Review: FandyFire S3 review sample from LightsCastle
FandyFire S3
Overall Rating
Summary:
Battery: 1x16340 or 123a
Switch: tailcap clicky
Modes: H>M>L>Fast Strobe>SOS Next Mode Memory
LED Type: XM-L T6
Lens: Glass
Tailstands: Yes
Price Paid: Review Sample - Retail $21.70
Date Ordered: 07/15/13
From the LightsCastle Website
Description
Brand FandyFire
Modes 5
Battery Configuration 1 x 16340 / 123A
Brightness 600
Dimensions: 3.70 in x 0.94 in x 0.94 in (9.4 cm x 2.4 cm x 2.4 cm)
Model: S3
Emitter Brand/Type: Cree
Emitter BIN: XM-LT6
Color BIN: White
Total Emitters: 1
Battery Configurations: 1 x 16340 / 123A
Rechargeable: No
Battery included: No
Voltage Input: 0.8~4.2V
Circuitry (mA): 1500
Brightness (lumen): 600
Modes: 5
Mode Memory:No Goes to next mode
Mode Arrangement: High > Mid > Low > Fast Strobe > SOS
Switch Type: Clicky
Switch Location: Tail-cap
Lens: Glass Lens
Reflector: Aluminum Smooth/SMO
Carying Strap: No
Weight: 57.00 g
Pros: Small, Light weight, great color, Love the clip. Good overall fit and finish. Very bright.
Cons: Next mode memory
From here I go my separate way. I will discuss the light as I show photos:
The led is well centered in the SMO reflector. A little too much solder was used during reflow.
Stainless tail cap
Body/head threads. They were lubed. They are not super smooth, nor are they gritty, just average.
Head/body threads and driver. It appears that the driver is not fully seated, but unless I were to disassemble, I can't swear to it. It looks like it was tested at the factory. To load the battery, you unscrew the head from the body and drop the battery in from the top.
I only found a couple minor blemishes on the light. Here and in the photo below. These were blems that were done prior to Anodizing. The top one is probably contamination that did not allow the Ano to stick and the bottom photo shows inclusions that probably came from parts hitting each other in storage bins before plating.
All the O rings were in place. I found one that had been shaved a little during assembly.
The tail cap and rubber boot removed. Threads were dry, but that's ok. It should not be removed under normal conditions. It was not super tight and came out easily.
Inside is the switch and the assembly can be unscrewed via the two holes, with needle nosed pliers.
Looking inside the body at the spring.
Stainless bezel
The led sits on a shelf. The head is one piece with the shelf made into it. No removable pill here and most likely no easy way to mod it. Not enough metal to really go hog wild and put a 3 amp driver in it, at least I wouldn't. It's bright enough as it is. Lots of thermal paste in there. Maybe too much, but at least it's in there and spread out evenly.
Glass lens looks to be coated. GITD O ring is a nice touch.
The reflector is aluminum and has a good plating job on it.
Overall - This is a Very nice light. It's light, it's very bright and it has a nice strong clip. I really like this little light. The fit and finish is good and better than the other lights I will review. The only down side, for me, is that next mode memory. It should have been mode memory, so it would turn on where you left it at.
Beam Shots
Like I said, it's bright. My Amp readings were 1.70 amps on High, .72 amps on Medium and .34 amps on Low. That was with a fresh TF Flame 16340 battery.
Thank You to LightsCastle for sending me samples to review. I'm not the best reviewer in the world, but maybe I will improve..... or not....
That's all folks..........
I keep looking at this little light, a qlite with three 7135’s removed would make it a really nice little light. Thanks for the review Old lunens.
I have thought about changing the driver out and using a 6x7135 with just the three modes and memory. I may mod it before it goes to giveaway mode.
Great thorough examination of the light with nice pics!
The shape reminds me of McGizmo’s original PD light.
Very good job, Justin! I still love the look of that light but it's a little long for a 16340 torch and the next mode memory sucks. Still, a simple driver swap and you have a very classy, sharp looking little light for EDC to my board meetings. :bigsmile:
Nice review Justin! It seems like a tiny powerhouse, and with decent looks too.
I am starting to think about trying a group buy for this, if the driver can be changed for mode memory. Wrong thread to put this into, but I will contact LC to see what they say.
Sounds interesting.
Nice review, thanks.
Jim
I’d be in on a group buy regardless of driver, infact if they could do it as a host, all the better tbh
Nice review!
I have always loved that clip and tailcap section.
Thanks for the review OL. I cannot believe next mode memory. When will manufacturers wake up to themselves?
Nice light. The beam shots is really bright. Even at a farther distance, it’s passable. To me that is.
I like the looks of this one .
Cool
nice review. looks like a fun little light
O-L if you want to burden yourself with a GB on this, I’ll go in for one. I like the styling. As a host is ideal for me (probably not enough for a GB though), but as a complete light is fine too.
I am working with LightsCastle, to see what options they can do. It might take a few days.
Is this really fancy enough for YOUR board meetings?I thought you only wore the silver machined EDC’s with the gold bezzels to work?Are you starting to slum-it a bit to try and fit in with us little people?LOL! :stuck_out_tongue: -Rick
Thanks a lot for the review! Frontpage’d and Sticky’d.
Easy to see whose design they stole.
McGizmo for those who don’t know.
