Review: Convoy M1 XM-L T6-3C 2.8A 2-Group 3/5 mode
115 replies [Last post]
JohnnyMac
JohnnyMac's picture
Last seen: 2 min 40 sec ago
Title: ★★★★★
Convoy M1 Cree XM-L T6-3C 2-Group 3/5-Mode LED Flashlight
Fasttech.com has provided me with this Convoy M1 for review.  It arrived with an order I placed for a few other lights, incluidng a Convoy M2 and an S3.  I will be reviewing those at a later date.  The money spent on the other Convoy lights was well spent as they are of amazing quality for such a small price.  The M1 is no exception.  Let's start out with the specifications of this light per Fastech's website.
Manufacturer Specs
Aesthetic
COLORBlack
Flashlights
FLASHLIGHT MODESGroup 1 (3-Mode): 5% > 50% > 100%; Group 2 (5-Mode): Lo > Mid > Hi > Rapid > SOS
LENS TYPECoated Glass Lens
MODE COUNT3/5
REFLECTOR TYPEAluminum Textured/OP
SWITCH FEATURESGlow-in-the-dark
SWITCH PLACEMENTTail
SWITCH TYPEClicky
TAIL STANDYes
Light Sources
LIGHT SOURCE BINT6-3C
LIGHT SOURCE BRANDCree
LIGHT SOURCE MODELXM-L
LUMENS (MAX)700 LM
Power & Batteries
BATTERIES INCLUDEDNo
BATTERY FORM FACTOR18650
REQUIRED BATTERY COUNT1
Manufacturer
BRANDConvoy
Package
PACKAGE TYPEPlain
Dimensionsus | metric
DEPTH35.5 mm
HEIGHT137.0 mm
WIDTH35.5 mm
PRODUCT WEIGHT125.8 g
Product Numbers
FASTTECH SKU 1212405
And now let's take a look at the specs from a modder's point of view - mine. Wink
Total length:137.3mm
Head diameter35.54mm
Tail diameter25.7mm
Lens (diam*thickness)31.7mm * 1.6mm
Reflector O.D.31.65mm
Reflector I.D.27mm
Reflector depth23mm
Switch boot (diam*height)16mm * 8mm
MCPCB diameter20mm
Driver diameter17mm
Weight (less cells)124.2g
CONSTRUCTION
The Convly M1 arrived in the standard bubble bag inside the usual white box.  It was included in an order I had placed which contained 3 other lights and a few odds and ends.  Everything arrived in good shape.  The M1, like the other Convoy lights I received in that order, was in perfect condition.  The only accessory included was a simple lanyard of the usual type.  Some folks might appreciate it but I have a bag full of that style lanyard and would never trust one of my lights to it.  Too easy for the thin attachment cord to wear thin and break.
The light itself, while the more plain of the Mx series (M1 & M2), is a very attractive light with a nice HAIII flat anodizing and a mildly crenelated bezel.  The finish on my example was flawless with no blemishes, nicks, or mismatched or uneven anodization.  The threads are fully anodized and came well lubed with a nyogel type silcon lube.  Each end of the body tube has a brass insert for superior electrical conduction  the tail to the driver.  Aluminum can oxidize and experience a loss of conductivity.  Most lights, even the very expensive ones, rely on a bare aluminum connection to conduct all the electricity.  It was a pleasant surprise to see that Convoy took such care in making sure the M1 had connections that would not oxidize and cause issues or require the kind of maintenance cleaning that aluminum on aluminum requires.  All connections on the M1 are brass to brass.  Even copper will oxidize and create issues requiring special treatment and cleaning.
