We now have Keeppower 14500 800mah Li-Ion protected batteries in stock (button top). These are great 800 mah batteries. Two or more ship in a battery case.
Also
*Crelant V31A-U3 in stock (now Black type III anodizing) *Collimator head back in stock. Also for the first time for those who love NEUTRAL WHITE the 7G5CS is available in NW. All other out of stock Crelant are back in NW. NO Price increase. In fact we have lowered the prices on most items and still have free shipping
On your site it says single mode only! but in the xml-u2 description it is showing 18 lm/180hr making reference it is multi mode as it shows on back of box. confused :~
Xtar has a DIY system (Do it yourself). You can use graphite or solder to remove any of the modes except High by bridging contacts in the head. I had these brought in factory set to high mode only, If you are handy with a soldering iron you can recover any of the modes on these. There are some youtube video’s that Xtar did to show how it is done. The manual also has a chart that shows what contacts to bridge in order to recover or hide modes.
My personal TZ20 had SOS removed and it now has High-Mid-Low-Strobe only.
Just FYI, the KeepPower 14500 batteries are a little longer, and thicker than their AW 14500 750mAh protected counterparts. You would not be able to use one in the Balder HD1 for example, and the fit is a bit snug in the V11A - taking off the sticker helps.
Just tested one in the V11A, It is a little tight but fits even with the label. Of course there may be some variation in dimensions between various individual pieces
