A Perfect Dedome?
1003 posts / 0 new
djozz
djozz's picture
Last seen: 46 min 7 sec ago
mfrey wrote:
I have used gas and it works pretty well. I agree. I'm trying the DS as an experiment. I won't belabor the point but this stuff was formulated to do exactly what we want a solvent to do for de-doming: quickly and completely remove cured silicone without otherwise damaging the substrate. It even washes off with water when it's done. I was going to post results afterwards but folks seem resistant to something new, so anyway...
Well, I am curious about anything new, useful and not so usefull the like, so I'd be glad if you try out the silicone solvant and post about the results Smile (I'd also like reading that post about experiences with square wheels and zigzagged highways Wink )
Tom E
Tom E's picture
Last seen: 2 days 9 hours ago
Please, let us know the results!! This is exactly part of what BLF is about - experimentation, R&D to find better solutions. At the time, I thought gas was the best easiest way, that's why I started this thread, but records are made to be broken.
comfychair
comfychair's picture
Last seen: 3 years 8 months ago
djozz
djozz's picture
comfychair wrote:
thanks comfy! Smile Beer
tallboybass
tallboybass's picture
Last seen: 10 months 1 week ago
mfrey wrote:
I have used gas and it works pretty well. I agree. I’m trying the DS as an experiment. I won’t belabor the point but this stuff was formulated to do exactly what we want a solvent to do for de-doming: quickly and completely remove cured silicone without otherwise damaging the substrate. It even washes off with water when it’s done.
I was going to post results afterwards but folks seem resistant to something new, so anyway…
Hope you post the results, mfrey!
I’ve decided to try dedoming one more time after one unsuccessful attempt. Took the pill out of a Defiant 2AA and hung it upside down in a tiny container of gas (actually, the cap to the gas can). That was 14 hours ago, better go check on it…it might have evaporated! Smile
Tom E
Tom E's picture
tallboybass wrote:
Hope you post the results, mfrey! I've decided to try dedoming one more time after one unsuccessful attempt. Took the pill out of a Defiant 2AA and hung it upside down in a tiny container of gas (actually, the cap to the gas can). That was 14 hours ago, better go check on it...it might have evaporated! :)
It's been posted LED's have been left for several days in gas with no known side effects, so should be fine. I try to do 2 - 2.5 hours, but frequently let is soak overnight, sometimes to the next evening, so 24 hrs has been no problem with me.
mfrey
Last seen: 4 years 1 month ago
tallboybass
Just checked…most of the dome came off with some residual left…but the gas had evaporated who knows how long ago. Put some more gas in there to soak off the leftovers.
And thanks, mfrey, that DS-2025 looks like it was made for dedoming. Let us know what happens!
GottaZoom
GottaZoom's picture
Thanks comfychair, your square wheel vid reminds me of driving through East Los Angeles …
tallboybass
Well the Defiant 2AA light was a semi-successful dedome. It came off but the light it puts out in VERY blue. However, it still works!
Buoyed by the sweet scent of near-accomplishment (and LOTS of gasoline smell) I decided to dedome my S5 Convoy w/XML U2 1B emitter. After slicing into the dome then soaking in gas for 4 hours the dome fell off with just a touch from my fingernail. Next it went into a bath of rubbing alcohol for a while with some swishing around mixed in there for good measure. Then it hung by a ziptie to dry for an hour or so. Before pushing it back into the pill I put some Fujik-like white stuff behind the board…probably way too much, it came out around the edge and made a bit of a mess!
Anyway, after reassembly the darned thing WORKed! The beam was much warmer in color and narrower, with a tiny bit of a donut shape to the hotspot. Upon ‘testing’, which involved visually comparing it to another S5 that has the same 2.8A driver and an XML2 U2 1B in it, it doesn’t seem to throw any farther and puts out noticeably less lumens.
Any ideas on how to improve it from here? I assume the presence of the donut means the focus is a bit off…how should I attempt to rectify this? It has a SMO reflector in it. I’m a little disappointed that it didn’t do much for the throw, I knew it would lose some lumens and warm the beam tint up a bit. I tried spacing the emitter back a little and it didn’t seem to help.