The machining is as good as better than what I've seen on my Solarforce L2T.  While taking the comparison shots below I noticed my Solarforce L2T threads felt gritty and rough compared to those on the M1.  I've always considered Solarforce threads as a benchmark for what threads should be.  No longer.  That benchmark now belongs to Convoy and BlackShadow as far as I'm concerned.  The threads a super clean, anodized, and are smooth like butter and a joy to work with.  All o-rings are of proper size and seal tightly to prevent water ingress at the joints.  I have no doubt that this light will be able to survive 1-2 meters of submersion.  The fins are cleanly machined with no sharp edges, burrs or chips.  The ano is even in all places and is definitely a true anodization, not some cheap paint job like other lights in it's price bracket have.  The knurling is not the most aggressive ive seen but it is clean and uniform and it provides a solid grip wet or dry yet will not tear up your coat pocket over time like some more aggressive knurling can.
The components used all appear to be of good quality.  The reflector's MOP and has no blemishes, scratches or fingerprints.  The Nanjg 105c driver is a proven component with great options.  All components are heavy and well machined.  It's a light that really feels like it can take a beating and keep on pushing photons.  The switch feels good.  The spring is a little on the long side, in fact the entire tail and switch assembly seems longer than it needs to be but the light as a whole is very balanced looking.  The o-rings are thick and the grooves are perfect in width and depth.  The pieces seal up tight and snug.  It also accepts all 18650 cells from the shorter unprotected Panasonics to the long, protected Xtar 18700 cells.
PERFORMANCE
Performance on the M1 is really sweet.  The beam is very smooth and the tint on my specific example is standard 3C goodness.  While not nearly as bright in actual OTF lumens as the Convoy S3 (U2-1B) I purchased, it vastly out-throws the S3 due to the larger reflector.  Properly designed for an XM-L emitter, the reflector in the M1 is noticably wider than it is deep.  This gives it decent throw for a compact 18650 light.  If you were to order this with a U2 1B you'd see far more OTF lumens as well as more throw to be sure.  I will be taking some beamshots later tonight and updating the review with them.  I will also include comparison shots of the M1 against the M2, S3 and a UF P60 equipped L2T (since the reflector diameter is closest to a p60 light).  In the meantime, here are the raw test numbers.
ModeAmperage at tailOTF LumensThrow distance measured @ 2m
Low.12238.5
Med1.33350.6
High2.65629215.4m
OK...promised beam shots and comparisons have arrived!
Click for hi-res
Lets get down to the pics and teardown so you can see parts for yourself.  Click each pic for a high-res look if you like.
Click for hi-res
The larger head enables the M1 to have more throw than the usual compact 18650 while still being compact enough to easily fit into a pocket.
Click for hi-res
The fins machined into the head allow the heat from the large threaded in pill to escape.  There is a fair amount of mass in the entire head and the heat is well managed.
Click for hi-res
Medium, well machined knurling adds a good feel to the light without being too aggressive.
Click for hi-res
Click for hi-res
The tailcap is a refreshing 16mm in diameter instead of the usual 14mm most other compact lights have.  In fact, all of the compact Convoy lights have the 16mm tail cap.  This makes them very easy to operate and there is no sloppy squish in the switch.  Everything has a very tight, high quality feel while being easy to operate.  The large base allows for easy, solid tail standing while the thumb notch allows easy access to the large switch boot.
Click for hi-res
Click for hi-res
Some may not like the the crenelated bezel but it's really not as agressive as it may appear in photos.  It does allow you to see if teh light is left on when it's face down on a table.  The  mild orange peel reflector smooths out the beam while still providing pretty good throw for it's size.  The flawless, very well polished surface has a lot to do with that.
Click for hi-res
Odd, looking at the reduced sized pics on my screen, the finish looks like the glossy painted surface of some cheap brands.  In person it's a very nice flat black matte finish.  Click on the pics to see the full res originals. They look much better.
Click for hi-res
The laser engraving is nice and deep and consistently solid.  Nice and crisp.
Click for hi-res
All threads came nicely lubed with silicon grease.
Click for hi-res
Brass inserts on both ends of the body tube mate nicely with the brass switch retaining ring in the tail and the thich pill in the head.  Great conductivity with no oxidizing at the contact points.
