Which one is the "real" Sipik SK68?
66 posts / 0 new
Firelight2
Firelight2's picture
Last seen: 5 hours 49 min ago
vēer wrote:
Only thing I complained about regarding my lights was that one of the lights came rather scratched and that none of them were really waterproof, so I got partial refund due to their misleading item description, its fairly easy to get water under the lens if you happen to drop it into water or leave it outside/hold for prolonged period of time during rain and there is no way to get rid of that water unless you unscrew the lens cap and wipe it all dry yourself, otherwise it stays there...
There's an inherent difficulty in making small zoom flashlights like this one waterproof.  Especially for lights with relatively smooth push-pull zoom mechanisms.
I encountered this when modding my Sipik SK58, which is similar in size and uses a similar zooming mechanism.  The light originally came missing o-rings and with a metal C-ring in the o-ring slot on the sliding mechanism.  This made a metal grinding sound every time the light was cycled from zoom to flood ... and meant that air could get in and out so the light was not waterproof.
I took out the C-ring, added o-rings in all the o-ring slots and lubed the o-rings up with Nyogel.  The light was now waterproof.  But there was a major problem:
Since the light is now air-tight, cycling the light from flood to zoom is much harder.  As the light is expanded to zoom mode, internal volume of the light increases.  This causes a reduction in internal air pressure.  Since air pressure outside the light is now higher than air-pressure inside the light, the bezel would now retract on its own as the air pressure tried to equalize.  Result was that I'd have to physically hold the bezel in zoom position and if I let go it would slide back to flood on its own.
Assembling the light with the bezel in zoom mode caused the reverse problem.  When I pushed the bezel back towards the body it would increase air pressure inside, which would then push the bezel back into zoom mode on its own.
I solved the problem by removing the o-ring at the lens.  This allowed air pressure to equalize  and resulted in a silky-smooth zoom cycling with the bezel staying in whatever position I left it in.  My conclusion was that it's not practical to make a zoom flashlight of this size and with this zooming mechanism watertight.  You might make it splash resistant with a very tiny gap, but if you want a watertight light, you should select a non-zoom light.
Superior
Last seen: 5 years 1 month ago
Real Sipik68 in branded box with two batteries and charger – http://www.aliexpress.com/item/Free-shipping-Sipik-SK68-CREE-XP-E-R3-LED-150-Lumens-3-Modes-Flashlight-with-Battery/939417041.html
Danglerb
Now I have 3 clones, my preference is to have some of each kind, single and three mode, but I could do without the strobe.
After about a year of EDC I am planning on trying some physically smaller lights, starting with a higher output mid price 1xAAA like a Thrunite Ti2, for more convenient pocket carry and leaving the SK68 clones for toolbag or glovebox.
Still a bit dim
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 1 year 4 months ago
I measured some tail cap currents and was surprised by the spread. With maybe half an ohm in the leads and a 0.6 AH AW IMR charged up to 4.2 V, I got 1.5 amps for a Sipik, 2.1 A for one three mode UltraFire, 0.8 A for another 3 mode UltraFire from a different source, etc. The light output varies but apparently less and not well correlated with the current. I had been supposing that the drivers were all similar, but that is apparently not the case.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
toysareforboys
toysareforboys's picture
Last seen: 6 months 1 week ago
Those batteries are not good and that charger is not safe. Pick up some Sanyo 840mah 14500 batteries and a real charger.
-Jamie M.
Danglerb
Many of the cheap lights have high losses in the case connections.
What kind of leads have half an ohm of resistance? Seems really high, but I haven’t measured any.
I would not put Lion batteries into the hands of anybody that needed good ones. Yes the output is much higher, but Eneloops do fine and have no risk. I use cheap ones, and monitor the charging on a cheap B6 and pay attention to drooping output when in use. I don’t feel all the comfortable using Lion and maybe for now that is how it should be.
GF glovebox light, premium Alkaline or Eneloops, would be my choice.
