2AA Mini-Mag with a Side Switch, DrJones driver and a 3-up - just another crazy mod... It's Finished!
41 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
 I found this dark blue 2aa Mini Mag in Wal-Mart. I can't remember the last time I saw one that dark, so I took it home, to destroy it.Tongue Out
I am putting in a Nichia 219 3-up with TIR optic and a DrJones linear driver with ramping. In order to do that, I need to use a momentary switch, so I decided to try and put a SMD switch in the side of the body... Yes, a side switch in a minimag.
I made a little video of what I have done so far and when I finish it, I will update the video with the results.
Components:
  • 2AA Mini-Mag
  • 3- Nichia 219s on a triple star (parallel), from IS
  • 3-up TIR optic from IS
  • DrJones 3040mA driver with 3 chips added - 4 amps approx.
  • Various copper pipe components and copper discs
  • Aluminum rod stock for locating the switch and for the positive contact for the battery
  • Switch cap from a cheapie light
  • SMD switch
  • Efest 14500 IMR battery
  • Etc, Etc, Etc...
 mmsw1
 Here's the video teaser showing the start of this project:
Well, I am finishing this up with a few photos. As usually happens, once I get to finishing a mod, I don't want to stop and do a video, so a couple photos will have to suffice.
smdm1
I was waiting for a couple things. One of them was some 3mm copper discs, but I just went ahead and made one of my "almost round" ones instead. Here it is soldered to the positive wire, before using AA to glue it in place.
smdm2
Four wires are ground, positive and two for the SMD switch.
smdm3
Ready to add the driver. I drilled and put in a pin, to hold the center aluminum shaft to the outer copper shaft.
smdm4
Down inside I added a copper ring for the end of the insert to sit in, to help stabilize it.
smdm5
The driver is in place. I didn't take a shot when I put the led star on. As you can see, there's not much room and I could not add more chips, so it's a 3040mA driver, or about 1 amp per led. Not the brightest light in the world, but it should be ok for a Mini.
smdm6
Finished light
smdm7
I didn't even have a clear TIR optic. This one is frosted and I polished it up a little. I have to get a clear one.
smdm8
The IMR batteries have not come in yet, so all I have is a couple of "don't Trust Me" fire batteries. They can't put out the necessary amps, but at least it proves it works. This is on high.
smdm9
Lowest setting. My camera will not reproduce the neutral white color of the leds. It just shows up as white, when they are shining directly on the sensor.
I will do beam shots when I get the Efest batteries, but that will be a couple weeks most likely. It's finished for all intents and purposes.
This particular SMD gives an audible click when pressing it. It sounds like a muted clicky... sort of, but quieter. It takes a fair amount of pressure to turn it on. I ended up using just the rubber button and a thin spacer, so the rubber pushes directly on the SMD switch. It was because of tight clearances. The old 10 pounds of ____ in a 5 pound box kind of deal.
The DrJones driver has two main modes - High and Medium and then there's ramping and the other modes he normally puts in. I ordered mine with just high and medium, since the ramping will set the light wherever a person likes.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 08/03/2013 - 21:36
Old-Lumens
Reserved
RaceR86
RaceR86's picture
Last seen: 4 years 1 month ago
I really like this mod!
I might be doing a few maglite mods this autumn, but when it comes to AA MiniMaglite, I dont think it gets nicer than the light you are making there in terms of how the build is done. The parts and the design are just brilliant! I really like the DrJones drivers too. Im not that into using dummy cells and such (which this light does not use), but the way you have utilized the space for heatsinking and the electronic switch is just really cool and nice!
As for the amps. 4 amps is more than enough for high IMO! Its already stupidity! Which is just perfect! J) Wink Coupled with a DrJones driver where you can set high to be whatever you want you can actually make it more reasonable too. Smile
As you can see in a graph from HKJs review of the efest 14500. It should only be able to do 3+ amps with the required voltage for about 5 minutes, that is, if you start at 3 amps.
If you start at 4 amps, assuming it will do 4 amps maybe 1 minute. Silly My guess is that you are below 3 amps in less than 4 minutes if used on 100% output.
There should be no need to try and push it further than 4 amps. Its already insanity at its very best! J)
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Sirius9
Sirius9's picture
Last seen: 3 hours 31 min ago
Crap, I was doing very similar thing with 2AA minimag, Dr Jones driver, momentary switch and TIR optics but I can’t find bloody machinist with a lathe which could make me a copper insert |(
RaceR86
RaceR86's picture
On the bright side. Now you see how it can be done without a lathe! Wink
Sirius9
Sirius9's picture
As funky this may sound, doing this part on a lathe is much easier solution for me because I don’t have different sizes and thicknesses of aluminum and copper pipes and rods, and no one here is selling them in like 10 cm long pieces, you have to buy at least 1 meter and that would cost a fortune (copper)…
TrakTuned
TrakTuned's picture
Last seen: 5 years 10 months ago
SMD switch. Nice.
I dont think I have ever seen a dark blue mag..Pretty neat
BLF members are hilarious:
“That’s like saying “My car has top-speed of 200k millimiles per hour”. Why not to just say 10 Ah?”
TrakTuned
TrakTuned's picture
How much amperage can those 219’s take on copper?
RaceR86
RaceR86's picture
I understand. I don’t have access to lots of copper stuff either. Although you can gets lots of various rods and stuff on ebay cut in small lengths or quantity.
