Three the Hard Way - another Mini-Mag Mod - Updated - Beam Shots are up.
35 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
I wanted to give up on this light, but I just could not do it. I even threw it in the trash, but I retrieved it and went ahead and finished it.
Three the Hard way. Of course in Vegas it would be 4 the hard way, or 6, 8, or 10, but I can call it as I see it.
First a little Vegas music
 Now, the mod, or should I say, the brainstorming part, where my brain gets cloudy and the headache booms in the distance, right before I see the white light.
3hw
Guess...
Here's a video to help.
3AA NiMHs in series, but not end to end (long way). More like is in a battery holder, for a shorter and fatter light. The video hopefully explains something. Three 2AA Mags cut down to 1AA. One head. Three NiMHs in series. One XM-L. One Driver. A lot of modding work and hopefully some Las Vegas Luck...
More to come... (don't you hate it when I drag stuff out like this?)Tongue Out
 A few photos of how the jumpers will be made and how they will fit in the tubes.
3thw1a
Two of the plastic bushings are sanded till they will fall in a body tube. Then they are drilled for the small plastic tube crossover. A wire will run from a contact on one bushing to a contact on the other via the small crossover.
3thw1b
I filed the slot with round files till the plastic crossover would fit in.
3thw1c
Here's how the jumper assembly will fit in the bodies.
3thw1d
With the tail cap screwed in. The slot did not affect the tail cap going in.
3thw1e
Of course the other body has to be filed so it can mate up, but you can get the idea.
I will probably use 3/8" flat Nickel Silver rounds for the contacts. Of course two of the four contacts will need springs, due to the fact they will touch negative ends of the batteries. I have some very short gold plated springs for that. This is all just practice. I have not cut the bodies down yet and I am using the original tail ends for practice. I will have to do it all over again when I cut down the bodies.
04-07-2013
I decided to change things up a little. I am going to go with 4xAA NiMHs, instead of 3. I don't want to cut down the bodies more than I have to, so I will use 2AA in the LED body and 1AA@ in the Incan bodies. I have gotten a little done, mainly getting a groove cut in the second body and making a couple of copper pieces.
3thw2a
I made a tiny copper bushing out of some sheet copper and formed it to fit over the center plastic crossover.
3thw2b
I got both of the slots in the bodies to be the same length and width, so the copper bushing will touch the bottom of both grooves. When the tail caps are tightened down, there is enough pressure on the crossover that it grounds the two bodies. I even metered it.
3thw2c
This will be the end cap (or end caps), for the other ends of the Incan bodies.
3thw2d
Once they are permanantly in place, I will solder them together to keep the bodies from shifting and to ground the bodies together, so all three bodies will be grounded. I will also pin them to have a better ground.
It's been labor intensive so far. Everything is hand work and custom fit, but it is going as planned with no surprises. That scares me...
 04-12-2013
Here's the finished contact assembly that fits in the tail ends of two bodies.
thw1a
battery side
thw1b
tail cap side
thw1c
This is the assembly that had me wanting to throw it all away. This is revision 3. It seems to work. This goes in the cut off ends of two bodies.
thw1d
I used copper couplings to hold the bodies together. Then I filled in between the bodies and the couplings with Epoxy.
thw1e
The headache assembly in place. Now I have ground through all 3 bodies.
thw1f
Testing with Alkalines. I have a complete circuit, so I have a good ground now, finally!
I am doing some painting on the light and stripping the tail caps, to be polished. The head is ready to go, so it should be ready to fire off tomorrow night.
 Glam and Beam shots are in Post #4
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 04/13/2013 - 02:08
Triple A
Last seen: 1 year 6 months ago
Hurry,  Grab a Seat,   Old Lumens at it AGAIN !!!!
My "Buddy" and I have some snacks and are anticipating  ANOTHER Fantastic O.L. Mod.
flashlight man
Last seen: 6 years 5 months ago
Yesss Viva Las Vegas. Nice looking O-L. Thank you thank you very much for sharing Wink
Chicago X
Chicago X's picture
Last seen: 6 years 9 months ago
That thing is insane, in the best possible way.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
Old-Lumens
The Finished Light. I painted some areas and polished the tail caps.
t5a
t5b
t5c
t5d
Beam Shots
tb1
Garage Door on High
tb2
Down the side on High
tb3
Side of House on LOW
tb4
Side of House on Medium
tb5
Side of House on High
That's it folks.
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 4 months ago
Very interesting. Looking forward to more progress pics!  8)
RaceR86
RaceR86's picture
Last seen: 4 years 1 month ago
I like these projects. Thinking outside the box..
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Old-Lumens
OP is updated with more photos.
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 2 weeks ago
We begin to see how far you will go to avoid liion. I’m waiting to see the light you will build from all the off cuts you have made. I even know the perfect song. An old ditty about a car built from spare parts. “‘56, ’57, 58’ Chevy” or something like that.
Scott
MRsDNF
MRsDNF's picture
Last seen: 21 hours 19 min ago
Here we go again. Good stuff. By the time I get around to building my original dream light there will be no original ideas left. Wink
Orion
Orion's picture
Last seen: 5 years 11 months ago
Ain’t nothing like an Old-Lumens bespoke flashlight!
“It is a far, far better thing that I do, than I have ever done; it is a far, far better rest that I go to than I have ever known.” – Sydney Carton in ‘A Tale of Two Cities’ by Charles Dickens (1812-1870).
