DNF's Entry To OL Comp. 7.7.13 (7.7.13) Done and dusted.
66 posts / 0 new
MRsDNF
MRsDNF's picture
Last seen: 7 hours 34 min ago
I'm stealing this idea from a certain gentleman here. This is my place to go that I'm lucky enough to be able to visit and forget about the real world. No mains power, internet or mobile phone reception. It really does not get any better. So sit back and chill with a favorite drink and I hope you enjoy the build.
Unfortunately there is nothing new in my build but I will try and incorporate a forward switch which I haven't done yet. As most off you are aware I have a plastic friend holding me back at the moment so will do what I can when I can.
I'm just glad I'm not in hand built as those guys have some crazy ideas that they are actually building. Orsm effort guys.
And finally with the final waffle thanks to OL for having the audacity to put this build off on. What I've seen so far is really inspiring. Cheers all.
The parts that may or may not change. 26650 battery, IOS 4 amp driver with 55 thousand modes, XM-L2 cutter led, copper star, FT switch rubber, C8 lens full of grit from memory from FF, FT switch and a lens I just realized was missing.
Theres still not a lot happening here so I thought I'd show you some off the tools that will be used in this build. Firstly is the drill press. This is a cheap brand that I bought second hand about 25 years ago. I use the stand to store short lengths off steel.
My measuring tools. I do have micrometers but these digital calipers are used 99.9% off the time and are more accurate than I am.
My Lathe. Its 40 inches between centres and has a 1 1/2'' spindle. Its B section v belt driven with back gears for the slower speeds. I bought this brand new as a younger guy in 1982 when I was in my last year as an apprentice fitter and turner.
The V belts have been replaced once and well over due again. To replace this belt the whole spindle has to be removed which is not a 5 minute job which is why I have put off doing it.
One handy but rarely used option I bought with it was a milling vice attachment. It goes on in place off the tool holder and is only held on with 2 x 8mm capscrews. To say the least its not very rigid hence the reason it does not get used much. The end mills I use are usually old drills ground with a flat end and held in the three jaw chuck.
Heres a few off the tools which will be used. A parting off tool which again does't get used much as my lathe is not sturdy enough and an internal tool I use for cutting grooves for o'rings etc. It also gets used as a small boring bar when necessary.
And finally. Most tools I use are ground from 3/8'' tool steel. My tool holder I made when l first bought my lathe with the milling vice and a flat ground 3/8'' drill bit. The long tool on top is used for internal 60 threads. The middle tool is for external metric threads and the right tool is used for external o'ring grooves and parting off. There are a dozen others ground up in lots off weird and wonderful ways for lots off uses.
Its another 10 days before I have any chance off my plastic friend departing my left hand. There's still 6 weeks left in this comp isn't there?
The design is complete, nearly. This will give me a starting point and I will build from here. l have a very rough idea what it will look like finished.
Sorry I lied. I have no idea what it will look like finished. This may just make a good paper plane.
The machining has started. The aluminium bar started of with measurements of 45mm OD and 25.5mm ID.The first picture shows the internal thread cutting after the internal machining had been completed.
This picture did not turn out very. This is a shot off the inside with the machining finished. The ledge at the rear is 80mm from the front. The switch housing will butt up against this when its inserted from this end. There is a circlip groove 25mm back from this ledge which will hold the switch housing in.
The next step was to machine the thread for the bezel.
The form off the light is starting to take shape here. The outside was not designed at all as most off you know why. The light will have a one piece tube for the reflector housing and battery tube. The only other parts externally will be the tailcap and bezel.
The all important cooling fins are next. These have been designed in a wind tunnel with photons shot at it at mack3 with an MTG-2 led running at 25000 amps shone at it to design the most efficient cooling fins possible. These fins may look just like any other light but in reality will cool better than the light being run in a freezer.
Finally for today, the material is moved out as far as I dared in the chuck (the material I started with was this length without me cutting it) with the reflector end centered with a home made pipe center. This step is the battery tube being machined down to size.
