High current drivers for single XM-L2
174 posts / 0 new
RaceR86
RaceR86's picture
Last seen: 3 years 11 months ago
Im basically trying to find out which high output drivers are out there and how good they are. So please, share your info with the drivers I mention. Or link to other drivers of interest.
My main reason behind this thread is finding drivers that will do 6A++ to a single XM-L2.
SST-50 driver sold by FT and various places. Specs says: 4A- 5 mode
Is it any good? Can it easily be resistor modded? (looks easy to resistor mod)
The review on FT site says that driver uses PWM and beep during operation. So, its got PWM whine on all levels?
The SST90 driver is quite large. But rated at 6,5A 4,9-5,1 and it seems easy to resistor mod for whatever current desirable.
It looks to be exacly the same as the one DX sell. This review only said it had 70% efficiency and 5,7A to the emitter.
IOS sells a 9amp driver. Several BLF members seem to have one?
9amp is too much for an XM-L2, but it can be resistor modded for lower output. (There have been some overheating issues when driving MT-G2s hard.. )
LCK LED have a 5A DUP-5S driver.
For some reason it have strobe in between low and medium. My driver even had SOS instead of strobe.. Good output, but it can not be resistor modded since its somewhat "potted". So this is limited to 5A.
LCK LED have another 5 amp driver, FL-2
Its 5 amp. (me and some others have gotten a version with 5 modes, but its supposed to be 3 mode). I have not been able to resistor mod it for much more than 5A. (hopefully others will try) This seems to be the same one as the one sold from IOS. 4,5A buck driver
Edit: Its also available from Lightmalls see post 4 and 5. Its available in 5-pack and with different current 3000mA/5000mA, and 3/5 modes. (That kinda explains why I and others easily got a 5 mode.) They are not that expensive in a 5-pack.  0:)
3A version from LM (1-pack)
3A version from FT
IOS 3-18V 5 amp
With a single emitter it should output 5A.  I used to have one of these. Slow mode changing and it whines. Otherwise pretty decent.
Many seem to have this driver in various lights. It has been resistor modded by some (Relic 38 and maybe others)  But how far can it be pushed in terms of output to a single XM-L?
TR-3T6 driver
5 mode (with strobe and SOS). Very cheap, and have been modded to around 7A to the emitter by ImA4Wheelr.
SST-90 driver from Ebay.  Might have high output. Various sellers have them. The specs seems to be inconsistent.  Some say 5A max input, some say 7A max input. Some are meant for SST50 and are rated 5A or less.
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Edited by: RaceR86 on 10/25/2013 - 14:42
leaftye
Last seen: 2 weeks 1 day ago
The East-92 direct drive driver is back in stock at Fasttech.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
RaceR86
RaceR86's picture
Even if they have a decent version now. Which it does not look like based on description, or my experience with the same SKU. Im not buying another one. My last one was only 2 amps. I may have read someone have seen 3 amp or so...
Either way, its a single cell driver. It will not do the type of current I am requesting or looking for in this thread.
Gtamazing
Gtamazing's picture
Last seen: 1 year 11 months ago
RaceR86 wrote:
The SST90 driver is quite large. But rated at 6,5A. And it seems easy to resistor mod for whatever current desirable.
It looks to be exacly the same as the one DX sell. This review only said it had 70% efficiency and 5,7A to the emitter. Anyone have experience with it?
Yes I’m testing one now in a thrower project. I tried it with an XML2 and got 5.5A and also 5.2A with an XPG2 >) both on sinkpads. The xpg2 died after 10 minutes of shining it around the trees. The XML2 worked up until I dropped the light on the concrete floor. it never worked again after that.
Gj
Gj's picture
Last seen: 4 hours 17 min ago
RaceR86
RaceR86's picture
Gj wrote:
I just saw this yesterday, no firsthand knowledge.  Undecided
http://www.lightmalls.com/5-2-12v-5000mah-dual-lithium-3-mode-led-circuit-board-for-cree-xm-l-t6-u2-sst-50-mce-ssc-p7-leds
Looks like this driver from IOS
http://intl-outdoor.com/xml-multicell-circuit-board-45a-ouput-55126v-p-543.html
But in 5 pack. Nice price! Smile
I though it started life as a 3A driver. Then IOS modded it to 3,5A. Now its modded to 4,5A. Does anyone know how much further it can go?
