Modding a Trustfire TR-A9 - It's done, Beam shots are Up.
29 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
A little music while you read,
Well you already know I am going to mod the TR-A9. I'm not going to do a whole lot with it. It will have an XM-L2 T6 3C in it, with a DrJones driver and I probably.... maybe....  possibly....   won't drive it too awful hard. I'm not even sure if it will be 4XAA in series or 4X14500 in parallel yet. I guess I will just wing it and see what flies.  I want to make it bright, but manageable and an everyday user.
tra9a1a
Hare's the light broken down to it's basic components. The "pill" houses the led, driver, smd switch and the back side of the driver is the upper contact plate.
tra9a1b
The star is glued down with adhesive, (probably Fujik). The heat sink is aluminum, but I don't think it's anodized. I think it's painted black. I will know for sure later on.
tra9a1c
With the driver off, you can see inside the pill. It's hollow for the driver and it's fairly thin. I will need to work on that a little.
tra9a1d
Driver
tra9a1e
tra9a1f
The back side of the driver board is the upper contact plate.
I worked on the light some more tonight and I also want to show how the heat sink/pill fits in the light and where it makes body contact.
er34r25ht
The pill is in the body.
qwe345y5
Without the body. You can see the areas where the pill sets in. There's three of them (only two shown here). The fourth is cut away more, for the switch.
cxvbv8t
I stripped the driver components and soldered on the pos and neg so I can wire to the new driver. (That's some ugly AA that I gobbed on the solder joints, just before it got too hard).
fhfhuj7876
The contact plates were already modified. If I didn't know better, I would say the original set-up was 4S not 2S/2P. I didn't have to do a thing here.
a9kgerr6
The pill is back together. I added a few grams of metal inside it. Wired up the DrJones driver, with 2 extra chips, so it will be over 3.5 amps and buttoned it all back up.
a98hg568
I didn't change the led, since this is already an XM-L2 and the tint wasn't bad at all in the stock light.
Tested and ready to go...
Tomorrow (today), I can do the cosmetic mods and finish the light. It will now run on 4xAA NiMHS in series.
Here's the finishing shots. The light is done.
a9gl1
a9gl2
a9gl3
a9gl4
a9gl5
That's it. It turned out well and it wasn't hard to do. I used Fujik around the pill so when I pushed it in, it would make better contact with the body. I still think it would be a better light for an MT-G2 than the EA4 would be.
Beam Shots
These are all mouseovers. I used the shots from the original A9 and the modified A9.
The MODIFIED light Photos are Mouse Out  and the Original photos are Mouse Over. The same settings were used in both shoots.
a9mo1
a9mo2
a9mo3
a9mo4
a9mo5
I think I done good. It's brighter than stock. It heats up Fast. That tells me the heat is getting to the body like it should.
That's all Folks.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 06/02/2013 - 23:35
jmpaul320
jmpaul320's picture
Last seen: 3 hours 57 min ago
subscribed!
getting ready for another OL masterpiece Smile
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
Dale
Dale's picture
Last seen: 2 years 3 months ago
Can’t wait to see how this one turns out!!!
relic38
relic38's picture
Looks interesting. Looking forward to the mod.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
Pulsar
Pulsar's picture
Last seen: 4 months 1 week ago
That heatsink is kind of meh compared to what I was hoping. Don't think this is worth dropping $40 plus. Can't twait to see how this turns out though.
Sirius9
Sirius9's picture
Last seen: 2 hours 34 min ago
Pulsar wrote:
That heatsink is kind of meh compared to what I was hoping. Don’t think this is worth dropping $40 plus.
My thoughts exactly, kinda dissapointed..
Old-Lumens
Well considering the wall thickness and how it sits in the body, it's about 10 times more surface area than the EA4.
I'm sure it will come down in price, but I would still rather mod this than an EA4. I will have to take a photo showing how it sits in the body.
