C8 addicts thread
404 posts / 0 new
crnkin
Last seen: 2 years 2 months ago
C8 addicts thread
Hey guys.
A few of you know I’m big on c8’s.
I use my torches (yeah I’m kiwi) mainly for work and hunting. In NZ we have a huge rabbit problem and it’s a super popular pastime.
Anyway, the c8 for me provides an excellent balance of light weight, throw, flood, amazingly cheap price and most of all mod-ability. I have many other torches but the c8 seems the best so far.
Ive started this thread because I think it would be great to keep all the information out there in one place, and we can keep track of what each other are up to.
So without further ado, my efforts tonight.
68,200 lux at 3.56 amps
74,000 lux at 3.75 amps
83,100 lux at 3.89 amps
all tested at 8m, fully charged trustfire 3000mah flames, once amps stabilise, as they actually rise from turn on. There is a HUGE variance in my flames, I have had 3 fail this week, but they are cheap and work good when new. These are all a year old. I’m currently testing other batteries for the xml2’s due to the high vf. Samsungs are supposed to be good? (Tom?)
Made these 3 up for a mate who reckons he cant drive a soldering iron. He uses them for shooting rabbits on a 12g shotgun. He has been using a stl-v2 at 2.5 times the weight, 1/2 the throw, stupid modes and no pressure switch. He now uses these exclusively on the shotguns but i’m in the process of making something more suitable to centrefires for him.
They all have Fasttech 8×7135 drivers. Top has +2 .35a’s piggybacked, middle has +3 .35’s, and the bottom has +3 .38s. On the 10%-100% mode.
All have xml2 u2’s de domed in petrol from illumination supply on sinkpads from Vesture of Blood. (cheers mate). Mounted with AS and glued on top to the pill with AA.
Small extra bits are pressure switches, AR coated glass, GITD tail caps, all from fasttech and springs modified to suit longer batteries.
These are 20,000 lux standard with xml u2’s at DD (around 4.3 amps, ie why my cells are failing), so around about 4x brighter than standard.
I can get 10,000 more lux by removing the LED centering spacer, but Graeme likes the slightly wider beam when tracking rabbits.
The hosts are all from an aliexpress trader who is a fraud, has mostly all fake feedbacks on his auctions and has refused to refund me for the fact he sent the wrong items and I sent them back to him – all at my cost. Aliexpress wont respond, its been 4 months I’ve been trying to get my money back.
LED SUPERMALL is a highly untrustworthy, fraudulent trader and I’ll post more details where and when appropriate.
I am currently looking for a new host, and I LOVE fasttech, but their threads are all different, so we will see.
How is everyone else going out there?
I had my xp-e at 2.5 amps up to 128,000 lux last week but damaged the wires tonite moding it more – more xp-e’s are in order I think!
I have an xpg2 im just finishing, its sitting at 99,000 lux tonight at 2.5a, but I’m out of drivers, 20 on the way from fasttech.
My gunsmith needs a few so he’s next on the list.
All my torches are done for free, I just charge what it costs me, I don’t charge for time, its a hobby, not a job Smile
Cheers!
Chris
Edited by: crnkin on 07/05/2013 - 06:55
devdvr
Last seen: 10 months 2 weeks ago
Great idea. I Love building C8
Here’s the C8 i just completed. my favorite to date.
Convoy C8
Qlite driver with 2 chips removed giving me 2.28 amps, 3 mode, Brass pole to replace stock positive spring. No high pitch whine or PWM in any mode.
Used 24g silicon wires
Fully potted pill with 3 copper discs inside the pill flat against the top.
XPG2 2B tint mounted on 16mm noctigon copper pcb. I love the tint to much to dedome it lol. maybe the next one i build.
UCL water white lens
OP relfector from KD Smooth beam, really tight hotspot, No rings
Extra 24g wire from switch plate to negative brass post.
All my 3100 mah 2600mah and 3400 mah keeppower fit no problem
Have no equipment to test it but the hotspot is really tight and instantly burns my eyes flashing it on a white wall lol.
gords1001
gords1001's picture
Last seen: 1 month 4 days ago
I’ll add info when I complete my xp-g2 builds, I have a couple of xp-g specific reflectors from cnqg to try, I will also be going with noctigons, qlite drivers and trying domed vs dedomed, I’m also thinking about silver soldering the copper stars to the brass pill but am so far undecided on if this will be a benefit or hindrance.
ohaya
Hi,
If you’re interested in throw, in a relatively small form-factor, and if you can get your hands on one, you might try using the head from a FandyFire STL-V6, with a body from an A8 clone and a dedomed XM-L of the suitable variety.