Click for hi-res
Here you can better see the  pressed in brass rings.
Click for hi-res
Threads are super clean, deep , and close to being square.  They move like butter and are pretty exceptional.  Hard to believe this is a $20 flashlight.
Click for hi-res
Here you can see the 2.8A Nanjg 105c  This is one of the ones with 2 mode groups.  Group 1 has 5 modes - low/med/high/strobe/SOS.  Group 2 has just 3 modes - low/med/high.  To switch between the groups, enter low mode while in either mode group.  After about 4 seconds the light will flash once.  When it does, quickly turn the light off then back on and you will be in the other group.  The light will stay in your chosen mode group until you intentionally change it again.  Memory is pretty quick and pleasant to use.  I like that you can lockout blinky modes when you don't want them but can still have them should you need them.  A really nice compromise and gives the best of both worlds without having to solder any of the stars.
Click for hi-res
Threads inside the head are just as clean and well anodized as those on the body.
Click for hi-res
Here we have a look at the bezel removed from the head.  Again, all threads are great and well anodized.
Click for hi-res
Thick o-ring in the bezel seals the glass from moisture nicely.  Lens fits perfectly inside with little to no rattle or looseness.
Click for hi-res
The lip on the reflector is very thick but it works well and adds mass to the head.  The o-ring on the head is properly sized and seals as well as all the rest of the o-rings.  Usually I find at least one o-ring on a light that is the wrong size or is useless.  Not the case with this light. ;)
Click for hi-res
Aluminum reflector is well made and surprisingly heavy for it's size.  Probably the thick lip adds most of the mass.
Click for hi-res
With the reflector out we can peek inside at the emitter and pill.  What do we see?  The MCPCB is screwed in place for easy replacement or upgrades.  Thermal grease is under the pad and covers edge to edge without being too much.  It is obvious that the assemblers take pride in what they do.
Click for hi-res
The pill is nice and thick and well machined like the rest of the light.  Lots of mass and threads to conduct heat away from the pill and into the head.
Click for hi-res
Clean soldering on the connections between driver and pill.  No cold soldering here.
Click for hi-res
Another close look at the MCPCB and LED.
Click for hi-res
When assembling the light, insert the reflector, then the lens, o-ring and bezel.  Once they are in and snugged down you thread the pill in from the bottom and snug it against the reflector.
Click for hi-res
Click for hi-res
Now we move to the back end.
Click for hi-res
The tail has two lanyard holes as a proper tail should.  This allows you to loop the lanyard through the holes without the lanyard going over the lip of the tail.  This allows you to tail stand the light without the lanyard loop making it unstable.  It also has a notch in case you prefer to use a split ring.  The ring can sit into this notch for stable tail standing.
Click for hi-res
Solid brass nipple for good battery contact.  Unscrew the brass retaining ring to access the switch internals.
Click for hi-res
Here is the brass retaining ring for the switch.  Really solid and heavy.  Really pretty, too.
Click for hi-res
Nice and thick.
Click for hi-res
Here we have the switch with the bushing and plunger attached.
Click for hi-res
Removing the bushing and plunger reveals a very long spring.  Fortunately it seems a little thicker than the usual tail springs.
Click for hi-res
Working end of the switch.
Click for hi-res
Here we have all the front end bits together for a group shot.
Click for hi-res
Here are the tail piece bits striking a pose.
Click for hi-res
And all of it together.
Click for hi-res
Now a few comparison shots.
Click for hi-res
Click for hi-res
Click for hi-res
Click for hi-res
Click for hi-res
Click for hi-res
Due to requests for pics of the M1 in hand to get an idea of size, here are a few more. Wink
Click for hi-res
Now you see it...
Click for hi-res
...now you don't.