Ceiling bounce comparison with my three seem fairly similar on high. Maybe you got some bad lights?
My view buy several from several vendors, compare them and only gift the best ones.
Still a bit dim
toysareforboys
I just received this one: http://www.aliexpress.com/item/Upgrade-800Lumens-9W-CREE-XM-L-T6-Mini-LED-Torch-Focus-Zoom-Flashlight-Free-Shipping/997633297.html
OMG bright! Uses XML T6 led, way brighter than all my other SK68’s!!! Super nice having three modes too Big Smile
My digital camera (Canon T2i with hacked Magic Lantern firmware) says the XML is 21% brighter than my brightest XRE Q5 I own!
LED:
Beam:
Brightest XRE Q5 SK68 I have:
The only kind of rings I like are Onion Rings Wink
-Jamie M.
unknown00101
and I thought my sk68 cheapie was ringy. Big Smile
the XML definitely looks better.
Fritz t. Cat
I have one XM-L SK68 I bought already modified and a warm XM-L2 that I switched into one. Better flood at the expense of throw. The total light output depends more than anything else on the current, which varies especially with three modes. I have a lithium ion only driver on order.
Fritz t. Cat
I just got an “SK58” from http://www.priceangels.com/SK58-Adjustable-Zoom-Focus-LED-Flashlight-Lamp-Torch-s85918.html . The knurling is much deeper than on my other three. Only the one with the Osram led actually said Sipik on it. Otherwise similar, so I like this one best. Maybe I will switch a three mode driver pill into it. The XR-E upgraded SK58s are intermediate in size between the SK68s and the http://budgetlightforum.com/node/25402 slim zoomy. The light output is closer to the 68, because the head and lens diameters are nearly as large, but of course nothing else AA has the 68’s heat sinking ability.
Added: The swap didn’t work. The locations of the led in the pill and the locations of the lens in the bezel are different. Also the new one has the slide friction spring on the body, while the old one has it on the pill. The focus was off and the slide friction was wrong.
The knurling on the head on my example is much nicer than the one shown at the selling site. The spacing along the head is narrower and there are micro groves on top of the the knurl rectangles, similar to what I have seen in expensive lights. This makes it very easy to zoom with one hand. One of my best AA lights, and I am not aware of any expensive ones that I might like better. Because it has only one mode, I have an Eneloop in it, rather than a lithium ion.
DBSAR
DBSAR's picture
Last seen: 22 hours 44 min ago
sb56637 wrote:
Silverman wrote:
Slightly off topic… I picked up a couple of cheapo Sipik68 clones on eBay, but they came with different emitters.  Both were described as Cree Q5.
(sorry. crappy pic but you get the idea)
I believe that the one on the left (from Toptom) is the correct one.  What’s the one on the right?
I’m almost positive that the one on the right is an OSRAM emitter, judging by the pronounced square in the left corner.
Defnitely an Osram Emitter, i have several other Osram lights with the same emitter.
As for the original Sipik and the various clones, i have one of every variation i could find, and so far the only “real” one, and best one i have is the red one in this pic. it cost around 9 bucks, single mode, has an EZ900 series XR-E, runs well on both AA alc. and a 14500 lithium, has a glass aspheric lens, and so far is still the brightest of them all, with the best Neutral white tint in stock form.
The others in the photo are the various clones i could find and test. The original is found on the Sipik website here:
- http://suofulan.1688.com/page/albumdetail_29167096_855762054.htm?imageNu... and:
- http://translate.googleusercontent.com/translate_c?depth=2&ei=Hm48TZW4AY...
Danglerb
Did a quick search on ebay just now for cree t6 14500, this one is $8.14 shipped, says five mode, but that includes zoom in/out its just hi/med/strb.
http://www.ebay.com/itm/1600Lm-ThorFire-CREE-T6-LED-Zoomable-Flashlight-Torch-Lamp-AA-14500-5-Modes-/190927316614
Just thinking about it for now, maybe look for a XM L2 for more efficiency. Maybe not, cheapest looks like $27.