I only recently started dedoming (put it off for a long time, because it seemed like “magic”), but, with an XM-L T6 in the above, I measured 122 Klux. This light also has a UCL/P lens, and it’s direct-driven. Currently, I’m using a KK 26650, but the body can also use an 18650 with an adapter.
I have a new lux meter coming into today it appears, so that I can double-check that lux reading, because I have a hard time believing it myself.
Jim
BIGWOOD
BIGWOOD's picture
gotta love those c8s
1st picture - C8 pill from FT.  Metal on metal baby!  It has screws so no silly toothpaste between the pill and PCB.
10 x 7135s on KD V2 driver
XM-L2 U2 1C
20mm SinkPad
Those soft 22awg heat resistent leads are a godsend to use from intl-outdoor.   Notice the red wire?  That came with the C8 pill and soldered to the driver ground to the pill.
Crap!  Should have used an 1 mode driver.  Oh well too late!  H-M-L will have to do!  At least I remembered to pot the thing before soldering it together.
Ok - all done.  This will be going on... (see next picture)
"Hey Tony! Say hello to my little friend!"
Tom E
Tom E's picture
Last seen: 6 days 20 hours ago
crnkin - I'm a little confused here... by lux do you mean candela? lux is a meter reading, which by itself is pretty meaningless. Candela tells me exactly what it is, and ANSI/NEMA standard is on for at least 30 seconds. If you mean candela, you got good #'s on those 3 lights, but the 3.85A one should be 95 - 100 kcd (maybe higher) with what you got, but the batteries I'm sure are killing your #'s.
Yes - Samsung INR 20R's are the best, and it seems like FastTech's 20Q's are as good in my testing. You also should copper braid the + and - springs, and use 22-24 gauge wires. Other good cells are Pana PD's, maybe the CH's, and the SONY 30A rated ones.
I got one of VOB's copper pills in one of my C8 (LightMalls UF U2 originally). Also have a Convoy C8 with a de-domed XP-G2 getting 125 kcd, maybe better, and a XinTD C8 with an XM-L2 U2 at 3.85A w/dome that does about 45 kcd. (oops, had a mistake there - edit/updated).
bikenber73
bikenber73's picture
Last seen: 3 days 17 hours ago
I need some AR lens that are 42mm (C8 sized right?) anyone have a good source or experience?
Pulsar
Pulsar's picture
Last seen: 1 day 11 hours ago
IO has c8 AR lenses
Slim Pickens
Slim Pickens's picture
Last seen: 2 months 4 days ago
Anyone know what a C8 with a well-driven copper XP-G2 with intact dome does as far as candela?
eebowler
eebowler's picture
Last seen: 2 weeks 3 days ago
So if I remove the insulating ring around the LED (and put Kapton tape to prevent shorting), I’ll get a higher lux reading?
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
manxbuggy1
Last seen: 1 month 1 week ago
It looks like this thread was started just in time for me to post my upcoming test on. Lol. I have several C8’s that I plan on testing next weekend. With the help of my brother I will be measuring tail cap amps, lumens, candela and beamshots of several different C8’s. I have the Xin TD V4 with XM-L2 T6, Lightmalls C8 with XM-L2 U2, Kaidomain C12 with XM-L2 U2( hopefully in by next weekend), Lightmalls C8 with XM-L U3, Lightmalls C8 with XM-L U2, Trustfire C8 with XM-L T6, Keygos K-E5 with XM-L T6 and a Dongrui All-920 with XP-EQ5. That raps up the stock lights. I also have an XM-L U3 on sinkpad driven at 3.85A, an XM-L2 T6 de-domed on sink pad driven at just over 4A These last two are fantastic builds by Tom E. I am crossing my fingers that the Kaidomain C8 comes in on time.
crnkin
Tom E wrote:
crnkin – I’m a little confused here… by lux do you mean candela? lux is a meter reading, which by itself is pretty meaningless. Candela tells me exactly what it is, and ANSI/NEMA standard is on for at least 30 seconds. If you mean candela, you got good #‘s on those 3 lights, but the 3.85A one should be 95 – 100 kcd (maybe higher) with what you got, but the batteries I’m sure are killing your #‘s.