Click for hi-res
MY FINAL THOUGHTS
I can't recommend the M1 enough.  It gets a solid "Mac Approved!" endorsement!  When I first saw the Convoy lights on Fastech's website I thought the M1 was very plain, especially compared to the M2, and I fully expected to prefer the M2 that I purchased more than I would this M1.  I am a sucker for stainless steel bezels like the M2 has but this M1 just performs better and its stealthy appearance has grown on me to the point where I prefer it.  Against a standard p60 light I believe I'd choose the M1 simply because of the excellent heat sinking and the choice of driver output and XM-L tint and bin options.  Sure, you can't swap them out as easily as a p60 host but I usually own a host for every drop-in I have so it doesn't matter to me.  For the money the M1 has to be one of the best values out there.  It's only real competition is the other Convoy lights.  They really are great!  I will be reviewing my other Convoy lights in the very near future.
JohnnyMac
JohnnyMac's picture
Title: ★★★★★
Special thanks to Fasttech.com
I'd like to thank Fasttech.com for their providing this light for review.  They are quickly overtaking all the other Chinese retailers we deal with by providing genuine products at the lowest prices around all while offering superior customer service.  At the risk of sounding like a shill, if you are interested in the M1, head on over to Fasttech and check out the 8 different models they offer.  I truly believe that Fasttech deserves our support.
Convoy M1 XM-L T4-7C AMC7135 * 8
Convoy M1 XM-L T5-5C AMC7135 * 8
Convoy M1 XM-L T6-3C AMC7135 * 8
Convoy M1 XM-L U2-1B AMC7135 * 8
Convoy M1 XM-L T4-7C AMC7135 * 6
Convoy M1 XM-L T5-5C AMC7135 * 6
Convoy M1 XM-L T6-3C AMC7135 * 6
Convoy M1 XM-L U2-1B AMC7135 * 6
_the_
_the_'s picture
Last seen: 1 hour 38 min ago
Title: ★★★★★
Thanks for the review!
Great review, thanks!
__________________
=the=
My flashlight collection + links to my reviews and beamshots / My photo gallery
Disclaimer: Above post might contain referral links, but only to items that I myself have bought, tested & approved.
Chicago X
Chicago X's picture
Last seen: 5 min 23 sec ago
Title: ★★★★★
Thanks for the review, and
Thanks for the review, and especially the in-hand shots.  It gives a much better sense of size than the generic light-on-a-background shots often accompanying reviews.
The new avatar is awesome, BTW...
__________________
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
jacktheclipper
jacktheclipper's picture
Last seen: 4 min 32 sec ago
Title: ★★★★★
I am so glad to see that this light is well made . I have two of them incoming from Fasttech . I intend to use them as bike lights .
Looking forward to beamshots .
Thanks for an excellent review , JohnnyMac .
cool avatar
__________________
My Paracord Stuff
gords1001
gords1001's picture
Last seen: 32 min 42 sec ago
Title: ★★★★★
Good review. I agree, , the
Good review. I agree, , the convoy lights seem real well built. The specifications make modding of budget lights almost unnecessary, their almost like very good pre-assembled diy hosts than budger lights, this I feel realy is a good thing. Big smile
garrybunk
garrybunk's picture
Last seen: 3 hours 15 min ago
Title: ★★★★★
Awesome review Johnny!  Glad
Awesome review Johnny!  Glad to hear it's a great light.  I have to say, appearance-wise the M2 does look sharper.
-Garry
SashiX
SashiX's picture
Last seen: 7 hours 32 min ago
Title: ★★★★★
Great review and great light
Great review and great light Laughing out loud Nice shots, J Wink Beer
__________________
RaceR86
RaceR86's picture
Last seen: 4 hours 15 sec ago
Title: ★★★★
Thanks for the great and
Thanks for the great and detailed review. I have been waiting for it since I heard you were getting one for a review!