Still a bit dim
Fritz t. Cat
I have some marked Sipik and these are not the ones I like best, but maybe you get better ones from the Sipik Web site, for one reason or another.
wolfdog1226
wolfdog1226's picture
Last seen: 10 months 5 days ago
hank wrote:
Has anyone actually gotten a glass lens in a 1xAA Sipik SK68/clone?
They’re fairly often claimed in the specs on web pages but those are consistently wrong in many ways.
Mine is a glass lens and 14500’s work fine. Went from about 100 lumens[primary AA] to about 300 or 400 lumens W/ 14500 Battery. I got it off of Ebay a year ago
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
wolfdog1226
1600 lumens!!! lol!! I have never seen one exaggerated that much!!
Mine was advertized as 300 lumens, more like 100-150 lumens. With a 14500 I am guessing it is 300 maybe even 400 lumens.
It was my first torch!! I got it for about $7!
        WOLFDOG
RaceR86
RaceR86's picture
Last seen: 4 years 1 month ago
Who is the real Mr smith? Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
wolfdog1226
The Real one lives 3 doors down from me!! lol!
        WOLFDOG
Fritz t. Cat
If there are glass aspheric lenses, I wonder if they are cut and polished or only molded. I suppose the plastic ones are molded and that plastic can be formed that accurately by molding, but I think you could tell molded from polished glass by how clear it is as a magnifying glass. One usually can tell how a drinking glass was made by looking at it.
vresto
vresto's picture
Last seen: 8 min 22 sec ago
anyone knows this product? i wonder.is it fake,or..pressure switch for sipik sk68?? is it possible?
http://kiev.ko.olx.ua/obyavlenie/fonarik-sipik-sk68-c-vynosnoy-knopkoy-I...
EDC-Mezzol X8R-L nw
Headlamp-Thrunite th30
Fritz t. Cat
That does look like a remote switch. The switch is in the tail cap that screws off, so it would be easy to make a remote replacement for it. People use remote switches for lights on guns and what not.
vresto
vresto's picture
i got a version with xml u2…its brighter.and-i love it.from kaidomain.
EDC-Mezzol X8R-L nw
toysareforboys
Do you have the link? I don’t see the u2 version on their site??
-Jamie M.
vresto
vresto's picture
sadly not available any more…sadly but i can ask morning for it.sure they have it.
EDC-Mezzol X8R-L nw
Fritz t. Cat
I bought and gave away one of these http://www.aliexpress.com/item/Upgrade-800Lumens-9W-CREE-XM-L-T6-Mini-LED-Torch-Focus-Zoom-Flashlight-Free-Shipping/997633297.html . One might get the light and the XM-L for a little less than that price, but not by much. It loses some throw but puts out more total light.
vresto
vresto's picture
-Jamie M.
here is it: http://www.kaidomain.com/product/details.S023854
take this,its brighter
EDC-Mezzol X8R-L nw
toysareforboys
-Jamie M.
Ahh, I thought it was XML2 Sad nevermind for that price.
-Jamie M.
vresto
vresto's picture
there will be NO diffrence between them…its a driver for nimh also..i have changed the led for xml2…its no sense..few lumens.forget it:) extremly cheap this one..
EDC-Mezzol X8R-L nw
264
264's picture
I have purchased 4 Sipik clones from eBay in the past. All were very low quality. Just received the Sipik I purchased from Gearbest today. It seems to be a real Sipik SK68. Well made and brighter than all my clones. It is also a bit smaller in size. And has a real Q5. Unfortunately I paid a lot of money for it. It broke the bank. I used my Gearbest points to ease the pain a bit. $2.61 Smile
Woytas
I’m also a fan of Sipik’s – can you please share the links? Both for fake ones and real?
zuliaera
Last seen: 2 years 6 months ago
I also used Sipik but i was not much happy with this rechargeable battery light.
