A Perfect Dedome?
1003 posts / 0 new
djozz
djozz's picture
Last seen: 1 min 23 sec ago
texaspyro wrote:
"This video is unavailable" error...
I am not sure what happened, I made it public this time. Anyone else can't see the video from post #87 ?
dct73
Last seen: 11 months 3 weeks ago
I can see it
djozz
djozz's picture
djozz wrote:
dct73 wrote:
I can see it
Thanks
Tom E wrote:
That's amazin stuff! I guess you could reflow, then de-dome in one fell swoop! I assume that's an XP-G2 - you are a better man than I -- I never would have attempted a de-dome technique the first time on a XP-G2.
I did reflow and with the led still hot dedomed it, the video is one shot (and perhaps a lucky one Innocent). The led is a XP-E2 R3, 1D tint.
It is going into my 'budget test-thrower' (49mm reflector, led @2A), just to see what an extreme pencil beam will look like Cool. I may do a beamshot and some lux-readings if it gets finished this weekend Smile.
ok, I was inspired by the post of zizo and quickly finished the mod mentioned above. Just two pictures, hope you don't mind, Tom? (I do not want to derail this thread):
reflector 49mm, dedomed XP-E2 R3 1D-tint on copper, screwed on pill, arctic silver in between , driver LD25 2.0A, tailcap:2.0A. Ceiling bounce lumen estimate: 290 lumen. Throw (measured at 2 meter,3 meter and 5 meter, same results): 170klux@1m Cool (165klux after 5 minutes), functionality: zero, this is an utterly useless flashlight.
beamshot:
ImA4Wheelr
Last seen: 1 week 4 days ago
Quote:
djozz wrote: . . . functionality: zero, this is an utterly useless flashlight.
I don’t know about that. Looks like it would be handy trying to find buoys out on the water. In that situation, flood reflects off the water and boat and blocks your far view. That light you built is sweet. Looks like you could see buoys way, way out there.
djozz
djozz's picture
ImA4Wheelr wrote:
I don't know about that. Looks like it would be handy trying to find buoys out on the water. In that situation, flood reflects off the water and boat and blocks your far view. That light you built is sweet. Looks like you could see buoys way, way out there.
Funny you mention that, I have done that many times during sailing boat races at night here in Holland, but that was 10 years ago. At the time we had big maglites for that (very useless), and lead-acid battery powered big halogen lights, those were great, but lasted 7 minutes on a battery. And now we have this in our pocket Surprised. But still an aspheric would be even better for buoy-searching because of the total lack of spill
Tom E
Tom E's picture
Last seen: 9 min 28 sec ago
djozz - I don't mind at all and it's not off track, that's the next phase, what are the results and what do we do with these de-dedomed emitters? Smile
dthrckt
dthrckt's picture
This is probably the thread to note that
I’ve wasted >$100 trying to dedome mtg2s
You CAN shave the dome off with a razor, but the phosphor is thicker than you think, and the throw gains are not as high as with other emitters (neither are the output losses).
Petrol – no go, all the phosphor will come off the center of the emitter
Same with acetone.
If you try the ‘off heatsink heat method’, the dome will bubble at the emitter and pull the phosphor off…and it takes a @#$% load of power to do that…these things can handle some serious current…
____________________
Girls can shoot!
dthrckt
dthrckt's picture
100% agree. This is the only kind of thrower I need – tight aspheric beam to avoid back scatter on the water.
In NY state, the water is often much warmer than the air (particularly in late summer and fall). The amount of back scatter at night is ridiculous. you can’t see anywhere if there is any spill.
But, if camping on a small island, this makes for quite a surreal experience – fog rising all around but no fog on the island – and there’s still a cold/clear upper atmosphere and so many stars visible 8)
Girls can shoot!
comfychair
comfychair's picture
Last seen: 3 years 9 months ago
GUZZALEEEN!!!!!111one
I wouldn't have tried this on a U2 otherwise, but this one was dead after a reflowing screwup, so no loss if it didn't work. Guess what? It works now. It was dead, completely dead. I'm sure it's not 100% healthy, but light comes out when you put power to it.
apt323
apt323's picture
Last seen: 22 hours 53 min ago
Nice build and numbers. What light/host are you using to get those kind of numbers?
djozz
djozz's picture
dthrckt wrote:
This is probably the thread to note that I've wasted >$100 trying to dedome mtg2s You CAN shave the dome off with a razor, but the phosphor is thicker than you think, and the throw gains are not as high as with other emitters (neither are the output losses). Petrol - no go, all the phosphor will come off the center of the emitter Same with acetone. If you try the 'off heatsink heat method', the dome will bubble at the emitter and pull the phosphor off...and it takes a @#$% load of power to do that...these things can handle some serious current...