I ended up ordering the empty and non-branded host from cnqualitygoods (OEM D4) instead of the M1 the other day (I prefer it that way). But there is no denying the M1 offers the best bang for the buck despite that it comes nicely built. I hope Fasttech will get all the “convoy” lights as unbranded lights at a great price in the future.
I look forward to beamshot comparison!
__________________
BLF LED database - collaboration spreadsheet and latest news about where to buy LEDs http://budgetlightforum.com/node/19342
thebiggboss78
thebiggboss78's picture
Last seen: 2 min 16 sec ago
Title: ★★
JohnnyMac
JohnnyMac wrote:
href=“https://www.fasttech.com/products/0/10002364/1212401-convoy-m1-cree-xm-l-t4-7c-2-group-35-mode-led-flas-2020”> Convoy M1 XM-L T4-7C AMC7135 * 8
Help a noob please! Whats the difference between these and which one do you recomend?
Thanks! Laughing out loud
__________________
Form is Temporary, Class is Permanent.
RaceR86
RaceR86's picture
Title: ★★★★
More AMC chips equals higher
More AMC chips equals higher output on high. (downside is more heat and less battery life).
The first numbers after XM-L is BIN. It tells you about the expected output/efficiency of the led. Read more here
The number after bin is tint. Or color temperatur. Here is a chart I made for the tints sold from Fasttech:
I would have bought it with 8x AMC and 5C tint. But I prefer warmer tints…
__________________
FMS
Last seen: 1 day 8 hours ago
Title: ★★
thebiggboss78 wrote: Help a
Thanks! :D
+1 Smile
thebiggboss78
Title: ★★
RaceR86 wrote:More AMC chips
So the U2 8xamc will give me maximum brightness?
__________________
RaceR86
RaceR86's picture
Title: ★★★★
Yes..The the 8 chips they
Yes..
The 8 chips (8×350) they use gives a total of 2,8 Amps.
6 chips gives a total of 2,1 Amps.
See the XM-L specs/chart in the link in my previous post for more info..
__________________
thebiggboss78
Title: ★★
RaceR86 wrote:Yes.. The 8
RaceR86 wrote:
Yes..
Thanks!!!
I just ordered Convoy M1 Cree XM-L U2-1B
https://www.fasttech.com/products/1212400
Laughing out loud
__________________
BanglaBob
Last seen: 16 hours 5 min ago
Title: ★★★
Like mine!
Must appreciated review. Many thanks. Ive been using the M1 now for over a week; and I like it a lot. It’s got a lot going for it.
I got the very same one that’s being reviewed here. Probably the best thing about the M1 is the tints/drive levels available, since everyone has his own preference.. Laughing out loud
__________________
PilotPTK
Last seen: 46 min 1 sec ago
Title: ★★★★★
Hey JohnnyMac, is there any
Hey JohnnyMac, is there any chance you could take a photo of the M1 with a L2T or L2P (or some solarforce L2*)? I have an M1 on order from FastTech, but I’d like to see the comparison for size..
Thanks!
PPtk
__________________
I am currently extremely busy with work. Please do not expect a response from me quickly. I will be dropping in as time permits, but the amount of time I can dedicate to responding to topics and PMs is very limited.
ChiggerPepi
ChiggerPepi's picture
Last seen: 11 hours 19 min ago
Title: ★★★
Very helpful review, and I do
Very helpful review, and I do believe it’s time to order one…
I must admit, I like the appearance of the M2 more, but you mentioned something about the M1 performing better. Will you explain why?
JohnnyMac
JohnnyMac's picture
Title: ★★★★★
Beamshot and comparison pics
Beamshot and comparison pics added to the original post.
JohnnyMac
JohnnyMac's picture
Title: ★★★★★
ChiggerPepi wrote:Very
ChiggerPepi wrote:
Very helpful review, and I do believe it's time to order one... I must admit, I like the appearance of the M2 more, but you mentioned something about the M1 performing better. Will you explain why?