Time for another update. This nearly ended in tears this morning when I was trying to fine tune the plastic switch insert, switch and pins outside in the fog this morning (still more light outside) when I went back into the shed for a blade and came back out to find the switch gone. Noooooooooooooo. Looking around one off the dogs was chewing on something. Yep, it was the plastic switch block. Luckily no damage was caused but one of the pins I had just soldered the wire into and had it sitting in the block was missing. Going into instant panic, as it had taken quite a while to make and I had no material left, I started looking. Again luckily l managed to find it, surprisingly without the wifes help (she was at work anyway) and no damage had occurred. To be honest I dont think I will build anothere switch like this again. Not with a one piece housing anyway as its just to fiddly.
This is the milling vice at work making the switch block and using a drill bit as an end mill.
What it looked like after what felt like about 6 hours.
Dummy assembled.
And finally fitted inside the flashlight housing.
The bezel is made from a piece off scrounged brass. Problem being I don't have any to make a tailcap with. I'm not sure what I'm going to do there yet.
The pill is massive which is made from copper. This light will end up weighing as much as a brick. Thread size is 30mm. Driver diameter is 17mm and the depth of the hole for the driver is 11mm.
Nearly done. I may get disqualified for this build as I cheated on the tailcap. I took some homage from the hand built lights and visited the local plumbers  in desperation for some brass coming away with this. A 1'' BSP cap. Its not correct but I will explain tomorrow in my summary. This hurt.
There was not enough material left on the head of the light to hold it while the tail end was being machined so I made a split bush to hold the body in the chuck and a large taper adaptor to go over the live centre to steady the light.
I did not want to use knurling on this light and spent a lot of time wasting material to come up with this design. Each individual groove suits my fingers holding the light. It does not work for Mrs DNF.
Mrs DNF left for the afternoon so I could use the stove without getting in trouble. The two pictures are before and after.
Thanks to OL for answering a question I asked for me being able to solder the spring in neatly. This has since been changed but soldered in the same way.
A picture of all things copper and brass.
The finished one piece housing.
A couple off pictures showing a stock C8 weight and the weight off the pill alone in this light.
And finally a family portrait all the parts that went into this light.
Some night shots. Firstly a C8 running 3 amps and a XML-U2 cool white led that is not quite as bright as the XinTD V3.
EA4W U2 on turbo.
And finally this light running here at 3 amps with a filthy reflector that would not clean up and an XM-L2 T6 0A.
Mouse over this light. Mouse out C8 XML-U2 cool white. The tint on this light should be nearly blue but comes out a lot warmer than the XML-U2. The spill is also a lot bigger on this light contrary to what the pictures appear to show. The reason for this is that the hot spot on this light is a heck off a lot brighter drowning out the spill.
An awkward hand shot showing the finger grooves in action.
And lastly a couple off pose shots.
Summary.
I did run times on this light to test for efficiencies. My measurements dont relate to anything but this light. Ambient temperature was 19 degrees C. My educated guess was the light never got above 55 degrees C. The whole light pretty much heated up over the whole length. With a ceiling bounce test run over an hour the initial reading was 32 lux which pretty much dropped in a straight line to 24.1 lux. After letting the light cool down to room temp it was again switched on with an initial reading of 24.8 lux dropping to 24.1 after 10 minutes. I dont believe that heat is causing the light output to change much at all. This driver will eventually be changed for a 7135 driver with a couple off extra chips added and a new reflector fitted.
The light itself to me was a challenge to build for more than one reason. Normally I just build a light. This time I tried to style it and spent far to much time trying to make the light look right. Machining a mm here and there and putting grooves here etc etc. At the end of the day I'm as good at styling as I am at soldering.  The forward switch was another challenge which I thought would work perfectly with this driver. For some reason the driver puts out 3 amps at start up and gradually drops off with voltage. The other six hundred and fifty five modes are not there. Well they probably are but there not coming out to play. The switch though works like a dream. Yes I am a fan.
My search for the elusive piece of brass was in the end mistaken. When polished up the bezel and tailcap where different colors. Foolish me. The material I thought was brass I made the bezel from was bronze. So it has an aluminium body, bronze bezel, copper pill brass tailcap and ended up with a weight off 340 grams.
