FmC's DIY Handbuilt thread. Finished!!! It's Alive!!!!!!!
61 posts / 0 new
FmC
FmC's picture
Last seen: 6 days 15 hours ago
p=. I'm planning to do a running commentary with this, & will add 'chunks' of the build as I progress. Right.... let's have a look at the beginnings of what may actually become a working flashlight & even look half decent. I really didn't want to buy anything specifically for this build - I should have enough crap around the house to cobble something together. *+The host contenders+* - These were spotted by me whilst sitting on the lounge, drinking a few beers, & watching Top Gear. Up until then, I had no idea what I would use for a host. Image Hosted by ImageShack.us
I currently have no proper work-bench - I have just had a shed built in the back yard, & have not 'moved in' yet. Pretty much all work will be carried out here in front of the PC, or on the back pattio if it's going to be too messy... I have a myriad of hand tools, but most of them are used for building houses, or working on cars... Image Hosted by ImageShack.us
Hmmm... I think I'll start with the bastard file; Top comes off; Image Hosted by ImageShack.us
Push out the guts; Image Hosted by ImageShack.us
This should give me enough room now - just have to figure out how to join them neatly; Image Hosted by ImageShack.us
____ *+Reflector & Pill+* I really didn't want to go with a P60, as it seemed too easy. But making a decent reflector by hand, with _those_ tools - nahhh - I think I'll go with a modified P60 reflector & custom pill. Let's see if it fits to start with... Image Hosted by ImageShack.us
Yep, that'll do nicely. Finally, I found some copper, & a nice chunk of it, too; Image Hosted by ImageShack.us
Just have to get it out of that heatsink first... where did that bastard file go??? Cut down the P60 skirt w/hacksaw, + copper slug ready for a date with the drill; Image Hosted by ImageShack.us
Holes drilled with hand drill - (I know it's sitting there in a drill press vise, but it's the only vise I have available...) + tapping holes for the emitter plate retaining screws; Image Hosted by ImageShack.us
Pill topside looking good, along with the much-hated V10 "5 amp" ramping driver that doesn't really do 5 amps... Image Hosted by ImageShack.us
To house the driver, I'm using one of three brass 'C8' pills that have been gathering dust for a while, seeing as they are yet to actually fit any C8's that I have come across... I filed the top flat, sanded, then soldered to the underside of the copper slug. Image Hosted by ImageShack.us
....which brought me to my first hurdle. & there's no switch in that stack yet either... It may have solved a dilemma I was having; whether to have it open at the center, or at the tail. I _may_ have to take a trip to the hardware/plumbing store...
Edited by: FmC on 08/22/2015 - 17:41
FmC
FmC's picture
*+Body.+* With the last episode ending in a slight hiccup, I ended up doing the 'walk of shame' through the plumbing section of the hardware store, but I wasn't liking anything there; any of the threaded fittings that would allow a 26650 battery through the inside were too 'chunky' in proportion to the rest of flashlight body, & would look too out of place. I must have spent about 45 mins. walking around the store, with a 6" steel ruler that I borrowed from the tool isle in order to measure the fittings. Finally, I discovered -gold- brass in the gardening section in the form of this slim-line, fine threaded hose-joiner; Image Hosted by ImageShack.us
...I also coughed up the $3.90 for the stainless ruler... The brass fitting was sectioned with a hacksaw – at this stage I still hadn't decided how much of it to use. It was difficult to think straight with the drill press mocking & taunting me.... '_use me, uuuussse meeeee..._' Image Hosted by ImageShack.us
The body sections had taken a bit of a beating with all of the work & trial fitting so far, so before joining them, some panel work was required to get the two mating ends looking good; Image Hosted by ImageShack.us
The base of the body was rolled back on itself to give a little more strength; Image Hosted by ImageShack.us
The end cap was soldered to the body by heating up the brass cap with a mini butane torch; Image Hosted by ImageShack.us
Inevitably, the base of the tube took a little heat, but it cleaned up alright; Image Hosted by ImageShack.us
The screw-in cap will still need some work to get the switch into it...maybe next weekend... I decided to go with the stream-lined body, rather than having an external joiner, so I rolled up some of Racr86's left-overs from his build & used it as an internal sleeve, epoxying the two halves together; Image Hosted by ImageShack.us
Everything will load in from the tail of the light, & eventually be sandwiched together. *+Additional Pill/Heatsink work+*; To help the heat distribution & transfer to the body, I added a 1mm (.040") copper sleeve to the pill. The assembly is now a tight fit into the body tube. Copper sheet; Image Hosted by ImageShack.us
Rolled up; Image Hosted by ImageShack.us
Soldered to pill; Image Hosted by ImageShack.us
The sleeve also keeps the battery nice & centered. ***A big thanks to Steve from work for providing the copper plate*** Beer
FmC
FmC's picture
*+Switch Assy+*; The threaded fitting was cut down, allowing for a recess for the switch to fit into; Image Hosted by ImageShack.us
Attached some solder wick to the brass, then to one of the legs; Image Hosted by ImageShack.us
Finished switch assy., epoxy'd in place; Image Hosted by ImageShack.us
*+Components+* Here's everything all laid out; Image Hosted by ImageShack.us
*+Assembled torch+*; Image Hosted by ImageShack.us
*It's alive!!!* Image Hosted by ImageShack.us
Some outdoor beam shots; Low; Image Hosted by ImageShack.us
Medium; Image Hosted by ImageShack.us
High; Image Hosted by ImageShack.us
Lux reading @ 1m; 123k Tools used; * Hacksaw * Bastard file * Hand-cut file * Hand drill for pill holes * Hand tap for pill threads * Mini butane torch for soldering the bigger pieces * Soldering iron * Vice * 220 grit sandpaper * Scissors * Hammer * Screw driver * Socket extension for rounding edge ...I think that's all of them... Thanks for reading!!