Thanks to Tom E. and everyone else who has posted their results here!
Tom E
Tom E's picture
The transition to blue is strange - seems like the phosphor came off - that's what the beam tint will turn when that's happened to me on XML's.
Usualy the donut hole (I assume dark center?) is from the emitter being further out of the reflector, so you need to get it further in, I believe??
tallboybass
Tom E wrote:
The transition to blue is strange – seems like the phosphor came off – that’s what the beam tint will turn when that’s happened to me on XML’s.
Thanks for the reply Tom. I figured it must be the loss of the phosphor on the one that went blue. I have no idea what kind of emitter is in those 2AA Defiants….XB-D maybe?
Yes, the center was a little darker than the rest of the hotspot on the other one. How in the heck do you get the emitter farther in the reflector?
comfychair
Does the S5 reflector have that lip around the base? If so that will bottom out against the pill and thinner insulators won't actually change the focus any. Trim that lip off and it'll start responding to different thickness spacers.
Pulsar13
Pulsar13's picture
Last seen: 9 months 5 days ago
comfychair wrote:
Does the S5 reflector have that lip around the base? If so that will bottom out against the pill and thinner insulators won’t actually change the focus any. Trim that lip off and it’ll start responding to different thickness spacers.
+1. I have some light that needed this too, but still hasn’t done it. Seems way too easy to make a mistake on this and totally ruin the reflector.
What’s a good method to “trim” off the extra base of the reflector?
comfychair
LOL, I use tin snips. Cuts much easier than you'd think. Needs only very little cleanup with a file afterwards to knock off the sharp edge, the whole thing doesn't have to be filed down perfectly smooth.
Stockton-Rob
Stockton-Rob's picture
Dremel?
and the lord did utter….‘let there be light’……..and CREE said ‘how much?’
siletto
siletto's picture
Last seen: 15 hours 31 min ago
I tried to dedome a dead xm-l in gas for about 16h, but it failed. I hanged the star sideways in the glass, i thought the dome will slip off by the gravity. It actually worked, but a lot of silicone remained near the wires. I tried to remove, but i broke the wires.
Is there a way to trick out that situation? Dissolve the silicone, or anything? Because i think if i do the same thing again it will also broke, and it is a bit pricey to waste the xm-ls to me.
Tom E
Tom E's picture
Oh boy - I got a ton of XML T6's laying around, all from upgrade mods. I always do it on a dis-connected board though, never wired. I use a toothpick now with a 20x lighted magnifier to clean up the silicone, but I won't try for 100% around the wires. You have to use something soft with a magnifier, even then, I don't take the risk getting too close to the wires. Very important though to have good visibility.
siletto
siletto's picture
For “wires” i meant those hair-thin copper wires on the led die. Mine is also disconnected. The problem was that a silicone chunk that remained on the die with the copper wires in it were loose, so i thought it released the wores, i could simply push it away from the led.
Sirius9
Sirius9's picture
Last seen: 4 days 10 hours ago
My first XML dedoming in progress (XPG was a fail Sad ), will see how it turn out…
garrybunk
garrybunk's picture
Last seen: 6 hours 54 min ago
I burned up an XM-L (& driver) while bench testing a driver recently (thanks to RaceR86! - just kidding man) and so I was about to toss it in the trash when I had this idea to try and dedome it by soaking it in gas.  I had not brushed up on the technical details on what to do and didn't have time to so I just threw it in a plastic cap with some gas and set it aside (cap was about 1 inch wide and 1 inch tall and I only put about 1/4 to 1/2 inch of gas in it).  I checked on it every now and then and finally plucked it out about 2 hours later.  The dome just fell off and it looked fairly clean.  I then doused it with some rubbing alcohol to rinse it.  I did try applying power to it to see if the gasoline brought it back to life, but no such luck Cry . I'm sure if this LED had been a working one I would have failed.
