Mini-match gets infinite brightness via QTC
59 posts / 0 new
Match
Match's picture
Last seen: 3 years 11 months ago
Hey guys,  just a quick update on what is now my most favored torch.
After reading about the outstanding job Jekostas did modding his tank E07, I contacted Don about aquiring a few samples of QTC and thankfully he obliged.  The torch to recieve the special treatment is my triple xpg mini-maglite.  The rapid threaded head lends itself almost perfectly to using this for infinate brightness control.  In short order, I had it up and running....and then giggling like a little schoolgirl.  My little torch was no longer a one trick pony, but now able to meet dang near all my illumination needs.  Everyone has an idea in their head of what the perfect torch would be... and for me I just got a little step closer.
  Here's the quick specs on how it stands now:
  • 2xAA size mini-mag
  • 3xXP-G R5
  • Carlco narrow optics with AR protective lens
  • Uses 2x14500, 2xNiZn, or 2x enegizer lithiums
  • Infinately variable brightness from .1lm to over 800lm
  • Twist on/off action (starts off low, then brightens as it gets tighter)
  • No silly strobes and low only draws 1ma from the tailcap (Loooong runtime thereWink-  Eat that, Zebralight...)
Following Jekostas lead here, I shot a quick video the other night.  Pay no attention to my ramblings, I was tired and excited at the same time.Tongue out
Edited by: sb56637 on 02/14/2012 - 08:19 Reason: sb56637 replaced budgetlightforum.cz.cc with budgetlightforum.com via Scanner Search and Replace module.
okwchin
okwchin's picture
Last seen: 3 weeks 5 days ago
Someone needs a finer thread!
Thats one way to get brightness control! reminds me of the keychain lights
Minus the slightly brighter output of this one Cool
"like everyone else - I’m looking for my next “last” flashlight" -  ohnonothimagain
Don
Don's picture
Last seen: 2 years 11 months ago
Niiiice!
I knew you'd do something special with those.
Impressed!
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
SashiX
SashiX's picture
Last seen: 5 years 11 months ago
Wow, dude, you need to create your own flashlight company LOL :bigsmile: Awesome ML Crown Try to speak with them and with CREE comp, and start to sell these piece of artwork 8)
sb56637
sb56637's picture
Last seen: 3 hours 48 min ago
Oh yes! That is a nice mod Match! Well done sir. And thanks to Don for obliging with that QTC material.
jekostas
Last seen: 8 years 4 months ago
Very sweet man, puts what I did to shame - you put the flashlight together AND did the QTC.
pounder
pounder's picture
Last seen: 3 years 3 months ago
that looks awesome..i'd love to have one..
mizjif
mizjif's picture
Last seen: 2 hours 40 min ago
Wow! Match, you never cease to amaze me with your sweet creations! I just popped a piece of qtc into my e07 as well and it is absolutely awesome! Now I need to begin a project such as this mini mag!:) well done sir!
jekostas
Just a thought, but this would work with a standard incan AA-mini mag with an LED upgrade, wouldn't it?  I mean, something like a Terralux mini-star extreme wouldn't be any where near the brightness of Match's masterpiece, but unfortunately not all of us are blessed with his modding skills.
tbenedict
Last seen: 11 months 1 week ago
Nice job...... I want one!
Budgeteer
Budgeteer's picture
Last seen: 6 years 6 months ago
Excellent! Now just out of couriosity... since the fancy material used act as a resistor and the more you press it the less resistance it has.... how did you manage to "prevent" the loss of energy on the resistor?
*** and low only draws 1ma from the tailcap ***
You probably used the quantum goop as a variable resistor in the driver or it's a trade secret? Smile
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
Don
Don's picture
As I understand it, the stuff either passes current or doesn't - there's no resistive heating involved. Since a 4 x 4 x 2mm pill of the stuff can handle 400W there is clearly a different action from the usual resistor. But i could be miles out, it is 29 years since I had to do quantum mechanics and I was never any good at it.
What I'd like to know is how it is mounted in the light.
Budgeteer
Budgeteer's picture
If the stuff does not have any noticeable power loss when current passes through ant any pressure level it is truly an outstanding material.
sixfink
Last seen: 11 months 2 weeks ago
Fascinating!