Better throw due to larger reflector while still providing great spill and much better heat management due to head design.  Don't get me wrong, the M2 is a great light and you won't go wrong getting one.  I am just surprised because I like the M1 a whole lot more than I expected to.
The M2 is the same size as a p60.  Granted, the L2T does look and feel a little smaller than the other L2 models but I was surprised that the M1 was actually larger than the L2T.  Not much, as you can see in the pics, but enough, especially in head diameter.
PilotPTK
Title: ★★★★★
JohnnyMac wrote:Beamshot and
Thanks Very Much!
The M1 is bigger than I pictured it. Guess I’ll have to order an M2 as well.
PPtk
__________________
JonnyC
JonnyC's picture
Last seen: 1 day 21 hours ago
Title: ★★★★
Excellent review Johnny.
Excellent review Johnny.  Another item to add to the wishlist for my next order.  Seems as though this is a much better alternative to the Solarforce builds that I've done.
__________________
MRsDNF
MRsDNF's picture
Last seen: 1 hour 15 min ago
Title: ★★★★★
Thanks for the review JohnnyMac. Interesting light. The battery tube reminds me of the Shadow line of lights.
__________________
My current and or voltage measurements are only relevent to anything that I measure. Budget light hobby proudly sponsored by my Mastercard and unkowingly paid for by a hard working wife.
gen1.3_
gen1.3_'s picture
Last seen: 6 weeks 6 hours ago
Title: ★★★★
I have yet to own a Convoy, I
I have yet to own a Convoy, I might start with a S2 then work my way up to the M1. They really do look well made. Thanks for the detailed review!
__________________
Brian8383
Last seen: 1 week 5 days ago
Title: ★★
Great review. Thanks for
Great review. Thanks for that.
Also, I am very impressed with Fasttech. They seam to go the extra mile and care about the customer, which is rare for a Chinese based company.
One suggestion on your review. I always find it helpful to see lights in someones hand to get an idea on its size. You have parts in your hand which helps, but a hand actually holding the light is good.
Thanks again.
neutralwhite
Last seen: 1 day 13 hours ago
Title: ★★
hi thanks very much. would a
would a “Panasonic Protected NCR18650A Rechargeable 3100mAh 3.7V 18650 Lithium Battery” fit the M1 ?.
might order a pair along with the M1 7C tint.
thanks.
__________________
~ alpha ready made ~
bdiddle
Last seen: 1 hour 38 sec ago
Title: ★★
With those cooling fins in
With those cooling fins in the head, it looks like it is asking to be driven to 5+ amps
__________________
Newb
kreisler
kreisler's picture
Last seen: 46 min 12 sec ago
Title: ★★★★★
Thanks, helpful pictorial
Thanks, helpful pictorial descriptions of the flashlight parts!
__________________
*FMI* i have 4 pending orders (=1*E09 +1*USPS +1*DO +1*WB).
deletions, dis**iminatory, harmless,
**eisl
JohnnyMac
JohnnyMac's picture
Title: ★★★★★
Brian8383 wrote:Great review.
Brian8383 wrote:
Great review. Thanks for that. Also, I am very impressed with Fasttech. They seam to go the extra mile and care about the customer, which is rare for a Chinese based company. One suggestion on your review. I always find it helpful to see lights in someones hand to get an idea on its size. You have parts in your hand which helps, but a hand actually holding the light is good. Thanks again.
Ask and you might receive.  In this case you did.  I've added in hand pics to the OP.
thebiggboss78
Title: ★★
Quick question. I just bought
Quick question. I just bought this M1: Convoy M1 Cree XM-L U2-1B 2-Group 3/5-Mode 350LM LED Flashlight (1 × 18650 / AMC7135*8 / HA-III). On specs it says rated 350LM, while others T6-3C, T4-7C, T5-5C that are also AMC7135*8 are rated 700LM on the Fasttech website. Did I just purchase the wrong one? Sad
__________________
JonnyC
JonnyC's picture
Title: ★★★★
thebiggboss78 wrote:Did I
Did I just purchase the wrong one? :(
Must just be a typo in the specs.