Here's a pic (best I could get with my phone):
1
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
NOTE: Moving my photos from PhotoBucket to Flickr. PM me or post in the thread if you can’t see my images and need me to fix or send a gallery link. PhotoBucket images should remain visible until November 2018.
Sirius9
Sirius9's picture
Mine ended up kinda OK-ish, but tint shifted to more-green :Sp which I don’t like too much…
garrybunk
garrybunk's picture
Do we have a guide as to  how far tint shifts based on the tint you start with before dedoming?  I know generally speaking that dedoming will move you to a warmer tint, but how far?  What is the "best" cool white tint to start with so as to end up near a nice neutral white tint (i.e. 4C tint)?  Start with a 1C?  1A?  Or is it not this simple?
-Garry
Tom E
Tom E's picture
I saw a nice post of maybe 3 different tints, and their resulting de-domed tints - not sure where this was. I like the 0D and 1A's de-domed - 1A turns neutral but not too much yellow - much like a 3C or little less. 1C's definite more yellow, I'd say more so than a 3C. I accidentally de-domed a 3C and wow - ton of yellow but looked nothing like the T3 6A1 and T4 warms I've seen - the de-domed 3C was much more yellow than the warm tints, in fact the warm tints seem to me to be more of a true pale white while the 3C is more yellow.
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 day 14 hours ago
Well thanks to RaceR86 i know that de doming of cold white emitter(6500) upper neutral white color appears(around 4800) which has little greenish tint visible in aspheric and not so visible in reflector. This de-domed tint looks much better to me than cool white but don’t ask me; you decide.
Guys if you are not familiar with tint colors it looks something like this:
RaceR86
RaceR86's picture
Last seen: 3 years 11 months ago
-Garry
I would say its beneficial to start with 1A/1D instead of 1B/C.
On the tint chart, most emitters seem to end up 1300-2100K to the left, and then some up (towards the green/yellow spectrum) You will not end up with anything as nice as a 4C no matter where you start in the CW range.. A 2A would probably get you "close" to a 4C in terms of temperature.  But it could still not compete in color rendition or color tone IMO. I have not measured this stuff, so I dont have hard factual numbers. I have seen texaspyro show some stuff on temperature change, but I have never seen any numbers on color tone.
Luminarium, your are learning. Smile   Although the pictures you are showing are for describing temperature (kelvin), not hue.
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Stockton-Rob
I’ve found through trial and ONE error (XR-E) that dedoming an XP-G2 R5 2B (CW) on a noctigon:
http://intl-outdoor.com/noctigon-xp20-mcpcb-cree-xpg2-r5-2b-led-p-723.html
:and put in a DD zoomie gave me a really sharp die image, and it retained a great amount of ‘cool whiteness’…
But, when I dedomed another XP-G2 R5 2B (CW), this time on a alu star:
http://intl-outdoor.com/cree-xpg2-r5-2b-led-20mm-mcpcb-p-705.html
:and again mounted in an identical DD zoomie, I got the green tint… everso slight on zoomed in mode (again a nice sharp die image), but quite visible on flood!
Clearly the Noctigon copper base helps immensely.
Cheers all
Rob
Tom E
Tom E's picture
RaceR86 - that's what I was thinking - de-doming would take you 3-4 cells over to the right, and maybe 1 up on this chart: http://flashlightwiki.com/images/c/cb/Ansi-white.jpg. Don't think your link is working, not sure if the ANSI white chart is what you meant.
garrybunk
garrybunk's picture
Link works for me.
-Garry
Rockspider
Rockspider's picture
Yesterday tried my first gasoline dedome, in EU unleaded 95 gas (here called "benzina", if anybody cares).
Worked like a dream, both emitters came out of the overnight bath clean like the dome was never been there, wires area too! GREAT!
But clearly I underestimated the color shift: on noctigon XML2 T6 C3 became so yellow it looks like those french car headlights from the early eighties... Undecided
And on octigon XPG2 R5 B2 went slightly better but has a definite green hue.Cry
Now ordered XML2 U2 A1, hope the tint remain better...