Old-Lumens
Updated the OP with more photos. It's almost done.
troisanh
Last seen: 7 months 4 days ago
nice teardown with pictures! you make it look so easy.
georgek
Last seen: 6 years 1 month ago
Is the driver you used a drJones nanjg 105c 8+2 amc’s you added???
MRsDNF
MRsDNF's picture
Last seen: 20 hours 26 min ago
I’ve just finished listening to the video and now you tell me your nearly finished? Are we in some sort off time warp? I’m sure I read somewhere that it was hot and you may take awhile to finish this as you may only get an hour in the morning. Or am I asleep and dreaming?
Old-Lumens
MRsDNF wrote:
I've just finished listening to the video and now you tell me your nearly finished? Are we in some sort off time warp? I'm sure I read somewhere that it was hot and you may take awhile to finish this as you may only get an hour in the morning. Or am I asleep and dreaming?
I like to bitch. If it ain't worth bitchin about, it ain't worth doin.
Besides, it was an easy build and it cooled off after the front moved through.
The light is done now and I will do beam shots tonight.
Dale
Dale's picture
Can’t wait to see the beam shots!!
Slim Pickens
Slim Pickens's picture
Last seen: 3 days 50 min ago
Is the bezel actually SS or just bare aluminum?
I liked the song too. And I’ve never heard it till now :exmark:
jmpaul320
jmpaul320's picture
awesome!
Best wish, May
Tmart service team
Old-Lumens
Slim Pickens wrote:
Is the bezel actually SS or just bare aluminum? I liked the song too. And I've never heard it till now :exmark:
It's SS
blueb8llz
Last seen: 1 day 12 hours ago
i like the looks of this light now. black and silver…oakland raiders color. plus it has a side switch! never even heard of this light till now, looking forward to beam shots.
Old-Lumens
Beam shots are up, in the OP.
Slewflash
Slewflash's picture
Last seen: 1 year 8 months ago
You never cease to amaze me.
Slewflash
relic38
relic38's picture
Nice job O-L, decent gains without changing the emitter!
Welcome the night.
texaspyro
Last seen: 9 months 1 day ago
Old-Lumens wrote:
I like to bitch. If it ain’t worth bitchin about, it ain’t worth doin.
Didn’t I see you standing by the highway with a “Will bitch for food” sign?
Old-Lumens
texaspyro wrote:
Didn't I see you standing by the highway with a "Will bitch for food" sign?
So you're the one that threw the rotten eggs!YellTongue Out
MRsDNF
MRsDNF's picture
Thats quite an improvement. Are you happy with the way its turned out?
JonnyC
JonnyC's picture
Last seen: 6 days 18 hours ago
I saw this pop up on Fasttech.  First thing I did was check BLF, and of course OL has one modded already Smile
This is like the SRK with a momentary switch, correct?  Do you just unscrew the tailcap slightly to prevent parasitic drain?
Old-Lumens
It has a momentary switch, but the tail cap has nothing to do with ground. The circuit is complete without relying on grounding the body. When you have four cells in series, both the positive and negative end up at one end (the top), so the driver/contact plate has both positive and negative in it and the circuit is complete. You can't isolate this light unless you take out the batteries. (in stock form, or modified form).
EDIT: That is why the EA4/8 has a clicky and smd built right into one switch. The clicky shuts it off (isolates) and the smd controls modes.
RaceR86
RaceR86's picture
Last seen: 4 years 1 month ago
Nice mod!
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Bob Loblaw
Last seen: 1 year 4 months ago
How do you remove the reflector? I have the bezel off and the o-ring that surrounds the top of the reflector. Do I need to remove the switch for it to come out?
Old-Lumens
I have slept since then.Wink  I think it just came out by turning the light upside down and tapping it on the table, (with a rag under it for protection).
Bob Loblaw
Got it! It took a bit of careful prying with a small flat head, I think the plastic led centering thing was holding on tight.