Not that cheap when shipped, but doing “mechanic” custom builds aint always that cheap…
…or maybe we are just too spoiled with the stupid low prices from China.. Silly
Sirius9
Sirius9's picture
they definitely spoiled me with “free” shipping :bigsmile:
Microa
Last seen: 16 hours 26 min ago
Brillant idea for the thermal management and keep the classic Maglite’s appearance.
strayz
Last seen: 3 days 12 hours ago
Can not wait to see finished project!! Beam shots too!!
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 2 weeks ago
Been thinking about doing a switched AA for awhile. Not surprised OL beat me to the punch. Rivited
Scott
MRsDNF
MRsDNF's picture
Last seen: 21 hours 22 min ago
Was there invitations sent out for this party? Who’s shout.
ryansoh3
ryansoh3's picture
Last seen: 2 weeks 2 days ago
Crazy indeed! Great job, thanks for sharing. Smile
BLF ≠ B-grade Flashlight Forum
Old-Lumens
Copper is definitely going up in price fast. Even copper plumbing fittings are getting way high. I usually buy from Lowe's and they have various small sizes of pipe in two foot lengths, but the new stock has gotten too high. I still have some of the old stock and that's what I have been using. Just trying to use up what I have.
That is the first dark blue Mag I have seen. I thought it might be a new color or someone sent a sample color out with the rest of a run.
With the temps in the 90's-100's it might be a few days to finish, since I just get an hour or two in the mornings.
We aren't spoiled by China, it's just that we don't realize just how much of our taxes go back to China, to subsidize their shipping. It isn't free, we are paying for it and paying for the manipulation of the Yuan.
ToyKeeper
ToyKeeper's picture
Last seen: 6 hours 47 min ago
Haha, tell me about it. I just installed 90 feet of copper pipe in my living room, for use as steampunk decor. It looks nice, but it could definitely stand to be a little cheaper.
Old-Lumens
The mod is finished. See the OP for the rest of the mod.
MRsDNF
MRsDNF's picture
Orsm build OL. Did the switch rubber boot slip in after or before assembly?
Slewflash
Slewflash's picture
Last seen: 1 year 8 months ago
Nice build!
A question though, does the driver accept more than 8.4V? Or does it have to be used with a dummy cell.
Slewflash
Sirius9
Sirius9's picture
- driver only accepts up to 4.2V, it’s a NANJG 105C
- what dummy cell, thers no place for dummy cell, one 14500 only (runtime on high = 5 minutes Silly )
ruffles
ruffles's picture
Last seen: 23 hours 48 min ago
Very nice… particularly like how you mounted the switch.
Apologies if you said so in the video, but where did the switch cover come from?
ChibiM
ChibiM's picture
Last seen: 21 hours 43 min ago
Thanks O-L
its always interesting to see your mods.. and you usually show as if it is pretty easy to do...
I can`t come even close to what you do with your mags...
(probably this is going up for sale pretty soon?)
Old-Lumens
@ MRsDNF - The rubber switch cover went in the body first, before the rest went in.
@Slewflash - Answered in Sirius9's post.  aDWE34  This assembly replaces what would be the dummy cell.
@ ruffles - The switch cover came out of a cheap multi-led light.
@ChibiM - Once the Efest battery comes in and I do beam shots, it will go up for sale.
Rufusbduck
That’s a serious cram job. Until you’ve modded a Minimag, it’s hard to realize just how much less room there is than in an 18650 host. Always interesting to watch these evolutions.
Scott
TexasLumens
TexasLumens's picture
You rascal! You can truly put 5 lbs. of stuff in a 1 lb. sack!!! ...and STILL make it look good!!
Neat Mod, video and images!!!   Thanks for sharing!!
Dan.
Texas Lumens Website… http://www.texaslumens.com
WE LIVE IN THE LAND OF THE FREE ONLY BECAUSE OF THE BRAVE!
Gj
Gj's picture
Last seen: 4 days 4 hours ago
Glad you use your powers for good, instead of evil. Smile
DB Custom
DB Custom's picture
Last seen: 6 days 23 hours ago
Love your work O-L, simply love the out-of-the-box thinking that goes on at your place!
Would like a shot at that one my own self, auction it off, make us pay for that ingenuity! Smile (or just sell it to me cheap on the sly before you tell anyone else what the price is Wink )
Rufusbduck
LOL. Very few posts have me doing that. Well said Gj.
Scott
TexasLumens
I just had to come and look at this again!! A mini with a side switch!! And just this week, I ran like a chicken in the rain when a customer wanted a side switch on a little light with two 14500's.... And I make the whole thing Undecided....much easier in my mind than doing  a mod! He gets when finished, a twisty!!
 I MIGHT re think this now and surprise him... Get out the jewelers tweezers and optics... microscope, band aids, a glass of scotch to steady the hands, 3 more lathes, two more mills, another dial indicator, rip out another hand full of hair,  Tylenol,  16 new gadgets.... never mind.... twisty it is! Tongue Out
Go ahead..... Laugh! I see that grin!  I can't help it if I need a tug boat to launch a canoe!!! CAN'T HELP IT!!! CAN'T!!!!!!
Dan.
jacktheclipper
jacktheclipper's picture
Last seen: 6 hours 37 min ago
Jacktheclipper likes this .
Excellent work , Mr. Justin .
It was just a plain old dark blue MiniMag
'Till the Godfather modded it without a snag
It's now stylish and bright
and the man with this light
Will obviously have every right to brag