Edit: And that is also the same as the FL-2 from LCK-LED??
Edit2: LM seems to have it as a 3 amp version too.
And they have both the 3 amp and 5 amp version in 3 or 5 modes.
RaceR86
RaceR86's picture
Yes I'm testing one now in a thrower project. I tried it with an XML2 and got 5.5A and also 5.2A with an XPG2 >) both on sinkpads. The xpg2 died after 10 minutes of shining it around the trees. The XML2 worked up until I dropped the light on the concrete floor. it never worked again after that.
Thanks, that is useful information.. Did it have any PWM whine?
I wonder why the XP-G2 died.
I have a driver (stock driver in STL-V6) that is adjusted for close to 5,3A. Will combine it with an XP-G2. That might be able to do 6++, but I  have not pushed it that far (yet?), but its not available from any stores..
comfychair
comfychair's picture
Last seen: 3 years 8 months ago
IOS 9A has a huge pile of 000 resistors, should be easy to remove them all and add back until you get what you want. No clue about the stupid overheat protection though.
nottawhackjob
Last seen: 11 hours 4 min ago
Do you have an FT link for the correct East-092 version? The one I see on FT doesn’t show it back in stock.
“In many things in order to truly understand the small picture you have to understand the big picture first.”
comfychair
http://www.fasttech.com/products/1127405
 $3.07     WORLDWIDE FREE SHIPPING
stock     In stock
quantity     __
(change currency)
nottawhackjob
They’re not selling any version, 2A or 4A. What am I missing here?
comfychair
What you're missing is the part where it says 'in stock' and you can add it to your cart. They just haven't removed the note at the top of the page yet.
Tom E
Tom E's picture
Last seen: 5 days 6 hours ago
Thanks Racer86 for starting this thread. The 21.6 5A LCK-LED driver is the same as the 4.5A IOS driver - identical, only difference is the resistors, so it must be very modifiable by resistors. I got both side by side - clearly the same driver. the LM listing specs and left side photos match this driver as well. I don't understand their photos though showing 2 different parts: lightmalls-5000mah-3-mode.
Mass. Wine Guy
Last seen: 5 years 2 months ago
I'm new to this so please bear with me. I have an UltraFire single 18650 cell light using this bulb. What would changing the driver do and how easy is it to change drivers?
RaceR86
RaceR86's picture
Hi, on most lights its fairly easy to change the emitter. (Atleast when you are used to doing it). The main reason for changing out a driver can be:
- Increasing current on high
- More or less modes, with or without blinky  stuff
- Better mode spacing
- Getting moonlight
- A more advanced UI, programmable, hidden modes, battery indicator etc...
- Less PWM, not visible or audible
- Better efficiency..
- Better memory
- etc...
This is not the thread for your light though. This thread focus in maxing out the XM-L2 in larger lights using two batteries. This might also require modifications to the driver circuit. Using copper mounted emitter etc..  This thread is about taking the XM-L2 to the extreme. The emitter is rated for 3Amp max, which for most is a lot. Here I am looking for drivers that can be modded to do 6A+..  J) Or generally, just getting of list of extreme output driver circuits.
Read around on some build threads, stickys and stuff. That will give you some basic knowledge. In many single emitter lights (using 17mm driver circuit), a Qlite driver circuit is a very nice and simple upgrade. Make a thread about your light if you need help modding it...
RaceR86
RaceR86's picture
hmm.. good catch. I can not comment on the difference though. One light seems to have a large toriod and another picture uses a small one. Maybe others know more..
3A version small toroid, 5A version large???
Gtamazing
Gtamazing's picture
I swapped back to an xml2 on a sinkpad. However my driver must be defective, it only has off and on, no other modes. Now when it came in the mail it was broken squashed flat. I soldered it back together used it and forgot it was supposed to be multi-mode until you just mentioned it.
RaceR86
RaceR86's picture
Well, a single mode driver pushing 5A+ isnt the most practical driver. Did it come from FT?
Btw, when I read the part you have quoted me on. I have no intention of pushing an XP-G2 to 6A..  Only a bit more than 5 amps.. 0:)
But my STL-V6 driver might be capable of 6 amps for all I know.
___________________
Does anyone know if the manafont TR-3T6 driver can be used with a single XM-L2 and if it can do 5++ amps if modded?