__________________
JohnnyMac
JohnnyMac's picture
Title: ★★★★★
thebiggboss78 wrote:Quick
Quick question. I just bought this M1: Convoy M1 Cree XM-L *U2-1B* 2-Group 3/5-Mode 350LM LED Flashlight (1 x 18650 / AMC7135*8 / HA-III). On specs it says rated 350LM, while others T6-3C, T4-7C, T5-5C that are also AMC7135*8 are rated 700LM on the Fasttech website. Did I just purchase the wrong one? :(
Yeah, that's just a typo in the specs.  If you look closely you will see that it says >350 lumens and it is, by twice that amount at least. Wink
As long as you bought the AMC7135*8 version you shouldn't worry. Smile
thebiggboss78
Title: ★★
Thanks guys!
Thanks guys! Smile
__________________
thebiggboss78
Title: ★★
How can I tell its AMC7135*8 version
JohnnyMac wrote:
As long as you bought the AMC7135*8 version you shouldn’t worry. Smile
How can I tell its AMC7135*8 version when I get it?
__________________
apt323
apt323's picture
Last seen: 1 hour 55 min ago
Title: ★★★★★
Nice review JM looks like a
Nice review JM looks like a nice light!
Was wondering if this pill fits this light
Link
If so then you could just buy one light and build a pill to swap in to it you wanted. That way you could choose different tints or brightness bins or upgrade the light when newer and better things come out without loosing the option to go back to the old one.
apt323
apt323's picture
Title: ★★★★★
thebiggboss78 wrote:JohnnyMac
It will have 4 of the 7135’s around the spring like in the pictures in the review
thebiggboss78
Title: ★★
apt323 wrote:It will have 4
(facepalm) Smile
__________________
JohnnyMac
JohnnyMac's picture
Title: ★★★★★
apt323 wrote:Nice review JM
apt323 wrote:
Nice review JM looks like a nice light! Was wondering if this pill fits this light "Link":http://www.fasttech.com/products/1616/10002799/1208602-driver-pillar-set-for-26650-flashlights If so then you could just buy one light and build a pill to swap in to it you wanted. That way you could choose different tints or brightness bins or upgrade the light when newer and better things come out without loosing the option to go back to the old one.
Thanks, bud! As to that pill you linked to I'd say no.  That sucker is 30mm in diameter (according to their specs) and made for a 26650 light.  The entire head on the M1 is only 35mm.  Good idea though but no way will it fit.
JohnnyMac
JohnnyMac's picture
Title: ★★★★★
thebiggboss78 wrote:apt323
apt323 wrote:
It will have 4 of the 7135's around the spring like in the pictures in the review
(facepalm) :)
LOL!  Doh!  Been there and done that.  Big smile
rivet62
Last seen: 2 weeks 20 hours ago
Title: ★★
Great review!
Thanks for the great review. Very thorough and great pics!
So, what sort of mods did you have in mind for this light?
iron potato
Last seen: 4 days 5 hours ago
Title: ★★
Very nice review on such
Very nice review on such great flashlight, thank you JohnnyMac Beer
__________________
My Flashlights / Chargers / Batteries
qandeel
Last seen: 2 hours 43 min ago
Title: ★★
Great review Johnny. Thanks
Great review Johnny. Thanks for sharing
So the 4 little boys are queuing for their coffee Laughing
JohnnyMac wrote:
Click for hi-res
__________________
عُمَانْ
bibihang
Last seen: 1 day 6 hours ago
Title: ★★★
Thank you JohnnyMac. Would
Thank you JohnnyMac. Would you review the Convoy C8 in the future? It seems to be a nice light too.