That is sad, sorry to hear that you ruined many of those . At least by mentioning it here people are warned not to try it themselves.
djozz
djozz's picture
It is this light from dx, I think it is a good deal, one of the few large reflector lights under $20, it is not too heavy, but there is enough aluminium near the pill and the body is one piece, good for heat spreading. The reflector is also aluminium, had to file some away to stop it touching the solder joints of the led-board.
But I seem to be the only fan of it, the problem may be the 'coffee' colour, I don't like it either. I use it as a test thrower because it is very easy to mod. It has its third driver now and its fourth emitter Cool, and I guess the current set-up will also not last long...
Tom E
Tom E's picture
Looks a lot like my Small Sun ZY-T619 here which I got for 50% off, like $13. Been on my list to play with, but no time. Thought it was an X9 clone, but not quite the same quality, bit disapointed.
djozz
djozz's picture
Looks very much like it, but there are also quite some differences (I looked at pictures at manafont.com), the most obvious one is the body of that Small Sun is not one piece. Anyway, it is the reflector that does the job Smile.
comfychair
Successful gasoline de-dome on XP-G2, as well. Working just fine at 2.8 amps. Previously mentioned resurrected XM-L2 U2 working fine at 3.8 amps.
I'm sure there are tools made for this, but I don't have one, so... I made a plastic pointy-thing from the tail end of a zip tie, cut to a very very fine sharp point. Use that to clean away any of the crumbly bits of silicone off/away from the dome. (I used a metal knife on the assumed-dead XM-L2 in the earlier picture, hence the nasty scratches on the substrate - no more of that, thanks.)
bose301s
bose301s's picture
Has anyone tried kerosene on these?
comfychair
If somebody wanted to make a blue one, on purpose, what's the best way to get rid of the phosphor layer?
GottaZoom
GottaZoom's picture
Last seen: 1 year 6 months ago
dthrckt wrote:
i’m going to have to try gas on an xr-e. I’d LOVE to get a clean/no-ring de-dome.
2x the current of xp-e…should be quite a thrower
Finally got around to cutting the grass and since the mower needed gas the XRE started it’s bath late today. It’ll probably soak until some time Thursday morning.
What kind of current are you thinking? Or have you already done it?
comfychair
The ones I've done in gas only need 3-4 hours, even without giving it a headstart by lifting the corners.
GottaZoom
GottaZoom's picture
comfychair wrote:
The ones I’ve done in gas only need 3-4 hours, even without giving it a headstart by lifting the corners.
Well, I pulled it out of the dunk this afternoon and there wasn’t any sign of remaining silicone on the ring or the mount. Used bent needle nose pliers to pull the ring off (green stuff adhered on bottom of the ring, spots show in the pic below). Sprayed it off with some electrical contact cleaner to dry it off fairly quickly.
Results
Applied power for a just a brief moment and it still lights up. So I guess I’m now 1 for 1 on a successful de-dome.
Perhaps swapping out the XPE in a single mode SK68 to see what happens is the way to go.
A reflow over to a copper sinkpad and into a P60 drop-in with a new driver would be nicer. Will 2.8A be too much, or should I just limit it to 2.1A? Suggestions on how much amperage to reasonably push into it?
Tom E
Tom E's picture
There's no SinkPAD for XRE's?? For XRE's, limit is about 2.2 - 2.4A or so, I've used 2.45A for A60's, maybe not much more than 2.1A. I'm using XP-E2/SinkPAD's now in A60's at 2.8A -- Match's tests still show a rising lumens output at that amperage, but not rising much...
GottaZoom
GottaZoom's picture
Tom E wrote:
There’s no SinkPAD for XRE’s??
Good question – I think the MTG and XML pads are too narrow, and Sinkpad doesn’t seem to list it.
dthrckt
dthrckt's picture
depends on your XR-E. people here have gone north of 2.5A with white R2s, and that’s without copper PCB.