Yes – Samsung INR 20R’s are the best, and it seems like FastTech’s 20Q’s are as good in my testing. You also should copper braid the + and – springs, and use 22-24 gauge wires. Other good cells are Pana PD’s, maybe the CH’s, and the SONY 30A rated ones.
I got one of VOB’s copper pills in one of my C8 (LightMalls UF U2 originally). Also have a Convoy C8 with a de-domed XP-G2 getting 125 kcd, maybe better, and a XinTD C8 with an XM-L2 U2 at 3.85A w/dome that does about 45 kcd. (oops, had a mistake there – edit/updated).
Yeah sorry I mean lux @ 1m or cd.
All are at least 30 seconds, I test them 3 times and take the lowest. Its also just a cheap fasttech light meter so who knows exactly what they are, but work good for comparisons between each other.
I have the fasttech Q’s on the way so will see what I can do there.
What are you running the xpg2’s at? I have thought of running them at 2.8, I have previously ran them at 3.5 on alloy but just testing right now.
The XPE2 at 2.5a was bloody awesome, its basically a jacobs a60 with 25% more cd and a far, far better beam.
Will update as I get each batch finished, im extremely busy with work but this takes my minds of things
Chris
light junkie
light junkie's picture
Last seen: 3 days 8 hours ago
I can comprhend only about 2% but I love the C8platform iwas looking where to subscribe on this forum but no luck any how ill try to keep up with tbis post .
Lj
crnkin
Buh.
So my iphone is playing up, Graeme couldnt pick up the three c8’s because apparently I had no sim card in. Reset and 3 texts come through.
So after playing with some toys and getting the cat off my lap I decided to play with the xpg2 a bit.
Excuse the cell pics and clutter, I have 3 planes, 2 heli’s, 2 rifles and 100 torches on the go at the moment, plus leaving for a 6 week trip to US, Canada and Mexico soon so no time to keep tidy Smile
So thats 115,260 lux at 1m at 2.85a (7x.35s and 1 .38)
was 99,000 lux at 1m at 2.50a (7x .35’s).
The driver is again Nanjg from fasttech, AR lens from fasttech, xpg reflector from CNQG (Also highly recommended), this one has no spacer, but seems to have a focal point about 1/2 way between no spacer and a spacer, so will get out the sandpaper, see if I cant get 125k at 2.85a.
I wish this Aliexpress seller wasn’t so damn dodgy, because this host is absolutely perfect. The pill height is 1mm higher than stock, so requires no modding for using no spacer. Also has 20mm recess, good switch, stepped c8 xml SMO reflector (best ive found), anodizing is good etc.
Might have a beer and do some youtubing!
Chris
ohaya
FastTech has them:
https://www.fasttech.com/p/1203405
Tom E
Tom E's picture
I'm running a de-domed XP-G2 at 3.85A, but only getting 125 kcd, though I think that # is low because measuring at only 4.3 meters. I used this XPG reflector from KD: kaidomain.com C8 XPG. XP-G2's just increase their output on copper with more amps - Match's charts show it increasing at 4 amps still, here: http://budgetlightforum.com/node/19331.
 If your #'s are good and getting 115 kcd at 2.85A, I'm think'n that reflector is really awesome. I'm ordering two now... LED positioning and the reflector I've seen make big differences.
 For AR lens, I got the AR lens from IOS and UCL from flashlightlens.com, though you may have issues with the thinness of the IOS lens - they were nuch thinner than the stock C8 lens in one C8, so didn't end up using it.
bikenber73
I ordered some AR lenses from FAST TECH we will see what I get! It seems like there are 1.5mm and 2mm lenses out there we will see what shows up.
Did the Xin TD V3 come with an AR lens?? I cannot seem to tell on mine . I am pretty sure that my Convoy C8 did not.
Thanks!
