some crude measurements of the MT-G2 on a Noctigon board
29 posts / 0 new
djozz
djozz's picture
Last seen: 4 sec ago
I have been waiting for a while for people to come up with high current testing of the MT-G2 on copper, and now decided to do some testing on my own, I tested up to 7300 mA before the power supply gave up (not the led). When looking at the numbers below keep in mind that nothing is calibrated, and I do not have the skills and certainly not the accuracy of match or texaspyro, let go something fancy as a integrating sphere. But I will show you the set-up so you can judge the experiment for yourself, at least I am confident that the lumen measurements are within say 5%, for the current and voltage numbers I trusted the readings of my Kert stabilized power supply (which is of reasonable quality) but perhaps not rightly so (please feel free to disagree with the method),  it does give an idea of the performance anyway.
So before giving the numbers, this is how it was done:
The led was reflowed on a Noctigon copper board and screwed tight onto a well flattened block of aluminium with a thin layer of arctic silver in between. The block was clamped onto a larger bar of aluminium. Nowhere during the experiment any significant heating up of the led board was felt, so the heat was transferred away very well, in fact at 4A (=26W) the lumen reading at started at 2156 lumen and stabilised after 2 seconds at 2140 lumen and that did not change anymore.
The led was directly connected to the power supply with short thick wires. In this experiment I regarded the power supply voltage reading therefore a measure of the Vf (and again, please correct me if this assumption is way wrong). The power supply also provided me with a current reading, no idea of the accuracy of that, but i used it anyway Smile. Unfortunately the power supply is rated for currents up to 5 amps, but I was glad it went up to 7300 mA all the same before some temperature/current/or whatever protection shut it off. So no higher current readings sadly Cry.
I placed a 49mm reflector+(non-coated)lens coming from my Trusty Budget Test Throwertm  Wink on top of the led board to simulate an actual budgetlight-real-world-situation  Laughing, it fitted very nicely. So the lumen readings that are given in this post are not led lumens but lumens that could actually be expected out the front of your budget modded light.
The light was directed towards the ceiling to be able to do ceiling bounce lux measurements. This was done the standard djozz way, 77cm from the ceiling, light measured with a Tondaj lx-1010b el cheapo luxmeter, calibrated with a few known flashlight outputs. In favor of the method, the djozz way has given me enough measurements that were close enough to ANSI-values or other people's measurements to trust it within a few percent.
Somewhere halfway during the test run:
The beam pattern on the ceiling, actually not bad at all with this reflector:
A peek at the led at less than 1 mA Cool:
So here are the numbers, again mind that the lumens are simulated OTF-lumens, not bare led lumens:
The fact that the Vf at 7 amps goes up to 7V might indicate that there may still be a voltage loss between power supply and led so the real Vf might be lower, someone better equipped (and less lazy) than me please correct these numbers. EDIT (may, 29th): some other measurements with this same set-up 'may suggest' that the Voltage measurements from this power supply are about 0.15V higher than the real Vf of the led. This would also be more consistent with MT-G2 data from Cree (although you don't really know, Cree's data were at 85 degC, no idea what the led-temperature is in my set-up)
I could not get the graph out of excel (I have to educate myself sometime) so here are the numbers in my original oldfashioned graph:
So what are my own conclusions from this rough and dirty test? Well, to get the most out of it, do not be satisfied with 5 amps for this led on copper, it did not care less for 7.3 A and that does not seem to be the end of it (so who is going to test at 10 amps? Evil )
Edited by: djozz on 05/29/2013 - 10:49
sintro
Last seen: 2 years 5 months ago
Nice work, the 1ma shot is pretty cool. I wonder if stadiums will start using these, you could probably expect a few thousand more lumens too.
ryansoh3
ryansoh3's picture
Last seen: 4 months 1 week ago
Very cool test, thanks for shedding some light on the MT-G2 and taking a risk with high current testing. Glad the LED survived!
Oh, what’s the orange piece of plastic hanging out from the star? Just wondering. Smile
Thanks again!
BLF ≠ B-grade Flashlight Forum
comfychair
comfychair's picture
Last seen: 3 years 8 months ago
Silly me, I was beginning to think that 9A driver I have on the way might be too much! Evil
djozz
djozz's picture
ryansoh3 wrote:
Very cool test, thanks for shedding some light on the MT-G2 and taking a risk with high current testing. Glad the LED survived! Oh, what's the orange piece of plastic hanging out from the star? Just wondering. Smile Thanks again!
Kapton tape, to insulate the leads from the reflector.
ryansoh3
ryansoh3's picture
Gotcha, thanks. I thought it was the same stuff the covered the base of my Noctigon PCB.
Chicago X
Chicago X's picture
Last seen: 6 years 6 months ago
Thanks for taking the time to make this test and publish your findings.
ryansoh3 wrote:
... Oh, what's the orange piece of plastic hanging out from the star? Just wondering. Smile Thanks again!