JohnnyMac
JohnnyMac's picture
Title: ★★★★★
bibihang wrote:Thank you
bibihang wrote:
Thank you JohnnyMac. Would you review the "Convoy C8":http://www.fasttech.com/products/0/10002364/1210900-convoy-c8-cree-xm-l-u2-1b-2-group-35-mode-led-flas in the future? It seems to be a nice light too.
If they will send me one I'd be happy to.  A little too much $$ for me to spend on my own for a light that would redundant with some I already have.  I did ask them to send me one originally but it was too pricey for them to send for a review.  If I can work a good discount deal with them so it won't be too much OOP I can make it happen.  Maybe they will read this and reconsider.  I will try though since the C8 looks like a fantastic light and a far better light of that size than a stock/modded Maglite.
rikr
rikr's picture
Last seen: 2 days 23 hours ago
Title: ★★★★★
Great review Johnny. I have a
Great review Johnny. I have a Convoy C8 ordered. Awesome ring!!!
__________________
jmpaul320
jmpaul320's picture
Last seen: 26 min 15 sec ago
Title: ★★★★★
i lol’d @ your new avatar
__________________
TN31mb 431k lux
Dereelight Xsearcher XPE2 de-dome @ 3A 380k lux (sold)
VPT3 SBT90MB Aspheric 362k lux
VPT3 SBT90MB 304k lux
SR90 SBT90MA - 245k lux (sold)
Chrome Plated Mag458 127k lux (& >12,000 bulb lumens!)
HD2010 XML2 65k lux (sold)
JohnnyMac
JohnnyMac's picture
Title: ★★★★★
jmpaul320 wrote:i lol'd @
jmpaul320 wrote:
i lol'd @ your new avatar
Heheheh...you can tell I get bored easily!  Sucks having adult ADD.  Big smile
Mr Frugal
Last seen: 5 weeks 1 day ago
Title: ★★
Very nice review, Thanks.
Very nice review, Thanks. This will probably be my next light as I have been looking for something around P60 size but could handle being driven hard better. Plus I like the fact these lights and the supplier are consistent. Fasttech is awesome, recently changed my mind on a purchase and was refunded same day within hrs!
Flomotion
Flomotion's picture
Last seen: 2 hours 20 min ago
Title: ★★★★
Very nice, obvious quality
Don’t currently own a Convoy, but it looks like they know what quality it. As you indicate, (even compared to the KeyGos M10, which ain’t a bad light), the Convoy has brass this and brass that, and heatsink screws. The machining looks impressive, and it does look like the assembly people take great pride in their product. I will definitely be getting a Convoy soon. I also like how FastTech tells the customer all the specs, including which driver is used — you know exactly what you are getting. At $20, what, couldn’t scratch build one for that…Oh, by the Way, your new avatar is insane, and your review is…pretty
damn good, in fact, damn good… Wink
__________________
Flomotion
JohnnyMac
JohnnyMac's picture
Title: ★★★★★
Flomotion wrote:Don't
Flomotion wrote:
Don't currently own a Convoy, but it looks like they know what quality it. As you indicate, (even compared to the KeyGos M10, which ain't a bad light), the Convoy has brass this and brass that, and heatsink screws. The machining looks impressive, and it does look like the assembly people take great pride in their product. I will definitely be getting a Convoy soon. I also like how FastTech tells the customer all the specs, including which driver is used -- you know exactly what you are getting. At $20, what, couldn't scratch build one for that...Oh, by the Way, your new avatar is insane, and your review is...pretty damn good, in fact, damn good... ;)
Smile  Thanks, brother.
whokilledJR
whokilledJR's picture
Last seen: 4 hours 59 min ago
Title: ★★★★
Thanks for the review JohnnyMac, I’ll definitely pick one of these up in the near future. And your new avatar, is like, ……..disturbing Wink
Comment viewing options
Select your preferred way to display the comments and click "Save settings" to activate your changes.
