It’s here and it’s a beast The newest Crelant 7G10 with MT-G2 emitter.
1860 lumens from a single emitter.
NEW COUPON CODE 7G10 at check out for a lower price with FREE shipping in the USA
Specifications
- CREE MT-G2 LED with 50 000 hours life span.
- Maximum output: 1860 lumens (ANSI FL-1 standard)
- High efficient constant current circuit and output-luminance
- Durable, custom-designed Microcontroller drive circuit
- Side switch and mode changing infinitely variable brightness
(Hidden Strobe and SOS,quickly click side switch twice).
- Working voltage: 5.4V—12V DC
- Battery Types Supported: 4 x 18650
- Runtime:High output at 3 A: 1860 lumens for 130 minutes.
Low output at 0.01A: 1 lumen max for 1000 hours
- Mil. Spec. Type III hard anodized aircraft grade 6063-T6 aluminum alloy
- Color: Black
- Ergonomic grip with anti-roll design
- Bezel: stainless steel
- High performance aluminum OP reflector with concentrated beam shot
- Waterproof: IPX-8 Standard
- Lens: Toughened & ultra-clear coated and anti-abrasive glass
- Dimensions: Length 198mm, Head Diameter 79mm ,body 54mm
- Weight: 644g excluding battery
- Accessories: Lanyard, spare o-ring
