Features
● CREE XM-L2 LED, with a lifetime of up to 50,000 hours;
● Easy switching of 2 operating systems, 7 output modes
Turbo: 360 Lumens (1hr.) (Automatically enter High mode after 5 mins continuous use to avoid overheat)
Strobe
High: 135 Lumens (1.8hrs.)
Mid: 70 Lumens (4hrs.)
Low: 2 Lumens (100hrs.)
SOS
Slow Flash
● Constant current circuit, constant output
● Effective range of 128 meters
● Intensity: 4080cd
● Uses one single AA or one 14500 battery
● Working voltage: 0.9~4.2V
● High quality metal reflector maintains great throw distance and spread with an ideal beam pattern
● Dimensions: 104.5mm (length) x 25.5mm (head diameter)
● Weight: 54g(battery excluded)
● Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Tail stand capable- can be used as a candle
● Accessories: lanyard, O-ring, rubber cap,reversible SS clip
Features
Strobe
High: 185 Lumens (2.1hrs.)
Mid: 80 Lumens (6hrs.)
Low: 8 Lumens (60hrs.)
SOS
Slow Flash
● Intensity: 4080cd
● Uses one single CR123A or one RCR123A/16340 battery
● Working voltage: 3~4.2V
● Dimensions: 88mm (length) x 25.5mm (head diameter)
● Weight: 47.8g(battery excluded)
Easy Switching of 2 Operating Systems, 7 Output Modes
The S10A and S10R has two operating systems by tighten or loosen the light head, easy to switch. There are 7 output modes to choose from by depressing the tail cap switch.
Operation details:
—-With the light head tightened
1、Regular Modes: slightly depress the tail cap switch once to activate the light, and slightly depress another time to choose from Low- Mid- High outputs, each depress for one mode and it goes in cycles. Fully depress to choose your desired mode and lock it.
2、Hidden Modes: there are SOS and Slow Flash hidden. To avoid accidental activation of the hidden modes, only after two continuous cycles of regular modes, will the SOS be activated, another slightly depressing at SOS will enter Slow Flash. Fully depress to choose your desired mode and lock it.
3、Memory Function: the most recent mode used will be memorized for future use, hidden modes not included and replacing of new batteries or disconnect of light head and body will refresh the modes.
——With the light head loosened
1、Slightly depress the tail cap switch once to enter Strobe mode, and another time to activate Turbo mode. Fully depress to choose and lock your desired mode.
2、No memory function, first slight depressing will always activate Strobe.