I can say from experimentation that the green ones are not as robust. Also, the Vf on greens seems to be much higher than white – ie I can direct drive a green xr-e off one CGR18650CH and it won’t eat over 1.4A because of the Vf, but that doesn’t seem to be (as much of) a problem w/ white xr-e
I sent an XR-E R2 to Match and there’s a graph of his test on here somewhere…
edit: also, I flowed an xr-e to a copper sinkpad, and w/o an good tests to back it up, I’d say its a toss up between using that and an aluminum pcb (w/ proper xr-e solder pads), because you lose so much contact area on the center pad.
Girls can shoot!
dthrckt
dthrckt's picture
Tom E wrote:
There’s no SinkPAD for XRE’s?? For XRE’s, limit is about 2.2 – 2.4A or so, I’ve used 2.45A for A60’s, maybe not much more than 2.1A. I’m using XP-E2/SinkPAD’s now in A60’s at 2.8A — Match’s tests still show a rising lumens output at that amperage, but not rising much…
nope, I asked them directly.
and since it isn’t something they already make, they won’t mix it into an order like they did with out xml/xpg orders.
Girls can shoot!
ImA4Wheelr
I just did my first on-purpose xml dedome while the led was in place in flashlight. It worked great. Did it as follows:
  • I lifted the led base off the pill so it would have no heat sinking. Turned on the light to high. This is a cheap zoomie with stock driver. High is less than 2 amps, probably around 1 1/2.
  • I darted into another room to grab a sharp pick. Took probably less then 20 seconds. Smoke was coming off the led/base. I turned off the flashlight. Took the pick to the dome and the led slid right off the pad. I quickly slide it back on to the pad. I took advantage of the accidental reflow moment to push the led down and squeeze out the excess solder. I then gave it a few seconds for the solder to solidify.
  • I then carefully stuck the pick fairly low on the doom on the opposite side of the bonding wires. I put gentle upward pressure. I could see an air gap starting to form in one corner of the led, but I could sense the led was cooling because the doom felt like it was stiffening. I turned on the light to heat it up. When I started seeing a little smoke again, I turned it off. Carefully made sure I didn’t reflow again. Lifted the doom more. I was very cautious and repeated turning on and off a few more times, but only for a few seconds (before it started to smoke).
  • The dome came off clean off the top of the led. No residual silicone on the led. The phosphorous looked perfectly intact. Very clean looking. The silicone sheared off above the bonding wires. Perfect, I wanted them to still be protected. There was also residual silicone on the led’s pcb around the led. I left it in place. Pushed the led base back on to the pill and reassembled the zoom and lens to the flashlight.
The light worked great. Reduced the size of the flood, but beam is more intense and warmer as expected. Image of led zoomed out is clearer. Then I got over confident and picked off the residual silicone that was around the led. I did this whiled the led was cold. It peeled off easily. But apparently, it was still bonded to the edge of the phosphorous and pulled a couple small chunks of phosphorous off. You can’t tell with the naked eye, but when the light is zoomed out, you can see the missing chunks in the projected image of the led. Not a biggie because I don’t use full focused zoom in real life. Too distracting. I take it just out of focus so I can see what I am actually trying to light up better.
Werner
Werner's picture
I have done it with slight cutting then heating and pulling off with tweezer some times and it works every time. The dome is clear and the bond wires still a bit messy…
Is this as easy with an XML2?
comfychair
There may be an even better way. All you have to do is build a rocket to launch the LED to fly close to the sun to heat up the dome, then a super-intelligent robot can poke it with a pin and peel the dome off. Do you think that might work better than just dunking the damn thing in gasoline and then a few hours later like magic you have a freshly de-domed LED?
texaspyro
Last seen: 7 months 2 weeks ago
Been there, done that. Problem is robots eats phosphors…
ImA4Wheelr
I get the impression you may be mocking me. That’s cool. It’s all good with me. I’m telling you though, the led was clean and probably took less than a minute to dedome (not counting other issues). No left over gunk like I see in most of the pictures using gasoline.
comfychair
ImA4Wheelr wrote:
I get the impression you may be mocking me. That's cool. It's all good with me. I'm telling you though, the led was clean and probably took less than a minute to dedome (not counting other issues). No left over gunk like I see in most of the pictures using gasoline.
Have you tried it? What's left cleans off very very easy. Just crumbles away. A spritz of rubbing alcohol from a spray bottle gets rid of most of it. Anything left after that falls right off with a little brush from a pointy piece of plastic.
I think most of the 'after' pics of the gas method are taken before it's been given a final cleaning, which might be what's throwing you off.
