15x Cree War Heats Up -- KD 15x T6
12 posts / 0 new
Flomotion
Flomotion's picture
Just went to KD, and saw this:
http://kaidomain.com/product/details.S022097
Flomotion
photon1k
photon1k's picture
I think it isn't bright enough - it only has 18K lumens.Wink
dchomak
Last seen: 7 hours 13 min ago
If you feel uneasy looking at the reflector of this light you may have this.
Trypophobia
sb56637
sb56637's picture
Last seen: 6 hours 52 min ago
I wonder if this is actually any brighter than a SRK or a BTU shocker?
moderator007
moderator007's picture
Last seen: 13 hours 40 min ago
I wonder how its wired and the driver they used. With a input voltage of less than 16.8v it about have to be a boost driver I would think. With 15 xml’s you can’t get a even array for 4 li-ion’s. Could be either 5p3s buck or 3p5s boost.
Rusty Joe
Rusty Joe's picture
Last seen: 15 hours 6 min ago
I have only a little doubt that it is almost twice as bright with 15 emitters, but if driven correctly, would be about 3 times brighter. It would also produce enough heat to get 210 degrees on the head surface!
Eat Once a Day - Lose Weight - Feel Great!
www.omad.info
Dale
Dale's picture
It’ll be a super bright short flooder… Distance will suck..
relic38
relic38's picture
I agree with this statement… once it’s modded. Stock, maybe 3000-3500 lumens. Yes, that’s bright but it has 15 XM-Ls so it would be barely driven at that output.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
MRsDNF
MRsDNF's picture
Last seen: 8 hours 39 min ago
$6.60 per Led. Looking at it another way you could say that you get 15 XML leds for $98.70 and a bonus host thrown in. Its starting to look good.
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
TrakTuned
TrakTuned's picture
Last seen: 4 years 3 weeks ago
I like the looks of this the BEST of all multi xm-l lights. You could severely under drive this for fantastic efficiency and still major output. Sweet.
even if each xm-l was putting out 100lm it would be 1500lumens, easily over 1000 OTF.
BLF members are hilarious:
“That’s like saying “My car has top-speed of 200k millimiles per hour”. Why not to just say 10 Ah?”
Slewflash
Slewflash's picture
Last seen: 2 years 8 months ago
This is a great idea for emergency lights and floody lights. To get 100 lumens out of an xml it needs to be just under 250mA. So 250*15 = 3.75amps for a 1500 lumen light which doesn’t heat up. And that’s based on a 1st gen xml t6 which is what this light uses. That’s crazy efficient.
I can imagine it now.. an array 20 xmls giving off 180 degrees of 2000 lumen flood while only consuming 5A, and staying cool enough for a child to hold.
Slewflash
leaftye
Last seen: 3 hours 27 min ago
I still want someone to make a direct drive 1x26650 version of this light using the 50A continuous battery.  3.33A per LED on copper.  18000 lumens.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
