Match's Mods: 3xXML MagMod - The RogueFlare
32 posts / 0 new
Match
Match's picture
Last seen: 3 years 11 months ago
Good Morning Gentlemen!
  There's a lot of D cell XML mag mods out there, from singles, triples, and more...  I finally got around to completing an idea for a triple XML build on a 2D Mag last night.  As you can guess, I did things a tad bit differently.  Wanting to make a light more compact than the MadMatch, yet still have a lot of lumens, I came up with this design here:
Let's get on with the build...
Designed around the 32mm triple xml-U2 board and CUTE lens from Cutter, along with the reworked head, it's more or less a drop-in.  The only modification that needs to be done to the stock body is to cut away the bulb holder from the switch assembly and remove the acompanying ground strap:
The neat thing about the 32mm triple board is that it seems like it was made to be dropped into a D mag tube.  Now that we have cleared up room above the switch, the next step is to make a BIG heatsink.  I have a penchant for using pure copper (because it works like a champ), so here's a shot of the emitters and what I made to handle the heat:
Once the wires were soldered in place and the heatsink polished up, I used Artic Silver thermal epoxy to hold it in place.  I made an insulated nipple for the positive connection out of an electrical butt-splice, because I had one handy and it seemed to fit (best reason I could come up with). After soldering the positive wire to the end of the butt-splice nipple and epoxying it in place, it turned out like this :
The spring in the second photo above is a cutdown tailcap D mag spring.  It will be used to put pressure outward on the heatsink because this puppy is going to get infinate brightness via QTC.  This way the head can be rotated and set to desired output yet still be activated by the side pushbutton.
  To hold the QTC I reused the little spring cup from the stock bulb assembly.  I lined it with a ring of plastic (again, cut from an extra butt-splice), and set the QTC pad in the center:
In this photo you can see how it will all go together with the QTC cup and the cut down tailspring:
Next comes the modifying the head.  I'll admit here that I wasn't sure how it would turn out, or how I was going to retain the 32mm lens, but figured if it was a failure I could hide all evidence of the attempt and go back to reading Clive Cussler and Stephen KingWink. As you'll see, it turned out ok (In my opinion anyways...).  What I did was mill a stock D maghead down and then make a retaining ring out of stainless to act as the bezel.  Here's how this little idea turned out:
The light golden color is a result of me not paying attention to how hot the stainless was getting on the lathe.  Although after looking at it assembled, I kinda like the mild contrast it offers. It's no FoyBezel™, but it serves its intended purposeWink.
Power comes in the form of 8x14500 LifeP04 westinghouse cells that I got at Walmart setup in a 4Sx2P configuration.  I'm not using popsicle sticks to hold it all together, but still need to finish my battery carrier (Currently made out of stainless rod and poly).
Here's the neat thing... I could cut the body down to slightly less than a 1D size, since I really only need 4 cells to power it.  Runtime wouldn't be the greatest, but would make a more compact package.  I still may do this ( I have an extra D cell body to mangle).
And now onto the finished product, along with a couple of shots with it's 3xpg mini-match sibling:
Final Test Results:
 Since I now have a I.S. to do testing with, the first order of business was with that.  I tried it both with and without the QTC pill installed, just to see the difference. Tailcap draw was 3.3amps:
Max with QTC: 2,733.7L !!
Max w/o QTC: 3,138.3L !!!!
I ran the test a total of 6 times just to make sure, and the results always came back within a fraction of each other.  I haven't tried a single XML U2, but if this is what is to be expected, it's a winner.
(A note about the optics - I had ordered the narrow version of the CUTE 32mm lens, but as you can tell from the pictures, I got sent the wide version.  In talking with them, they wanted me to RMA back that lens, but considering the postage would cost as much as the lens, I'll keep this one and order another...hopefully correct this time).
Beamshots: Last night I ventured back on to the golf course to snap a couple of pics. Distance to far treeline is 130yds (same spot where I tested the MadMatch).
In order of apperance, they are Control, SC60, L2P w/UF XML, and my new triple (need a name for it, guys...)
Control
Zebralight SC60
Solarforce L2P w/ UF 3 mode XML drop-in
New triple xml-U2 build (insert appropiate name here)
What suprised me is that I don't outright hate the wide lens they supplied.  Enough photons are being generated that it still throws fairly well, and illuminates EVERYTHING in front of me.  With the cut down head, this thing actually rides quite well in my back pocket (won't fit in your pocket you say?  Buy bigger pantsTongue out!), and if need be can safely be used to keep ships from hitting the rocky shore.
A quick note about tint:  This was the triple U2-2S bin pcb from cutter.  I'm not sure if you can tell from the above beamshots, but it is much creamier/whiter than the standard T6 affair I've been used to.  The more I play with this thing, the more I like it...a lot!  It's now become my backup light for nightly walks...not because I need it, but because it's just so damn fun to play with.
As always, if you have any questions, please feel free to ask. Thanks again for reading folks, I hope you enjoyed it.
(I'm going to reserve the next comment spot for any future updates)
Edited by: sb56637 on 02/14/2012 - 08:19 Reason: sb56637 replaced budgetlightforum.cz.cc with budgetlightforum.com via Scanner Search and Replace module.
Match
Match's picture
reserved
Don
Don's picture
Last seen: 2 years 11 months ago
Wow!
I love the QTC fitting. That's neat, really neat.
