XM-L2 emitter. High of 980 lumens - for 3 minutes - and low of 30 lumens. Interesting switch.
From their spec:
Features
● CREE XM-L2 LED, with a lifetime of up to 50,000 hours;
● Brand-new Dual-button Side Switch System, slightly depress the side switch buttons for output ranging from 30 to 980 lumens, Police Strobe, Aviation Signal, SOS, Strobe and Moon Mode:
Turbo: 980 Lumens (To avoid overheating, the light will enter High mode automatically after 3mins continuous use)
High: 550 Lumens (1.7hrs)
Mid: 220 Lumens (1.8hrs)
Low: 30 Lumens (31hrs)
● Constant current circuit, constant output;
● Effective range of 315 meters;
● Intensity: 24800cd;
● Uses 4* AA (alkaline, NI-MH, nickel-cadmium) batteries;
● High quality reflector with soft beam pattern;
● Working voltage: 3~6V;
● Optimized Deep Reflector, great throw distance as well as perfect beam pattern;
● Dimension: 120.6mm (length) x 40mm (head diameter) x 42mm (body diameter)
● Weight: 165.4g (battery excluded);
● High quality aerospace-grade aluminum alloy, Stainless steel head retaining ring;
● Military specification Type III- hard anodized body;
● Waterproof, in accordance with IPX-8 standard;
● Ultra-clear tempered glass lens resists scratches and impacts;
● Tail stand capable- can be used as a candle
● Accessories: Lanyard, O-ring, Holster
Just noticed that it does have a moonlight mode (long click from off). Missed that - it’s among the details of SOS, strobe, Aviation signal, police strobe, which has a tendency to send me to sleep when I read about them.
I would rather have a smooth reflector. As far as lumens, my EA4 is the XM L2 version with 950+ lumens so that is pretty much a push. I like the way the EA4 holds it’s batteries without a battery holder. Probably a better button on this light than the somewhat flimsy button on the EA4.
I do like this style and shape lights that use AA batteries. Probably buy one soon.
Wallbuys has the D40A for $77.58. I asked them to lower the price closer to BatteryJunction, and they delivered. I think the May 15% off code will work too.
I have a review sample inbound (not free, just discounted), but I doubt it will get here before the May sale ends…
Ever since I got the EA4W, I have a thing for them too. They are pocketable (EA4 is a little shorter), good run time, and look nice too. This D40A really looks nice, better than EA4. The button should be more durable too. It’s flush with the host.
I have a primal fear of shearing that EA4 button off when putting it in a pocket or brushing it against something. Looks impossible to replace.