Tom E
Tom E's picture
I think the V3 was shipping with an AR, but I had an earlier version. Convoy C8 definitely not - I found the FT AR's totally useless - no difference. Also the cheaper KD ones - same thing. IOS and UCL I trust and appear to be the real thing (UCL definite). Best bet now is maybe wait for OL to get up with his AR lens making hobby/biz - pretty much guaranteed you are getting the real thing.
Haterade
Last seen: 2 years 5 months ago
Love my (stock) XinTD V3 C8 with XM-L T6 3C and Lightmalls C12 with XM-L2 U2. C8s (and C12s) are great. Sounds like I need a 3.85A one.
Big Smile
I like copper
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 9 months 2 days ago
Has everyone here seen the test of a new XinTD C8 SC-82/V4 here http://budgetlightforum.com/node/21824 ?
Do you agree with his opinion of it?
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
manxbuggy1
Fritz t. Cat wrote:
Has everyone here seen the test of a new XinTD C8 SC-82/V4 here http://budgetlightforum.com/node/21824 ? Do you agree with his opinion of it?
I certainly like mine. I have several C8’s and this is my favorite stock C8. The regulation is incredible. On the light box it only dropped 20 lumens in 30 seconds. The modes are really nice too. I refused to buy a Xin TD for over a year because it was double the price of my other c8’s. Now that I have bought one I just ask myself why I waited so long.
gords1001
gords1001's picture
yes I agree with and value foys opinion, I would have ordered one but ordered an x3 instead, maybe an xintd c8 next time
Haterade
Don’t have a V4 – yet. My V3 is great. My LM C12 is brighter, but the XinTD gets used more because of better modes (no strobe), and better tint (3c). And it just feels nicer in hand. Yes, it cost more, but still seems worth it, IMO. The new 5B tint option sounds fantastic to me.
I like copper
Jacob_
Last seen: 3 years 4 months ago
great thread guys, been reading this forum for months…
pulled the trigger on a Convoy C8 to start adding some mods…
wanted to asked if there is a copper pill that fits Convoy C8? …saw in a thread that it’s not the regular size…
Tom E
Tom E's picture
Jacob_ wrote:
great thread guys, been reading this forum for months... pulled the trigger on a Convoy C8 to start adding some mods... wanted to asked if there is a copper pill that fits Convoy C8? ...saw in a thread that it's not the regular size...
Hi Jacob, and welcome!! The Convoy C8 pill is a one of a kind - not standard C8 pill size threads, and it's designed for 16mm stars, not 20mm. The body is a quality C8, but the non-standard pill is my pet peeve with it. I bought it as a host and built a de-domed XP-G2 out of it.
eebowler
eebowler's picture
Jacob: Aluminium is a BETTER thermal conductor than brass. Brass is generally what the ‘chinese’ call copper. REAL Copper is a better thermal conductor than aluminium so if you find a pure copper pill then, you’re in a happy place Big Smile
Sirius9
Sirius9's picture
Last seen: 2 hours 44 min ago
Haterade wrote:
….Lightmalls C12 with XM-L2 U2. C8s (and C12s) are great. ….
Can you tell me how heavy is the C12 compared to ordinary C8?
Thanks
gords1001
gords1001's picture
jacob, fasttech has an ultrafire c8…..I’ve dropped one in my cart because it MIGHT take the c8 pills they have, its very cheap for an xm-l c8 and I only plan on using it as a host, I’ll report back
tivo532
tivo532's picture
Last seen: 3 years 7 months ago
Re: Post#13
crnkin,
“_So thats 115,260 lux at 1m at 2.85a (7x.35s and 1 .38) was 99,000 lux at 1m at 2.50a (7x .35’s)._”
I see 1807 from the lux meter, please advise how you got 115,260 Lux.
Also on your first post, you have 68,200 Lux at 8M, is it 68,200 data from the Lux meter at 8 meters? Beer
Fritz t. Cat
As discussed on http://budgetlightforum.com/node/22858#comment-422907, pure Al and Cu are too plastic for practical machining, and casting is not a practical alternative for a budget light. It might be possible to forge a soft metal pill, but not without a lot of development. So we are talking about relatively pure alloys that are machinable but still good conductors versus alloys like aircraft aluminum and brass that are optimized for machinability and strength.
Haterade
Thanks
Don’t have a scale to weigh them, but the C12 doesn’t feel much heavier in hand.
I like copper
