Hi Guys,
I’d like to introduce you to a brand new product, our very own Mini USB Li-ion Battery charger. This charger was in the works for about 2 years, but kept being put on the back burner (due to other projects). I designed and had the circuit boards made up over a year ago, just never got around to putting some together and listing them up for sale! These are quite time consuming to make due to the tiny enclosure they have to fit into. Well, they are here and they are sweet little chargers! Laser engraved aluminum case, CC/CV charging IC with 500mA charge current can charge most cells out there! I tested IC’s from 3 different companies, and also found most of the IC’s from China were fakes, and performed poorly, so I bought all the IC components from the USA. I also found most of these IC’s when you connect a battery backwards, the charger literally smokes and burns out the IC. So I built in reverse polarity protection. The PCB is assembled in China, the final soldering of the wires, alligator clips, thermal compound application and enclosing the unit in the aluminum case is done in the USA! Enough talk, now onto some more details and pictures!
Features & Specifications:
- CC/CV (Constant Current / Constant Voltage) Charge Method
- Thermally Regulated (automatically reduces charge current if needed )
- IC is heatsinked to the aluminum USB case for maximum performance
- Works on any 500mA capable USB port (99% of computers)
- High Charge Accuracy (4.20v ± 0.03v)
- Reverse Polarity Protection
- Short circuit Protection
- Soft start charge current for overdischarged cells (10%)
- ~40mA charge termination current (CV stage)
- Blue LED indicator turns off when charging is complete
Description:
The Redilast Mini USB Charger is a full featured USB powered CC/CV Li-ion battery charger. The charger with the included magnets can charge a variety of cells of varying sizes and capacities including: (14430, 14500, 14650, 16340, 16650, 17360, 17500, 17650, 17670, 18350, 18500, 18650, 18700, 26650 etc). Only charge cells with a capacity of 500mAh or greater, or you will exceed the recommended maximum charge current of most Li-ion cells which is 1C.
The standardized USB connection allows charging in a variety of locations: from a desktop computer, AC outlet USB power supply, USB 12v Car charter, solar panel or even from a portable laptop or power bank. This versatility makes this charger the ideal choice to take with you on the go.
Approximate Charge times:
RCR123 — 1.5hrs.
14500 — 2hrs
17500 — 3hrs
18500 — 4hrs
18650 — 7hrs
26650 — 10hrs
*Depends on cell capacity, state of charge, and power source.
Pictures:
Introductory price of only $19.99!
Also: Order $80 or more of Redilast batteries from edcplus.com, and mention “USBCHARGER” in the order, notes and we will send you a charger for FREE!