It would appear to be Kapton tape (or similar) used to avoid shorts from the reflector.
(Edit) Djozz was faster than I at replying.  Smile
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
ryansoh3
ryansoh3's picture
Thanks for the confirmation Chicago X! Smile
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 1 month ago
Interesting test. I would love to see testing on every led in a "real world" situation, say a 3/4" dia x 1/8" thick, round of Aluminum with the led/star on top, instead of huge chunks of aluminum. With the huge heat sink, many things are possible, but with just a small heat sink (like in a flashlight), many things are not possible.
I am not knocking your test. It's good to know what the led can do in "the lab" and I am grateful for your hard work.
Thank you for posting your results here.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
ImA4Wheelr
Last seen: 2 weeks 15 hours ago
Very good info. Thank you very much for the hard work and reporting. This emitter keeps getting more interesting.
MRsDNF
MRsDNF's picture
Last seen: 21 hours 1 min ago
Wow. Thanks djozz.
DB Custom
DB Custom's picture
Last seen: 2 hours 1 min ago
Very nice test, good numbers and well done. Thanks, gives me some ideas…comfychair can be my tester Wink Would love to see 3000 lumens out of my S2200, would be totally awesome!
djozz
djozz's picture
Thanks for all the appreciation for the test, it was fun doing it, I had to close the curtains to prevent strange looks from the neighbours Smile
RaceR86
RaceR86's picture
Last seen: 3 years 11 months ago
This is great info djozz!
Thanks for doing it, and sharing.
7amps and 7 volts.. 49W!! And output is still not leveling out!! Sick! 8)
I know you have good heatsinking here, but with that heat sinking, it sure looks like the sky-is the limit! At least until.. poff.. 0:)
I also take note the djozz-lumens is lower than Match lumens (No surprise, due to reflector, lens and such) But since you had the emitter on copper, the lumen curve does not flatten out as much as the ones Mach posted (his emitter was on aluminium). This just shows that the copper (Noctigon) mcpcb seems to do its job.. Smile Which is good to know…
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
comfychair
Direct drive off two 26650s? Wonder what the current would level off at after the voltage sag...
Hikelite
Last seen: 1 week 30 min ago
The Vfs I measured with my QL-355 on an Aluminum MCPCB (2mm thick) place over an aluminum finned heatsink (70mm diameter, 20mm thick) , 26C ambient temperature.  No active cooling.
Rufusbduck
Rufusbduck's picture
Last seen: 10 months 1 week ago
Nice pics!
Scott
djozz
djozz's picture
Rufusbduck wrote:
Nice pics!
Smile
dazed1
dazed1's picture
Last seen: 2 weeks 2 days ago
Only if this leds where CW….or NW, i hate warm white.
Fenix TK61 MOD> resistor, transistors, copper heatsink, Artic Cooling MX4, dedome, 3A > 5.7A ~ 1700 lumens > (600.000cd)
Hikelite
dazed1 wrote:
Only if this leds where CW....or NW, i hate warm white.
It's not WW.
dazed1
dazed1's picture
Yea but its to yellowish to my liking Sad
RaceR86
RaceR86's picture
Have you seen it real life and not on pictures?
On pictures the white balance on the camera can change any tint to whatever you want it to be. Pictures are rarely an accurate presentation of real life tint.
Hikelite
dazed1 wrote:
Yea but its to yellowish to my liking :(
It's 5000K so it's NW, many like it, if you really like NW than it's like other NWs or better. Maybe you want a "pure white" tint which would rather be considered CW.
dazed1
dazed1's picture
I’m sorry, i saw few videos, and it might be that they where using like <5000K versions, it was alot yellowish then the other leds in the video.
5000K is good, or maybe in the video it was just the camera oversaturation.
Pavlo
Last seen: 35 min 48 sec ago
Any recommendations on MT-G2 replacements? I can see that the LED is falling behind in output and efficiency, but do newer leds like XHP70.2 emit an equally nice beam?
Mike C
Mike C's picture
Last seen: 1 hour 1 min ago
There is for sure considering the amount of options available. I haven’t found one though, for me the MT-G2 is proving to be tough to replace in terms of beam quality.
mattlward
mattlward's picture
Last seen: 51 min 28 sec ago
Mike C, you hit the nail on the head. There are many leds that could maybe be used, but the quality of the light that this one makes in the right reflector is not something that will be easy to replace. The latest generaton of the MT-G2 80 CRI 4000k looks very good when running.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Pavlo
Thanks for the feedback. Where can I buy this 4000k 80cri with good tint?
mattlward
mattlward's picture
Not sure right now… I bought mine, I think, from KaiDomain or Mountain a good while back. They are worth tracking down, if you like the MT-G2.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