Pinetreebbs
Pinetreebbs's picture
Last seen: 1 month 1 week ago
Another really interesting light, wow!
Could you drill a hole instead of a slot? You would need to pre-wire the tube then assemble the tubes with tape and a bead of JB weld to permanently hold the bodies in a bundle.
One other thought, why not use two bodies with four batteries to feed current to a third shortened body that only holds the LEDs and the switch? You could have about three or six volts depending on batteries type and series or parallel connection.
Old-Lumens
Pinetreebbs wrote:
Another really interesting light, wow! Could you drill a hole instead of a slot? You would need to pre-wire the tube then assemble the tubes with tape and a bead of JB weld to permanently hold the bodies in a bundle. One other thought, why not use two bodies with four batteries to feed current to a third shortened body that only holds the LEDs and the switch? You could have about three or six volts depending on batteries type and series or parallel connection.
A hole? I don't know.
As far as batteries, yes, there are lots of diffeent configurations. It all depends on what one wants. 6xAA, 3x14500 in parallel, All kinds of things could be done.
Old-Lumens
OP is updated. Thanks to Pinetreebbs I decided to go ahead and make it a 4AA light. That way I don't have to cut tubes and cut new threads for the tail caps. I don't like that chore.
Pulsar
Pulsar's picture
Last seen: 4 months 1 week ago
wow… going wild on these things lately huh justin? lol
cant wait to see what comes of this one. the 4x one was amazing
Old-Lumens
Pulsar wrote:
wow... going wild on these things lately huh justin? lol cant wait to see what comes of this one. the 4x one was amazing
I'm just finishing off what I have "in stock". Once the stock is gone, the modding will shut down and I wanted to finish off with a couple unique lights.
I'm still waiting on the EA8 though. I might actually keep that light, LOL...
Pulsar
Pulsar's picture
Old-Lumens wrote:
Pulsar wrote:
wow… going wild on these things lately huh justin? lol cant wait to see what comes of this one. the 4x one was amazing
I’m just finishing off what I have “in stock”. Once the stock is gone, the modding will shut down and I wanted to finish off with a couple unique lights.
I’m still waiting on the EA8 though. I might actually keep that light, LOL
good choice! id like one of them myself, but got another light on my mind right now (shadow sl3)
hope you decide to stick around for a while after
jmpaul320
jmpaul320's picture
Last seen: 4 hours 50 min ago
O L you have been making some extremely awesome mini mag mods lately – do you take orders for custom jobs?
i pay cash Smile hehe.
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
Old-Lumens
jmpaul320 wrote:
O L you have been making some extremely awesome mini mag mods lately - do you take orders for custom jobs? i pay cash Smile hehe.
I have not made any custom order lights. It makes me nervous. It's one thing to mod a light and have it fail, but when you do one for someone else it can't fail. So I avoid doing orders from people.
Someday that may change, but not in the near future.
Old-Lumens
Well, to update this, I don't have anything new. Frown   I have set this aside and will not touch it for a few days. Other issues have taken the limelight. Hopefully I will finish this mod in the next week or so. Right now I am spending time with my favorite Chiropractor. My "Spring cleaning" just about cleaned my clock, LOL.
MRsDNF
MRsDNF's picture
I hope Chiropractors are cheaper in the US than Aus. Better yet just take mind expanding pain killers. There cheaper than Chiropractors and you can do a heck of a lot more when under there influence. Just stay away from rotating saw blades. :_(
Old-Lumens
I threw this project away, in the circular file. The next day I couldn't stand it and got it all back out again. Now it works and it is in the final paint stages. More photos are in the OP.
It's almost done.
keltex78
keltex78's picture
Rufusbduck wrote:
I even know the perfect song. An old ditty about a car built from spare parts. "'56, '57, 58' Chevy" or something like that.
That's Johnny Cash, "One Piece At a Time"
http://www.youtube.com/watch?v=rWHniL8MyMM
Love that song...
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
GottaZoom
GottaZoom's picture
Determination sucks until you get to the good part – it’s no asset until you get there!
MRsDNF
MRsDNF's picture
Old-Lumens wrote:
I threw this project away, in the circular file. The next day I couldn’t stand it and got it all back out again. Now it works and it is in the final paint stages. More photos are in the OP.
It’s almost done.
Just couldn’t leave it alone aye. Well done. Hows the part you cant throw away? Any better?
Rufusbduck
keltex78 wrote:
That’s Johnny Cash, “One Piece At a Time”
Love that song…
Yup. That was it. When I have enough battery tube parts I’d like to make a rainbow Minimag.
Scott
Old-Lumens
Rufusbduck wrote:
When I have enough battery tube parts I'd like to make a rainbow Minimag.
That sounds like a great mod, looking forward to seeing it.
Rufusbduck
Got any colored off cuts from AA minmags? So far I just have silver blue and black. I’d pay shipping+.
Scott
Old-Lumens
Glam and Beam Shots in Post #4
Old-Lumens
Rufusbduck wrote:
Got any colored off cuts from AA minmags? So far I just have silver blue and black. I'd pay shipping+.
No, I have not saved one single cut off from any of these lights.Frown
RaceR86
RaceR86's picture
Justin have done it again!
Its quite a good looking “Frankenstein Mini Maglite” you have made there! I think that is a cool name for it. Wink
It turned out be be a very nice and unique build! Great work!
