but all button top cells have worse performance than flat tops Stare It’s OK for protected cells I think, protect circuit can worsen the test, but just having that nipple… Stare
Thanks for the review, H Wink
__________________
Comment viewing options
Select your preferred way to display the comments and click "Save settings" to activate your changes.