Thanks for reading guys and again thanks to OL for putting this event on. I'm excited about what else will be machined up from my fellow rivals and as mentioned a couple off times blown away by all in the hand built category. Well done fellas and thanks for showing us your talents.
Edited by: MRsDNF on 07/06/2013 - 22:54
T.H.Cone
T.H.Cone's picture
Last seen: 1 year 1 month ago
You had me at “free plug”. Smile
fidem, prae caeteris omnibus praeter honestatem
Don't be confused, my Username has been changed from "Cone" to "T.H.Cone".  I'm still the same clown.
RaceR86
RaceR86's picture
Last seen: 4 years 2 days ago
Looking good so far! And Im not only talking about the view. Wink
The skills required to make a nice light on a lathe seems to be highly underrated lately. It takes a lot of skills!
Also, most people don’t do excuses. All us who hand build can usually say something like.. “oh, its handmade, those imperfections just add character and soul”.. Big Smile
I think its a very good valid excuse in some cases though.. 0:)
I can honestly say that I don’t have the skills to do a lathe build. So I will stick to handmade.
Im just as exited to see what the machine guys are able to put together as what the hand-made guys can do.
We are all just having fun making lights!
That is what its all about.. Beer
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Pulsar
Pulsar's picture
Last seen: 3 months 4 days ago
RaceR86 wrote:
The skills required to make a nice light on a lathe seems to be highly underrated lately... :beer:
i was just poking fun in the OL thread. i know it takes skill to use a lathe, thats why i stay away from them. im just jealous lol.
to be honest, so far there are a lot of cool handmade threads going on... but i really can not wait to see what the machine made guys come up with.
Rufusbduck
Rufusbduck's picture
Last seen: 11 months 2 weeks ago
Pulsar wrote:
RaceR86 wrote:
The skills required to make a nice light on a lathe seems to be highly underrated lately… Beer
to be honest, so far there are a lot of cool handmade threads going on… but i really can not wait to see what the machine made guys come up with.
+1. I’m poking fun everywhere but it really is fun seeing what gets thought up and the work arounds used. As more of the mods show up the reading will get even more fun.
Scott
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 2 months ago
OMG, that Scenery, must be somewhere in Australia? Surprised
I am glad to see you getting things together. Whatever you do, when you take the plastic off early, don't tell those nurses, or you will be back in plastic for another six weeks...
I'm looking forward to the lathe work.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
MRsDNF
MRsDNF's picture
You do want your nails done yes? Maybe it would be more suitable for Mrs cone. Shes doing a face painting course at the moment to expand her horizons.
I agree 100% with your thoughts RaceR except one. Believe it or not (violin starts playing) I’m not bad with hand tools as well. There is more skill in using hand tools than a machine. I’m like you and getting a buzz from the wild to mild.
I am glad to see you getting things together. Whatever you do, when you take the plastic off early, don’t tell those nurses, or you will be back in plastic for another six weeks…
I’m looking forward to the lathe work.
I kick myself everytime we go there. Theres an extremely large lake which you can only just see. The waters down at the moment. For 20 years we have been trail bike riding, skiing and generally larking around at this property. I learnt along time ago to do what the nurse says. Angry nurses scare me.
mattthemuppet
Last seen: 4 days 16 hours ago
srsly, if your plastic friend is holding you back, just deflate her and put her back in the box she came in Smile
looking forward to the build!
MRsDNF
MRsDNF's picture
First post updated.
djozz
djozz's picture
Last seen: 12 min 26 sec ago
Nice to see your tools and workshop, and I am jealous of your empty country. Looking forward to your build. Mine is still waiting to begin, have to finish lots of little jobs in the house before the hobby can resume...
