texaspyro
(texaspyro)
April 26, 2013, 12:22am
1
I de-domed an XML2 T6 3C LED. The original color temp was 4820K, a rather nice neutral white. The de-domed color temp is 3068K… standard halogen bulb warm white. Light output went from 865 lumens to 700 lumens. I think I’ll mount it in a Defiant 3C…
I used Coleman fuel to de-dome the LED. I removed the dome became it became damaged with the LED/heatsink toppled over face down onto a table when it was running at 3 amps. Burned a hole in the table and buggered the dome.
Edit: changed the thread title to reflect the addition of the 6500K XML T6 data
Chicago_X
(Chicago X)
April 26, 2013, 12:33am
2
Nice, quantifiable data - thanks for sharing !
ryansoh3
(ryansoh3)
April 26, 2013, 1:02am
5
It’s interesting how the color temperature actually became warmer.
Most dedomes I’ve seen made made it cooler because some of the phosphor that converts blue into white light was chipped off.
Was the dedoming process straight forward with the Coleman fuel?
Thanks for sharing!
A little heartbreaking to hear of a pleasant-tinted LED’s demise. Looking forward to the results of the Defiant build.
dthrckt
(dthrckt)
April 26, 2013, 1:26am
7
texaspyro:
great info!
I put a dedomed xml2 t6 3c on 20mm copper sinkpad in a 7g5v2. I’m surprised how much I like the tint, now that I know the actual color temp.
I also did some resistance fixes, but was very surprised when throw went from ~85kcd (stock, collimator) to ~180kcd, although I suspect I need to measure from farther away. ~13ft probably isn’t adequate for that light…
texaspyro
(texaspyro)
April 26, 2013, 2:19am
8
The Coleman fuel worked great. The dome came off clean and no scuzz was left behind or removed phosphor.
A proper de-dome will result in a warmer color temp.
texaspyro
(texaspyro)
April 26, 2013, 2:48am
9
The Defiant went from 78.4 kcd with the domed XML2 to 160 kcd with the de-domed XML2… over twice the throw (measured at 2 meters)
These Defiants were mod’d with 3 amp Qlite drivers, sinkpad, and coated lenses.
dct73
(dct73)
April 26, 2013, 2:31am
10
Tom E started a thread recently with some good gasoline dedoming info in it. In case you missed it dedome.
ryansoh3
(ryansoh3)
April 26, 2013, 2:34am
11
Thanks. I remember reading about the various chemicals used to dedome them.
texaspyro
(texaspyro)
April 26, 2013, 3:00am
12
I did some lumen measurements on the lights. Running on 3 C cells the domed XML2 was 680 lumens. De-domed was 595 lumens. Stock Defiant right out of the package was around 470 lumens.
Running off a bench supply set to 4.0V was 615 lumens de-domed, 720 lumens domed. This test was just with the head and bypassed the switch.
dthrckt
(dthrckt)
April 26, 2013, 3:05am
13
texaspyro:
huh. well, i’m more confident in my numbers now!
texaspyro:
How is the qlite working out with 3 x C cells? Im guessing it runs well on 3.9V or less?
texaspyro
(texaspyro)
April 26, 2013, 4:08am
15
It’s OK, but the C cells can’t hold the current for long. The Qlite/XML2 drops out of regulation around 3.6V
texaspyro
(texaspyro)
April 26, 2013, 4:10am
16
Some beam shots. Domed on the left, de-domed on the right:
AlexGT
(AlexGT)
April 26, 2013, 4:24am
17
Nice! What equipment did you use to measure the kelvin temperature? Would it be a safe bet to assume a drop of about 1,500k give or take when dedoming a led?
So a dedome of a 0A or 0B tint led (8,000K) has the potential of turning into a 2B or 2C tint?
Thanks!
texaspyro
(texaspyro)
April 26, 2013, 4:28am
18
I haven’t dedomed enough stuff to be able to predict what the outcome will be…
For measuring color temp I used this:
I am building a device for analyzing batteries, LEDs, drivers, flashlights. As planned it would have:
2 × 30 amp hall effect current sensors (< 2 milliohm burden resistance)
2 x type K thermocouples (good to 1000 degrees C!)
Battery and LED voltage monitoring (up to say 50 volts)
LVC cutoff FET for the battery
Light sensor input (digital and analog sensors supported, 50K-100K lux, integrating sphere supported)
RS232 link to computer / monitoring, graphi…
It has a Taos TCS3210 color sensor chip. I calculate the color temp from the color channel readings.
Thanks for the beam shot comparisons. Very useful!
Hikelite
(Hikelite)
April 26, 2013, 7:29am
20
dthrckt:
texaspyro:
I de-domed an XML2 T6 3C LED. The original color temp was 4820K, a rather nice neutral white. The de-domed color temp is 3068K… standard halogen bulb warm white. Light output went from 865 lumens to 700 lumens. I think I’ll mount it in a Defiant 3C… I used Coleman fuel to de-dome the LED. I removed the dome became it became damaged with the LED/heatsink toppled over face down onto a table when it was running at 3 amps. Burned a hole in the table and buggered the dome.
great info! I put a dedomed xml2 t6 3c on 20mm copper sinkpad in a 7g5v2. I’m surprised how much I like the tint, now that I know the actual color temp. I also did some resistance fixes, but was very surprised when throw went from ~85kcd (stock, collimator) to ~180kcd, although I suspect I need to measure from farther away. ~13ft probably isn’t adequate for that light…
What exactly do you mean by resistance fixes?
