What causes alkalines to leak?
36 posts / 0 new
Bort
Bort's picture
Last seen: 1 month 6 days ago
I’ve always wondered, also does airtightness have any effect on it?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
Edited by: Bort on 08/14/2013 - 00:04
Wilson
Wilson's picture
Last seen: 2 years 4 months ago
Wikipedia
http://en.wikipedia.org/wiki/Alkaline_battery#Leaks
Edit: [note 1] in the second line reads, with a mouse hover
This alkali particularly attacks aluminium, a common material for flashlights, which can be damaged by leaking alkaline batteries.
Inquire…Choose…Proceed
sorotantaz
sorotantaz's picture
I experience two times duracell leaked, one in storage and other inside Terralux 300.
almost unable to get the battery out as it sticked so persistently.
I’m not really sure why it leaked but maybe the expiration time has something to do. in my case it was coming close (about a year due). usually alkaline cell have 5 years storage time since production so I consider 1 year left is close already.
Bort
Bort's picture
Wilson wrote:
Wikipedia
you have answered my question, thanks
i clicked on the flashlight entry and it mentions capacitors being used for energy storage, i’ll start a thread on it
Backpacker Light
Last seen: 3 days 23 hours ago
Good thread question.
I have wondered the same. Having had at least a half dozen or more lights slightly damaged, or even destroyed by alkaline leaks, I am now freaking out. The few lights I still may run on an alkaline battery, I seem to try and check them every couple weeks. I am now afraid to run an alkaline in any of my decent lights of any kind.
What causes it? The constant high or low temps experienced for example in an automobile? The age of the cell? Multiple cell lights only?
I seem to never have a problem in a TV remote (or smoke detector) for some reason.
The lighter the brighter the better.
Bort
Bort's picture
its explained very well in the link above, i would remove them from any flashlight or device not in constant use
spaceboy
Last seen: 3 years 4 months ago
I have a 3D Maglite I’ve been trying unsuccessfully to open after the batteries leaked inside…
Chloe
Chloe's picture
Last seen: 2 years 11 months ago
You can try pouring in some vinegar to help dissolve the mess.
spaceboy
Pour it in where? I cant get it open! I could drill a hole I guess.
hank
hank's picture
Last seen: 2 hours 17 min ago
The alkaline cell uses the shell — zinc metal — as part of the chemistry. It’s supposed to be thick enough it doesn’t get eaten away from the inside enough to leak — in single use. Ha. Haha. hahahahahhaaha
http://www.corrosionist.com/clean_alkaline_battery_corrosion.htm
lightme
lightme's picture
I’d say it’s poor sealing right from the factory since most never have a problem under the exact same conditions. Capacitors leak too but that might be due to heat/pressure. I dunno, just guessing.
spaceboy
I think the main problem is hydrogen gas build up rupturing the casing or damaging a seal.
Chloe
Chloe's picture
Ahh, do you have a vice or something to wrench it open (you can put leather around it to help prevent scratches)? I used vinegar in my Fluke volt pen as two cells were corroded so much they were stuck inside. It works now after some cleaning and letting it dry out.
lightme
lightme's picture
That stuff ate pieces of my Stanley 3 in 1 Tripod. All three lights had a crust holding the batteries tight. Fortunately, the metal parts were SS which cleaned up easily with a toothbrush and Liquid Wrench (it’s what I had). I put it back together with the residual oil left behind for good measure.
Chloe
Chloe's picture
That’s good. There was a copper strip in my volt pen that needed cleaning with isopropyl alcohol. It really eats through aluminium though. Here’s my ruined Maglite:
The spring and nylon bulb holder were unaffected.
Racer
Racer's picture
Last seen: 3 years 2 weeks ago
I stopped using Alkalines a few years ago. Now it’s just for the few devices where NiMh won’t work, and if I’m worried about someone throwing them away, like the kids. The emergency kits in the vehicles even have LSD or lithium primary batteries in them now.
lightme
lightme's picture
I only use alkalines in devises that consume batteries quickly enough to change them out often. Thought that light would get used more. :~
Racer
Racer's picture
I used to do that until I had a few leak and ruin my devices. Now those devices get Eneloops.
