Test / Review: BattEnergy 18650 3400mAh (Black)
2 replies [Last post]
HKJ
HKJ's picture
Last seen: 45 sec ago
Title: ★★★★★
DSC_1638
Official specifications:
  • System: Li-Ion
  • Voltage: 3.6 V
  • Capacity: 3400 mAh
  • Size max: 69.5 mm x 18.5 mm Ø
  • Weight: 48 g
  • Protection: 7A
  • Maximum discharge current: 2C
  • Maximum charge current: 0.5 C
  • Manufacturer: Panasonic
  • Cell: 3400mAh NCR18650B
BattEnergy%2018650%203400mAh%20(Black)-info
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
DSC_1637
DSC_1639 DSC_1640
DSC_1641
DSC_1642
DSC_1643
BattEnergy%2018650%203400mAh%20(Black)-Capacity
As usual with good cells, the discharge curves tracks very well.
BattEnergy%2018650%203400mAh%20(Black)-CapacityTimeHours
BattEnergy%2018650%203400mAh%20(Black)-Energy
BattEnergy%2018650%203400mAh%20(Black)-PowerLoadTime
BattEnergy%2018650%203400mAh%20(Black)-TripCurrent
BattEnergy%2018650%203400mAh%20(Black)-Charge
Conclusion
This battery is using the best high capacity (for now) Panasonic cell and there was no problems in the test, i.e. it is a very good battery.
Notes and links
The batteries was supplied by Taschenlampen-Papst.de for review.
__________________
My website with reviews of flashlights, chargers and batteries: http://lygte-info.dk/
NightCrawl
Last seen: 39 min 47 sec ago
Title: ★★★★★
Made by EnerPower. Thanks for
Made by EnerPower. Wink
Thanks for the great test as always HKJ. Smile
sb56637
sb56637's picture
Last seen: 45 min 24 sec ago
Title: ==Administrator==
Thanks very much for the
Thanks very much for the review! Frontpage’d and Sticky’d.
__________________
Comment viewing options
Select your preferred way to display the comments and click "Save settings" to activate your changes.
