1.Using the latest cree XML-2 LED light,working current:2200mA,brightness can reach 800
lumens.led life up to more than 100,000 hours.
2.Intelligent digital circuit control,working voltage:16.8V,5 modes dimming circuit without memory
function,switch puts in the middle of the flashlight,convenient changing gear.
(1)Hig:800LM
(2)Mid:400LM
(3)Low:80LM
(4)Sroble:800LM
(5)SOS:800LM
3.Vacuum plating smooth cup,high-reflective efficiency.high temperature resistance, anti-fall,
the effect is perfect.More accord with the public demand.
4.Highly diaphanous lens,tempered glass,edge grinding process,effectively improve the ability of
resistance to drop.it can use 4pcs 14500 900mah rechargeable batteries,continously using
more than 60minutes.
5.Appearance: using T6061 Aviation aluminum alloy; Military regulations III anodized CNC
machining processing(color:matte black),head with stainless steel protection ring to protect
the flashlight core components from being damaged,strong and beautiful, easy to carry, surface
polishing, achieve military requirements, overall appearance modelling novel,feel good,anti-skidding,
waterproof level of IP VIII level.
6.Switch puts in the middle of the flashlight,feel good,with the tail inverted function,inheriting
retro style,equipped with a exquisite holster.
7.Dimming conversion mode: high mode,mid mode,low mode, entering in strobe mode and sos
mode with pressed for one second,exiting strobe mode and sos mode with pressed for one
second again.
8.Specifications:120mm(length)*43mm(head diameter)*42mm(tail diameter)
9.Net weight:192.5 g(excluding batteries).
the set comes with 4*14500 900mAh protected battery and a charger,holster.
Price:57.5$, HK post with tracking.