Rufusbduck
Thank you for taking the time to show us your tools. Don’t know what the doc will say but if that were my plastic friend I’d wear it while working (at least for a while) to protect the new tissue and work on mobility without strain. Range of motion exercises (mild stretching)induce the scar tissue to develope in long more elastic fibers. Overwork causes micro tearing that turns into knots that could ruin the outcome. Please put your recovery first. You only get one shot to do that right. When I wrecked my left hand I was off work for 7 months, 2 surgeries( first to push the bone pieces in the two middle fingers into line and pin them and the second for a bone graft replacement from my hip) plus months of therapy to convince a lot of scar tissue to act like normal flesh. Do whatever they say to get it right and at some point they should be able to tell you to cut loose and really start to work it. 8 months after the accident I went up for my first block attempt(volleyball) and though it hurt, nothing came loose and I was able to really push it again. Best regards and hopes for a good outcome.
Scott
MRsDNF
MRsDNF's picture
Thanks Mr duck. I cringe when you mention your hand. Yeah I’m a bit paranoid but without going into detail I have a freind who received serious injuries on a lathe. Hence the hesitation of using it when I’m not right.
This little old country here is filling up. Just dont ask me with what. Cheers guys.
ruffles
ruffles's picture
Last seen: 2 days 10 hours ago
Nice toys, er, tools. Any chance a link belt would save the trouble of tearing the machine apart? Link belt
(I was using one of these on my drill press, so not exactly your application, but I think it would work at higher speed.)
MRsDNF
MRsDNF's picture
Thanks ruffles. Yes I do have one ready to go on but . I’ve never used one before so was waiting for the tattered one to start slipping badly or break first.
MRsDNF
MRsDNF's picture
Finished design added to the OP.
ezarc
Last seen: 7 months 1 day ago
Looking forward to seeing the end product, good luck.
texaspyro
Yeah, and it uses lithium batteries… do you perhaps work for Boeing? J)
MRsDNF
MRsDNF's picture
Machining has started. Pictures in the OP.
ImA4Wheelr
Last seen: 2 weeks 5 days ago
Always love getting to see your work. Best of luck with your build.
MRsDNF
MRsDNF's picture
The switch ass has been completed. Pictures in the opening post.
Old-Lumens
Too many Pills...Frown
  Oh Noooooooo Mister Bill! Smile
Sounds like you are having too much fun with this build. Good to see you out and doing something.
Rufusbduck
I’m down one switch on mine. Went to see a man about a horse and gremlins took it. Spent two days looking but no joy. Fortunately I bought two. Looking good, I like the piles of long shavings and the JPL fins.
Scott
MRsDNF
MRsDNF's picture
Sorry OL. I still love Maxwell Smart after too many years. It’s still on here all the time. Maybe thats where the BS comes from. Smile Loopy Lucy with the shifty paws was the culprit.
Sorry about your lost switch mr duck. Its a bugger losing things hence the reference to Mrs dnf. She can usually find things quickly. I recall you losing a lens or reflector not long ago. Did it ever turn up? Maybe there colluding together somewhere in a dark corner about turning you nuts (or nuttier)?
Steve_the_Chief
Steve_the_Chief's picture
Last seen: 10 months 3 weeks ago
To find small objects on the ground, I put a strong flashlight down on the floor and shine it horizontally around. Even the smallest objects throw long shadows that way Smile
MRsDNF
MRsDNF's picture
Thanks Mr chief, unfortunately it was outside on the grass. Fortunately I did find it. Smile
gords1001
gords1001's picture
Last seen: 1 year 8 months ago
if I need to find something, I take off my socks and shoes…this works best of the iten is either a piece of lego or a hairbrush or english 13a plug.
texaspyro
I once found a TO3 power transistor (with the pins pointing up) that way… |(
MRsDNF
MRsDNF's picture
Bezel and pill added to the first post.
relic38
relic38's picture
Last seen: 2 years 2 months ago
That pill looks awesome! Nice work! The bezel is looking good too. Would be real nice if you can scrounge another brass for the tail end.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
MRsDNF
MRsDNF's picture
Thanks relic38. I’m trying. Got another guy trying to get me an off cut from anywhere.
TexasLumens
TexasLumens's picture
Nice Work MRsDNF!!  I like that Brass Bezel... the Copper Pill... the...the... I LIKE IT ALL!!!!
Danged nice work!Wink
Texas Lumens Website… http://www.texaslumens.com
WE LIVE IN THE LAND OF THE FREE ONLY BECAUSE OF THE BRAVE!