The technology that makes touch-screens work adapted to flashlight applications. A loss-free dimmer switch... I'm getting ideas...!
Now, where do I get the stuff, and how to work with it?
Don
Don's picture
There are various places sell it, or PM me.
arenat
Last seen: 9 months 5 hours ago
Amazing as usual , how do you manage to not burn the emitters with two 14500 , relying in the internal resistance of the battery ?
fishinfool
fishinfool's picture
Last seen: 8 months 4 days ago
  Match   is my idol.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Match
Match's picture
Wow!  Thanks for the positive responses, Guys!  Let me try and answer some of the above questions:
Yup. I actually used it first on  a bone stock incan mini-mag, and it worked fine.  Lowest setting would barely dribble yellow light out the end...
By using fairy dust and unicorn piss...Tongue out.  On a more serious note, I think there may be a misunderstanding out there on exactly what goes on in a series circiut.  Edit:  Just deleted huge wall of technical text...
Think of it this way: Adding a QTC is like having variable internal battery resistance.  We're only controlling how much current can come out at any given moment. In the same way that the "internal resistor" of the battery doesn't waste power, neither does the QTC.
Arenat wrote:
how do you manage to not burn the emitters with two 14500?
I'm still using the single mode buck driver from the original build.
ezeqdb
Last seen: 5 years 10 months ago
I agree with that!
Cool! are you physicist or something like that?
"no le temo a la oscuridad, la oscuridad me teme a mí"
Budgeteer
Budgeteer's picture
It is truly a wonder material if it acts like a current regulator per se without wasting energy. Still have my doubts that the losses are so small but could be.
Hows the liftime of the thing? 1000+ squeezes?
"Cool! are you (Don) physicist or something like that?"
He has a degree or vast knowledge in almost anything that has to do with science or chemistry and beer or ale (never understood what's the difference)
Don
Don's picture
Traditionally here, beer has hops in it, ale doesn't. Though this seems to vary around the world.
Budgeteer
Budgeteer's picture
Oh that's it? I guess ale is less bitter and aromatic? Not something i would like a good beer lacks...
Don
Don's picture
I already did. And am happy to pass them on at cost. I can easily get more in under a week in people want them.
Don
Don's picture
Today's sterling dollar exchange rate is as bad (for sterling users) as I've seen it in years. They cost 18p each and 20 of them will ship for 76p airmail. They are very small and light so 20 of them will weigh less than 2 grammes. I don't think I have 20 uncommitted so I'll order some more (Minimum order works out at 70  of them).
Paypal is fine for payment.
Don
Don's picture
I've just ordered 100 more QTC pills at a cost of $35.16 delivered to me. Up to 30 of them delivered to most of the world will cost $1.25 for postage. I can easily get more if people want them. I'm quite happy to sell them at cost to me.
Prices:
5 delivered: $3.01 plus paypal fee.
10 delivered: $4.77 plus paypal fee.
20 delivered: $8.28 plus paypal fee.
I'll start a new thread with this info in the seller's spot.
tbenedict
Has anyone tried one of these in a Fenix E01?  I know it has a spring, but it would be great to dim one of these.
Don
Don's picture
Trying it now.
Doesn't seem to work - it still just goes on or off - this may be poor placement of the pill or the boost circuit working harder. I just placed the pill on the head's + contact and screwed the body and cell down onto it. If I can think of a better way, I'll try it.
srfreddy
Last seen: 7 years 6 months ago
Probably the circuitry boosting the cell up-the E01 is a cell vampire.
Don
Don's picture
My thought too. I'll need to improvise a better mounting though and try it more thoroughly later. My E01 gets a new cell every year or so whether it needs it or not - just don't want them leaking in the light.
tbenedict
Yeah, I have had several battery leaks, even from new batteries.  Some people just use dead cells in their E01's for the dimmer output.
Thanks for checking/evaluating.  Trying to think if I've got any other single modes besides the mini-mag led and Gerber IU.  The Gerber has a bunch of fine thread, but I think it has a spring on both sides.
Don
Don's picture
I don't trust dead alkalines not to leak and my E01 has been on my work keys since they were announced - well, since they were announced and the one I pre-ordered arrived. The anodising is holding up pretty well for something like 4 years on a keyring.
