Pulsars DIY 2013: handmade
29 posts / 0 new
Pulsar
Pulsar's picture
Last seen: 3 months 6 days ago
Ok. I’m at work and it just came to me. It’s going to be an angle light with a twist. I’ll post some pics when I get home from work
____________________
now let me try to make this post an actual build thread:
this is what i got so far.
its going to be an angle light made from copper pipe and brass fittings.
the on/off switch will be on the back side of the elbow for activation with your thumb
its got a 3” reflector from a cheap rayovac lantern
think im going to put an xml, direct driven in it
either going to run it off a 3xAAA carrier, or sleeve the tube for an 18650
dont have much done yet, but here is the concept
ruffles was kind enough to search for some copper rod for me while at his metal dealers yesterday, so i should be starting on a heat sink soon
thank you ruffles!
things to come:
working on smoothing out the cast bronze parts and polishing. not easy with out a dremel
heat sink should be started this weeken
Edited by: Pulsar on 06/13/2013 - 05:13
Pulsar
Pulsar's picture
reserved for beam shots and such
Pulsar
Pulsar's picture
reserved for kreisler quotes... cuz that guys bad@$$ and i want it preserved like jams and jelly Tongue Out
moderator007
moderator007's picture
Last seen: 33 min 48 sec ago
Reserved for when pulsar finally figures out what his going to do. Big Smile
And I figure out what to say. Shocked
Pulsar
Pulsar's picture
moderator007 wrote:
Reserved for when pulsar finally figures out what his going to do. Big Smile And I figure out what to say. Shocked
i have 4 distinct ideas, ill decide which is most feasible tomorrow when im a little more sober lo 8) l
Rufusbduck
Rufusbduck's picture
Last seen: 11 months 2 weeks ago
Do you think I look at mine and think “feasable”? Lol. Pick the crazy one. S)
Scott
Pulsar
Pulsar's picture
was sitting at work today, thinking of what i can do… and this was sitting right in front of me on a t bar. now this will probably not be what is actually used for the host, i dont think the components will handle me soldering the joints on these. but it was the inspiration
the question is….
mild…
or wild…?
i think i will go with wild!!! got too think up a head to use on it. going to come up with some kind of switch on the elbow for thumb activation
i think this is going to be a heavily driven xml, maybe 4+ amps. will either be a single 18650 or 26650
Rufusbduck
Looks like plenty of head but short on tail.
Scott
RaceR86
RaceR86's picture
Last seen: 4 years 4 days ago
Nice!
I would try to work on the “mild” one.. “Wild” looks a bit out of proportions to me..
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Pulsar
Pulsar's picture
its 1" od heavy wall copper 3.25" long. when i figure out what im going to use for the head, im going to design it so there is clearance for my fingers behind the head. its just a concept at this point. im going to have it so my hand will fit perfect between the elbow and tailcap.
besides, dont you guys know by now i like small bodies, big heads?
RaceR86
RaceR86's picture
Pulsar
Pulsar's picture
thats a heat sink made for a c mag that allows the head to still focus. im not going to be using it (though its almost perfect). just there to hold the reflector up to get a visual
ill be trimming the lip off the reflector, and probably try my hand at a copper heat sink with pedestal. this weekend i will probably be going to the hardware store to look for threaded fittings, unless i think of a scheme to solder the fittings with out killing the electronic components.
now i just got to figure something to use as a head, or may be get a sheet of copper and make one…
ps: i could have pressed the tabs down and turned until the cows came home.. it was also glued… i cut the tabs off with a razor knife and lightly pried up with a flat head all around the reflector to break it loose.
now that i finally harvested the reflector out of this sub $2 host, maybe i can do an active cooled multi in it someday
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 2 months ago
If there's a way to solder before you put the components in... but if not, then you are right, threaded fittings are the way to go.
Hobby shops usually carry sheets of copper and maybe even brass. It's usually .010" or .020" thick sheet, I believe.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Pulsar
Pulsar's picture
So I figured out the head... With the lip trimmed off, the reflector is 3", so I will use a 3" end cap to start with, then get a sheet of copper to form the cone of the head shape...
