I am after some ideas about which LED’S, to use to light my garden shed, it has a 12v leisure battery in it to run stereo and the 3 strip led’s that are there at the moment, but need way more lighting in there, it’s only a “lad’s” shed and about 10’ X 10’ in size.
I know I will obviously need to keep an eye on the battery state/charge, and likely top up once a week or so, but it’s got settee in there just a chill out place that I need, I have brain damage that gives me anger issues, similar to PTSD.
Any help greatly appreciated, my brain damage was from being the victim of a DD, nothing to do with drugs etc, personally I don’t drink or smoke.
tabs
Have you considered a small solar panel to keep your battery topped up?? That might be the least expensive in the long run, coupled with a LED bulb from one of the big-box retailers.
Another trick is that if you paint the interior bright white, you’ll need far less light and perhaps even a good flashlight bouncing off the ceiling might be sufficient.
Even though I chill out in there, others also have the use of it, and I got out voted on colour, all BLACK, yep that really helps with the lighting, there is a double window at the back, has carpet inside as well, I have three solar panels, was thinking of putting these up and taking some readings over a week, it’s not really a hassle to recharge battery, only a case of running cable reel out once a week or how ever often.
I have a lot of 12v round led “disc” lights that I use on cars etc, so probably going to go that way as an experiment, I have invertors also, but I don’t want to put mains lecky in there as some hoodlums(read typical teenagers) also use it.
tabs
How does pointing a flashlight at the ceiling to illuminate the room and/ or using a Zebralight headlamp work with what you are trying to achieve?
No theft of your lights, use them elsewhere also, I do this myself
Russ
Use those “wall wash” floodlights that abound on Ebay. You can get them 12V or AC powered. The 10 watt ones are very cheap… and surprisingly well built.