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 2 months ago
Holy Shite! That is just Awesome!
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
MRsDNF
MRsDNF's picture
Last seen: 6 hours 26 min ago
As OL said. Now thats thinking outside the box. Very impressive start.
Foy
Foy's picture
Last seen: 4 years 10 months ago
I'm going to tell you right now, this is damn cool and I am very interested to see how this turns out.
Foy
No referral links and nothing embedded . . . ever.
                      &nbsp
ryansoh3
ryansoh3's picture
Last seen: 19 hours 48 min ago
So cool that Foy had to repeat himself three times. Big Smile
BLF ≠ B-grade Flashlight Forum
relic38
relic38's picture
Last seen: 2 years 1 month ago
Awesome idea FmC! You are way ahead of me. I will not even get started this week. Sad
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
michaeljee
Last seen: 6 years 8 months ago
Nice surprise about this shorter form. Can you tell us what it is you are talking/writing about?
Has any info. about this shorter form been posted before (and i just missed it)?
FmC
FmC's picture
Thanks for the comments.
I got a little more work done on the pill assy., will update the build log later today.
mattthemuppet
Last seen: 1 day 8 hours ago
wow, that’s some out of the box thinking going on there!
A sleeve with some kind of twist and latch/ peg’n‘hole set up might help join the 2 halves together and allow you to change the battery. The solution to the switch mystery is going to be interesting Big Smile
PyTech
PyTech's picture
Last seen: 1 year 3 months ago
Wow! great stuff
-Sean
Slim Pickens
Slim Pickens's picture
Last seen: 1 day 23 hours ago
Great start!
Buwuve
Buwuve's picture
Last seen: 2 years 9 months ago
This is a great idea. A battery body. Can't wait for more Smile
Light up the darkness.
blueb8llz
Last seen: 3 hours 33 min ago
very unique and cool factor.
FmC
FmC's picture
Thanks guys.
mattthemuppet wrote:
A sleeve with some kind of twist and latch/ peg’n‘hole set up might help join the 2 halves together and allow you to change the battery….
Yeah, I was thinking along those lines, unless I can find a threaded solution that is thin enough to be inside the ‘body’, yet still have enough i.d. for the battery to pass through.
Rufusbduck
Rufusbduck's picture
Last seen: 11 months 1 week ago
Clever!
Scott
totilde
totilde's picture
Last seen: 1 year 3 weeks ago
I’m amazed of the nice builds I’m seeing this week, the idea of the contest was great!
Mooooooo
FmC
FmC's picture
I may have sorted the length problem & the tailcap assy. at the same time.
2nd post updated.
MRsDNF
MRsDNF's picture
I hope you got a discount on the ruler as it was used. Its amazing what you can find if you look hard enough. The nuts even come complete with knurling. Now thats got to be worth an extra couple off points.
troisanh
wow you guys cant stop to amaze me with your ideas!
panthervision23
Last seen: 6 years 1 month ago
The part that amazed me the most is the way you modified the batteries. J)
FmC
FmC's picture
Done a little more work this w/end, not as much as I would have liked, due to family commitments.
2nd post updated with new progress.
MRsDNF
MRsDNF's picture
Coming along nicely FmC. It looks like coke cans are the flavour off the month in mods.
mattthemuppet
that’s some very neat work you’re doing there! Coke can’s are awesome, they’re useful for all kinds of things.
relic38
relic38's picture
That is looking quite nice! Great job FmC. Maybe I should start my build soon…
Welcome the night.
Rufusbduck
Great find on the brass. I can hear it now “ can I help you sir?”, “no thanks, just looking”. No idea how many times I’ve wandered the isles looking for “I don’t know what”. Borrowed my share of tape measures too.
Scott
MRsDNF
MRsDNF's picture
I’d suggest to find another shop if they don’t supply customer service. Whoever heard off a plumbers supply not helping you find the fitting that’s just right to build flashlights with. Whats happened to this world. Unbelievable.
Still watching. Smile
relic38
relic38's picture
Mine went something like this:
“Can I help you sir?”
“Yeah, I’m looking for a threaded adapter in copper that I can use for a flashlight head”
[blank stare] “OK, well everything we have in copper [starts backing away] is in this aisle, so if it’s not here [raises voice due to distance] we do not have it.”
“Sure, no problem, thanks!”
After that, now I just say what RBD says Big Smile
Welcome the night.
Rufusbduck
Yeah, lesson learned. Now I put on my stupid face and say “nope” whenever they ask. I like the way this is turning out and the tricks you use.
Scott
texaspyro
Last seen: 7 months 2 weeks ago
When I get asked that question, I just start drooling and twitching and blurt out “they have tried…”