I'm also thinking of just direct driving it, but not totally sure.
Also... Anyone reading this happen to have a piece of copper rod about 2" or so long? If so I'd like to buy. I'm not sure where locally I can buy it.
edit:  1" copper rod is needed
Pulsar
Pulsar's picture
found what the head will be made from
http://www.ebay.com/itm/170994689579?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
just want to give it a day or two to see if anyone here knows where to get one cheaper, or maybe has access to them cheaper from work or such
also on the lookout for a piece of 1" copper round stock about 2" long so i have 2 or three tries to mess up a heatsink
looks like the elbow and end cap i have are cast bronze... been working on filing down the porous surface to polish them up. with the motor cooked in my rotary tool, going to be time consuming
MRsDNF
MRsDNF's picture
Last seen: 15 hours 26 min ago
That is one massive reducing bush along with a massive price. I hope you find something a little cheaper.
Pulsar
Pulsar's picture
oh trust me, me too.
i was going to use a 2"x1" reducer and a 3" end cap, but that 3" end cap is $20 alone... i did not factor in the price of copper and how much of a broke @$$ i really am when i was planning this. oh well... i have $45 left on an ebay gift card i was saving for something special. if i cant find something in a few days ill order up the 3"x1" reducer and hope i win the loot Cool
MRsDNF
MRsDNF's picture
i was going to use a 2”×1” reducer and a 3” end cap, but that 3” end cap is $20 alone… i did not factor in the price of copper and how much of a broke @$$ i really am when i was planning this. oh well… i have $45 left on an ebay gift card i was saving for something special. if i cant find something in a few days ill order up the 3”×1” reducer and hope i win the loot Cool
Pulsar needs help. Is there any generous BLF plumbers in Pulsars area that wants to donate to a good cause? I hope Pulsar doesn’t mind me posting this.
Pulsar
Pulsar's picture
Nah I don't, bit I think this really is a specialty item that's not used often. I'll give it to Saturday maybe, then I will just order the one off eBay
jfalk1
Last seen: 5 days 47 sec ago
or does it resemble a medicinal pipe..like they have out here in CA?
Pulsar
Pulsar's picture
Not just you... But please don't smoke from copper lol
Rufusbduck
Good luck with the copper. I just make my own slugs from layered pieces of pipe and fittings. Some nice builds in this contest and they’re all creative.
Scott
Pulsar
Pulsar's picture
got some heat sink material, thanks to ruffles.
i sprained my ankle at work friday, and went in today and they want me on crutches and stay out until wens, most likely without pay. need parts for my car… so most likely wont be getting the 3” to 1” reducer… got a 2” to 1”, and a cutter reflector i will make work for now. maybe later in the month i will have the money to buy the reducer to use the reflector i originally wanted
and thank you DBCstm for the reflector, he mailed that out a while ago to try in a mag mod
i filed the lip down to sink the reflector into the “head”. i need to shorten the female connectors on the elbow and the reducer to make it look proportionate. lots of file work and polishing.
got a piece of copper pipe that fits inside the pipe i have already that is a perfect size for an 18650 spacer. i will cut it to length and solder it inside the other tube. thats also going to leave a lip for a positive contact plate to seat on
ohaya
Pic not working…
DB Custom
DB Custom's picture
Last seen: 50 min 43 sec ago
Can’t wait to see how this progresses, the reflector should give a nice output, we’ll see!
And yeah, I was thinking that that bowl was huge! lol
Pulsar
Pulsar's picture
yeah, that reflector does make a nice beam. should progress quicker now that i have most materials to work with. need to figure out a bezel/lens retainer
relic38
relic38's picture
Last seen: 2 years 2 months ago
Hey Pulsar, any progress? I have a feeling the M6 group buy has been eating into your time.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
Pulsar
Pulsar's picture
yeah. not going to have it finished... im a slacker.
ill still build it, but wont be done in time for the contest
relic38
relic38's picture
Bummer. Still looking forward to seeing it finished though.
Welcome the night.
