Lumintop SD10 1D cell flashlight
Anybody know any more about this light? No info on it yet that I can find, but It seems like it might be a neat light to have. Would definitely make a good power outage light. I originally saw this posted over on CPF and thought I might see what I can find out over here as well.
Lumintop SD10
Thats weird that it doesnt give any kind of information…
from the pictures, it suggests that it works from 1.5v to 4.5v starting voltage, kind of cool but depends how good the driver is really
Ohhh This I’m looking for!!!
1 = AA , C , D , 18650 , 26650 , 32600/32650
3 = 3xAA , 3x14500 with my parallel adapter :wink:
The AA carrier looks like the bad one used on all cheap 3AA flashlights.
Unless the battery carrier is set up to run them in parallel. Hopefully some more info will surface.
The carrier is the common cheap carrier which is a series configuration, just look at it, 2 springs on side 1 on the other.
You’re right. I just enlarged the picture and noticed the and - symbols on the top of the carrier.
thats why I said 1.5v to 4.5v………
1d =1.5v
3aa series (could even be 3aaa) = 4.5v
li-ions fall in between, its going to depend how good the driver is and as pointed out, the battery carrier does look like the cheap poor carriers.
there’s also been to my knowledge, not one decent output 1.5 - 4.5v driver in a budget light.
Finally got some info on it. It’s only 200lm with a D cell, but with a 7.2 hr runtime… I could live with that.
Description
SD10 is one of the world’s smallest, lightest and brightest 32650 searchlight. It is compatible with a wide range of batteries through intelligent control, and thus it has different outputs based on different battery types. It ensures not only enough brightness but also product stability and long runtime. With premium CREE XM-L2 T6 LED, its output reaches up to 800 lumens.
Construction:
  1. Coated tempered window resists impact.
  2. Aerospace aluminum uni-body design combined with a stainless steel retaining ring offers superior impact resistance. Mil-Spec hard-anodized. O-ring Sealed.
  3. Front side switch.
  4. Superb heat release system provides excellent heat transport capacity.
  5. Slip-resistant body design.
  6. Lengthened lanyard hole with tail-standing design.
Operation:
A. OFF State:
Press and hold the front side switch for more than 0.5 seconds to turn on the light, while another press for 0.5 seconds will turn the light off.
B. ON State:
Click the front side switch to switch between 3 output modes: High, Medium and Low. Double click the switch to enter into Strobe mode, after another click, the light will go back to original brightness. It memorizes last brightness level when the light is turned off, while Strobe will not be memorized.
Length 4.69 inches (120.3mm)
Diameter 1.56 inches (40mm)
Weight 4.03 ounces (115g)
1×32650
10lm / 280h
100lm / 26h
800lm / 7.5h
3×AA
10lm / 150h
100lm / 15h
500lm / 6h
1×D
2lm / 60days
30lm / 80h
200lm / 7.2h
that actually sounds like a reasonable spec to me, good find.
3 AA's or a D or a 32650. I've been wanting a 32650 light. I already have a charger for it. Side clickie, anodized threads and lanyard hole too. Please let this be budget friendly.
That really is a nice looking light. 8)
I definitely want one
HKE may be selling it soon.
Do want :stuck_out_tongue:
I just got a response from them that it's in stock now. $53 shipped. $2 more for tracking.
The price is low enough that I'll almost certainly get one if a better deal doesn't come along, but high enough that it can wait for a little while.
Likewise, Stanley also told me SD10 just arrived, US$53
Now would like to fish for a good 32650 Li-Ion batt, any recommendation ?
I'd recommend the Feilong at Fasttech, but they're out of stock.
I came across this earlier. No name battery, so I don't expect much. It might be the same as this cell at DX, except for about half the price. That doesn't make it good. We don't know.
There also the Trustfire 32650. From what I've seen, Trustfire flames are okay batteries with consistent quality.
Hmm, I think I can wait for FT to restock Feilong Li-Ion while toying SD10 with two AA to D converter which I have now, or Feilong LiFePo4 ?