Orion
Orion's picture
Last seen: 5 years 3 months ago
Chloe wrote:
That’s good. There was a copper strip in my volt pen that needed cleaning with isopropyl alcohol. It really eats through aluminium though. Here’s my ruined Maglite:The spring and nylon bulb holder were unaffected.
That is a really stark reminder that either extremes of the PH scale are always corrosive!
“It is a far, far better thing that I do, than I have ever done; it is a far, far better rest that I go to than I have ever known.” – Sydney Carton in ‘A Tale of Two Cities’ by Charles Dickens (1812-1870).
lightme
lightme's picture
Most smoke detectors use 9v. They’re a true “battery” of 6 alkalines. Maybe higher standards? A leaky cell wouldn’t show any signs immediately because of the housing which also offers some protection to the device. Our TV remote always gets new cells before old ones start there destruction.
spaceboy
Same thing happened to my Stanley 3 in 1 tripod. Bad design.
Don
Don's picture
Last seen: 2 years 2 months ago
Unscrew the head. If it won't shift unscrew the bezel ring, remove the lens and reflector. If the bezel won't shift you are probably stuffed.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
spaceboy
Don wrote:
Unscrew the head. If it won’t shift unscrew the bezel ring, remove the lens and reflector. If the bezel won’t shift you are probably stuffed.
I unscrewed the head and can see the plastic bulb holder thing. Does that unscrew?
Don
Don's picture
No - to remove the switch assembly you need to prise off the switch cover and insert a 5/64" hex key into the hole in the middle of the switch assembly and unscrew the pointy screw that cuts through the internal anodising to make contact with the aluminium body. I believe more recent Mags use a Torx screw which would be around TX5 or thereabouts - I've never seen one so don't know. Then there's a C ring retaining clip in front of the switch assembly that needs circlip pliers to release. Then you can pull out the switch assembly. Then have at it with vinegar/lemon juice whatever mild acid you have knocking around. It's best not to use stronger acids as the reaction with the strongly alkaline crap could be violent.
If the sun comes out from behind the rain and fog we have here just now, I'll do pics today.
spaceboy
Thanks. I’ll need to get some circlip pliers then.
Don
Don's picture
A couple of fine nails or screws can be substituted. Or some strong tweezers.
You just need to pull the ends of the ring in enough to release it from the groove cut into the body.
Don
Don's picture
Here's how to take out the switch the easy way.
Unfortunately this won't work with the cells stuck inside which is why we have to go in from the front.
Don
Don's picture
Oops, my memory was at fault. A fine flatheaded screwdriver is what you want to shift the retaining ring - I'm sure the older ones needed circlip pliers but my memory may be at fault here.
In this pic you can see the retaining ring - it is the lighter coloured ring at the base of the bulb tower. I used this old pic as my cameras have gone into hiding so the pic of the ends where you can remove it was taken with a nasty phone cam of stupidly high resolution and equally stupidly high over-sharpening and noise.
Maglite switch retaining ring.
You can see the notches in the ends of the ring here. They're at about 2-3 o'clock. Just get a small flathead screwdriver in there and lever it out of the groove. If it won't shift try washing it out with well hot water, dry it and shoot some WD40 in there then shake it out after a minute or two.
Retaining ring.
Good luck
spaceboy
Thanks for the tips. Had to get a 2mm allen key, got one today. Been trying for the last 20 minutes to release the circlip. Really difficult.
rekit500
Last seen: 5 days 10 hours ago
I read on another forum that the guy gave up on alkylines for remotes and things like that and just uses plain ol carbon ones. They might not last as long but they don’t leak. I’m going to try that.
Lightbringer
Lightbringer's picture
Last seen: 1 hour 31 min ago
Back in the day, I needed one of those teenytiny 12V batteries (A23) for my car’s remote. Rat Shack sold the C-Zn ones for 89¢ each, and they lasted for years.
Then, those were discontinued, and they only sold the hateful little alkaleak versions for almost 3bux a pop… which only lasted a year at best.
If anyone even made C-Zn AA/AAA cells anymore, I’d buy ‘em by the box for clocks, remotes, small instruments, etc.