Gtamazing
Gtamazing's picture
The driver came from DX
DB Custom
DB Custom's picture
Last seen: 3 hours 15 min ago
Planning a build on an M8, will see how these stack up. Thanks!
Tom E
Tom E's picture
RaceR86 - sorry didn't get back here - yes, from what I understand the bigger inductors are part of the circuit design for handling more power - amps.
Damn - the more I think bout it, the more I like that LM deal for the 5 pack - I bet the 5A version is with the bigger inductor pictured on the left, while the one on the right is the 3A version... I've been paying $12+ for the IOS one, bout double the price..... ugh
RaceR86
RaceR86's picture
Tom, did you pull the trigger on the 5-pack?
Some time back I tried to increase the output of the 5A IOS/LCK-LED/Lightmalls driver. But with my very limited testing, it did not seem like it wanted to go much beyond 5,2A (output actually got lower if I tried to increase a bit more)  I decided to leave it stock.  If others have tried to resistor mod these to more than 5A, please share.. Smile
I have updated OP a little bit. Added the TR-3T6 driver.
Tom E
Tom E's picture
No, but still got the IOS 4.5A an LCK-LED 5A. Someone or 2 did order the 5 pack. Thinking the 5A version is the big inductor, 3A small.
Ouchyfoot
Ouchyfoot's picture
Last seen: 4 months 1 week ago
I just installed an IOS 4.5A Driver in a Ultrafire F10 running 2 x NCR18650A and got 2.6A (5.2A) at the tail, and 4.52A at the emitter. (XM-L2). I’m impressed. A driver that does what it says it can do.
EDIT:Additional- this is a buck driver and needs two cells to run an XML-L2. Will also run on three cells.
unknown00101
Awesome, that is the driver I had in my sights for my DST mod. Though I would rather have a low enough voltage to run C’s or a single 18650/26650, but that isn’t a huge issue.
OT: Does IOS get scheduled shipments, or is it just random when they restock items? Been waiting a while for my noctigon emitter to restock.
Ouchyfoot
Ouchyfoot's picture
Just email Hank Wang (intloutdoor@gmail.com). He’ll let you know.
scottyhazzard
scottyhazzard's picture
Lightmall So how about the lightmalls 17mm 5a 3 mode driver? If the specs are credible then this appears useable on a P-60… Has anyone tried this version? Also if I wired the LED’s in parallel would this driver work on a triple XPG?
"Those who hammer their guns into plows will plow for those who do not."
FlashPilot
FlashPilot's picture
Last seen: 6 hours 7 min ago
Those look suspiciously like the junk left over from a failed attempt at flagrant deception by lightmalls. Of the two samples I tested with 3 × 18650 in parallel (4.20V), dedomed XM-L2 on sinkpad, 18ga wire, I get about 3.3A to the emitter. Lowest setting barley illuminated the LED so its completely useless. Mode changes requires very fast half-click button presses to get it to change. Extremely poor regulation where amps began to plummet around 4.05V.
moderator007
moderator007's picture
Last seen: 2 hours 18 min ago
Should work with a triple xpg if wired parallel. The driver appears to be a buck or just direct drive when the supply voltage drops below the vf of the led at 5amps. Notice what it says “Constant current output when the voltage is higher than the LED VF value”. Wouldn’t be much different if you just used direct drive, like the east 92 driver with a single 4.2v cell.
If you used a XM-L2 on a copper sink pad at 5 amps the vf would be around 3.75v. http://budgetlightforum.com/node/19331
If you used a Panasonic 3400mah or a sanyo 2600mah the voltage would sag below the vf of the led at 5 amps in under a minute. Then it would be basically direct drive after that point. http://lygte-info.dk/review/batteries2012/Common18650comparator.php
A 18650 IMR wouldn’t even be able to sustain 5 amps for very long. A XM-l on copper will stay in regulation longer, maybe around 10 minutes at 5 amps, just a guess.
scottyhazzard
Thanks Flashpilot and 007. Good information. Sounds like you guys think the 92 River driver is much better and I need to shop for some batteries. Thanks again for the info and links.
FmC
FmC's picture
Last seen: 1 day 10 hours ago
I bought a few from LCK LED a while back, ordered the 5a version. They came with large torroids, went to use one on the weekend, only put out 3a emmitter bench testing. It had 2 r200 sense resistors, so I added 2 r100 & it showed 7.something amps briefly before the xml popped. Removed an r100, & it tested 5a.