I didn't realise that the Mag head had so much metal in it.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Foy
Foy's picture
Last seen: 4 years 11 months ago
That - is - beyond - cool.  Also, appreciate the trade mark. Cool
And, my name suggestion for this powerhouse comes from the U-2 spy plane that was shot down over Soviet Union airspace May 1, 1960.  The pilot's name incidently, was Francis Gary Powers
"Skunk Works U2 or Skunkworks U2" (or some variation thereof)  It's where Lockheed developed the U-2.
 http://en.wikipedia.org/wiki/Skunkworks_project A skunkworks project is one typically developed by a small and loosely structured group of people who research and develop a project primarily for the sake of radical innovation.
  I think it's an apt description of what you do.
Foy
No referral links and nothing embedded . . . ever.
                      &nbsp
FlashPilot
FlashPilot's picture
Last seen: 18 hours 1 min ago
Another fantastic Match-Mod! What a great idea! The Mag host is about the most robust budget host anyone could ever ask for. I love the idea of eliminating the stock head to make it more compact. Your bezel came out great.
As for the beam shot, are you sure you didnt cheat and switch on a stadium lighting array? WOWWWWWW!
There's nothing like the floodlight output power of a triple XML.
jacktheclipper
jacktheclipper's picture
Last seen: 6 hours 30 min ago
" XXX MatchMag "
srfreddy
Last seen: 7 years 6 months ago
Wait.....you got a quad-bored Mag?
Match
Match's picture
Got? no no..... Made. Pretty easy to do, no sense paying for one.  Regardless, the size of the LifeP04 cells do not require boring.
srfreddy
Really? Because all Nimh do....
jamesearljonesi...
jamesearljonesisascab's picture
Another nice mod to drool overTongue out. Nice Job!
03/04/16
8 lives left
how2
Last seen: 5 years 3 months ago
Call it the Daylight flashlight.
srfreddy
Nup, thats Duracells name.... aw man... But someone needs to make a flashlight as bright as the moon! Gives new meaning to "moonlight mode".
fishinfool
fishinfool's picture
Last seen: 8 months 4 days ago
The "Magnum-Match".
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Don
Don's picture
Midi-Match?
old4570
Last seen: 3 weeks 4 days ago
Well done Match , a superb mod ..  Hmmm , Cutter has the U2 ...  Might have to visit them .
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
jamesearljonesi...
reminds me of the german grenade from wwII Model 24 Stielhandgranate http://en.wikipedia.org/wiki/Model_24_grenade
03/04/16
8 lives left
Match
Match's picture
Heh...that's this one:
To me it looks more like a baton:
Got to play a bit more with it tonight...does quite a number on illuminating night-feeders in an open field! >)
Budgeteer
Budgeteer's picture
Last seen: 6 years 6 months ago
How bout Light Match-ete.
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
raccoon city
raccoon city's picture
Last seen: 9 hours 37 min ago
Good one, Budgeteer!
A light that's so bright, it'll cut through any unnecessary vegetation.
The Light Match-ete!
rzezniq
Last seen: 7 years 5 months ago
You never stop to amaze me Match! Great job!
edc
edc's picture
Last seen: 4 years 5 months ago
You are a Lumen God!
http://i1193.photobucket.com/albums
Budgeteer
Budgeteer's picture
Coincidentally looks jut like a "gentleman" lightsaber.
raccoon city
Q: What's the difference between a gentleman's lightsaber and a tactical lightsaber?
A: Either one can slice your opponent in half in under a second, but the tactical lightsaber's spectacular appearance will instill the fear of the force into your opponent's soul just before they are sliced in half... if used properly.
Budgeteer
Budgeteer's picture
Tactical one is black. Silly Ask Trustfire and FandyFire manufacturers.
Dicky McClicky
Last seen: 8 years 3 months ago
Match
Nice mod!!!
Hows the qtc working out for brightness control?
Do you like it better than the 3 mode switch?
How many amps are you pulling with that set up 9 Amps?
That's my next mod 3 xm-ls.
thanks for the review!!!!
Wink
Match
Match's picture
Mixed results.  After playing with them on a few lights now, I'm having a hard time getting perfect consistancy out of them.  What I mean is, I'd love to engrave the head with marks for 0%, 50%, and 100%, but it seems to change the next time it's rotated.  Like any mechanical system, I think it may be due to minute play in how the qtc cup is mounted.  I'm going to re-address that and see if it tightens up. The problem is travel distance between relaxed and fully compressed is very short.  Also, even at full compression I did notice a slight loss of lumens.  But, that's why we experiment.
Yes and no...again, for the above reasons.
Since the emitters are in series, the total current is ~3.3A.  If I can get away with it, I'd rather run multi-emitter setups in series to ensure proper load sharing.  In parallel, even after matching emitter vf, it's hard to keep them balanced.  Besides, the stock switch should last a long long time at the lower draw.
 Thanks mate, glad you enjoyed it.
Nautic
Nautic's picture
Last seen: 9 months 3 weeks ago
Im very impressed
Cheap quality is good - Expensive crap isn´t
Huny74
Huny74's picture
Last seen: 3 years 10 months ago
Great and impressive work as usual, Match! It's to a not so little part your fault that I am not able to lose my interest in flashlights.
For the name: It's quite an understatement of course but the silhouette reminds me of a Matchstick
uncajesse
Last seen: 2 years 8 months ago
Since your 6x is charmingly nicknamed the "Holy Shit", this would could be nicknamed the "Little Shit".
Boaz
Boaz's picture
Last seen: 8 hours 25 min ago
Sexy as usual..Nice clean design.Since it;s red and looking at the baton I thought of a road flare ..Or a rogue flare .
moviles2
Last seen: 2 years 5 months ago
very nice, you have used 35mm copper bar grinded to 34.3-34.4mm?
dropin
