This is more a note about my observations on how an increasingly common design compares to the traditional contact behaviour. By which I refer to tradition as the design where there’s a spring ensuring battery is always in circuit and relying on break in path through the body for switching (driver neg contact is not bridged to sides and only complete circuit when lip of body tube touches contact plate). The “newer” as in the design where driver negative terminal is bridged to threading and circuit is broken by gap at the battery contact(*s) when loosened, relying on a compressible spacer/donut (with hole for pos end battery button) on pos side to ensure gap behaves predictably when in use (turning on and toggling) and eliminate battery rattle.
Ostensibly the “newer” design provides some saving in length since the spacers can be made thinner/shallower than a metal spring can, so I’m guessing this is why it seems to be quite common now. However now that I’ve owned a couple lights using this design (both brand name well implemented version of this style and the *other a cheapo clone brand rendition) I feel the traditional style trumps the possible minor decrease in length.
When done properly this implementation has two clear disadvantages (when it’s not it’s a disaster*):
First, it’s usually a bit of a battery crusher due to needing enough pressure to compress spacer disk esp in combination with using raised bit on neg end to ensure contact (including with deformed or dented batteries).
Second is that since the spacer must (until compressed) ensure a break in contact it has to be a non conductive material (foam/”pu foam spring”) which I suspect is not as resilient as a metal spring, especially since it is by design located next to where heat is generated.
Just putting this out there in case anyone else sees these issues and it can gain enough traction to bring it to the attention of manufacturers. Hopefully they either stick to the traditional design or find some fixes for this.
*In the cheapo clone brand they had no spacer/donut which makes it jump thru modes and flicker due to inconsistent contact until tight, which is a pain both when turning on and when twisting to toggle modes and the battery rattle potentially damages both the battery and pill.
