Trustfire AK-90 (12)XML-U2 Hyperboost driver @ 2000ma
58 posts / 0 new
Hyprmtr
Hyprmtr's picture
Last seen: 3 years 1 month ago
Thank you Johnny!
The laser parts I get are bought all over, mostly China if that doesnt surprise you! Lol. Its like flashlights though, they say 1000 lumen, but your really get a 400 lumen light. Lol.
The 3.4W laser I gor from a guy in Tennessee. He personally measures each diode/driver assembly and writes it on the heatsink before he ships it out.
I have a 100mw 520nm green nonpump laser, a 635nm 800mw red laser, and I have two of the 3w+ 445nm lasers. Various others also. Those are my most powerful. Bought all from different places though.
Ken
Hyprmtr
Hyprmtr's picture
Oh, I have a little over 200.00 bucks in the 3.4W laser.
tkmckay
Last seen: 5 days 15 hours ago
Awesome thread Hyprmtr! I have always loved the shock and awe these huge multi-emitter torches bring especially when all moded up. Thank you for showing us the pics of what something like this can become when you go all the way and not only mod/swap the driver but replace the led’s which I don’t think a lot of people have done due to the high cost on a torch like this. :bigsmile: This is a dare to dream torch for me for sure!
blueb8llz
Last seen: 11 hours 25 min ago
is trimming the white spacer pretty easy to do? did relic explain how to do it in one of his threads?
i think id like to do that to my 9xml also. do you just use a very small round file ?
whats the longest amount of time you ever had it on high mode so far?
Hyprmtr
Hyprmtr's picture
blueb8llz wrote:
is trimming the white spacer pretty easy to do? did relic explain how to do it in one of his threads? i think id like to do that to my 9xml also. do you just use a very small round file ?
I got a good sized piece of 600 grit sand paper maybe 6 inch by 12 inch and put it flat on the table. Then I took the white plastic spacer put it on my finger tip and swirled it around flat on the sandpaper checking often to not sand too much off.
After the hieght was where I wanted it I beveled the inside of the white spacer with an exacto knife. That way the white spacers kinda flow into the aluminum reflector. Now there is a smooth transition from the white spacer to the aluminum reflector. No edges. If you blow up my pic of the reflector you can see a modified spacer and a stock spacer.
I dont know exactly how much it helped but how could you even tell with as much light this thing is putting out at 2A? You may notice a difference.
Ken
Hyprmtr
Hyprmtr's picture
I ran it about 3 minutes last night. It was getting warm. But not hot.
Ken
Hyprmtr
Hyprmtr's picture
Thank you!
garrybunk
garrybunk's picture
Last seen: 2 hours 16 min ago
Wow!  Just Wow!  Thanks for sharing!
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
NOTE: Moving my photos from PhotoBucket to Flickr. PM me or post in the thread if you can’t see my images and need me to fix or send a gallery link. PhotoBucket images should remain visible until November 2018.
Hyprmtr
Hyprmtr's picture
rikr
rikr's picture
Last seen: 1 month 1 week ago
-Garry
+1 WinkBeer
TrakTuned
TrakTuned's picture
Last seen: 3 years 12 months ago
Looks like I will be doing an emitter swap on my 9xT6. I ever so boldly dedomed ALL 9 Tired Killed one being lazy doing it without heat but that was the best thing that happened lol.
Put it back together, doesnt seem to throw much farther if at all and now is majorly ringy :Sp
Bummer. Well $60 later it should be nice neutral beautiful XM-L2 goodness!
If It has been stated already I missed it, what are you using for a driver?
BLF members are hilarious:
“That’s like saying “My car has top-speed of 200k millimiles per hour”. Why not to just say 10 Ah?”
Hyprmtr
Hyprmtr's picture
Im using a hyperboost driver from Taskled.com. I considered dedoming mine, I think I will leave well enough alone.
You should be able to turn up the juice with 9 emitters. Im stuck at 2000ma because of only 4 batteries. If you are using 4 lithium ion batteries you should be able to push 2.3A to the emitters with the hyperboost driver. George does not recomend going over 6A input current from the batteries with the hyperboost.
I got an additional extension tube for 5 batteries. I havent tried it yet.
Ken
FMcamaroZ28
FMcamaroZ28's picture
Last seen: 2 weeks 9 min ago
sounds like a real beast!
http://taskled.com/hboost.shtml
Quote:
Constant current boost regulator. Adjustable current limit set by precision multi-turn trimpot and/or external Potentiometer. Maximum output current 3200mA . Can drive multiple series connected LEDs. Operates from 8V to 50V. Maximum output voltage 80V (open circuit protected). Protected against reverse polarity connection. Regulator requires input voltage to be LESS than output voltage (Boost driver). Board is 1.3” in diameter. Maximum thickness is 0.35” (PCB + inductor height). Components only on top side of the board. For higher power applications the board can be mounted to a heatsink with thermal pad material.
Hyprmtr
Hyprmtr's picture
The HB flex has different modes too.
I like the all or nothing on my hotrod lights though. Smile
blueb8llz
wow, you ran it for 3 mins and it only got warm! that is waaaaay impressive. did someone say you are getting about 10,000 lumens? or was he just exaggerating?
my 9xml ak47 is doing about 6000 lumens, and it gets warm within seconds. the longest i ran it on high was for about 45 seconds, and it was very warm/hot.
the ak90 must have better heatsinking then
edit. actually just ran the light. it starts getting slightly warm at 20 secs. i ran it for a minute now, and the head is warm, not hot yet. but no way i would dare to run it for 3 mins.
Hyprmtr
Hyprmtr's picture
It probably was not exactly 3 minutes, Im just guesstimating. It was every bit of 2 minutes though. I will do some heat tests the weekend.
I used thermal compund on all the threads of the head the get use of the fins to disapate the heat.
Someone elses hot, may be anothers warm too. Smile
Ken
blueb8llz
thats true, but still, you have one bad ass mofo light .10, 000 lumens at that size and can be ran for a few minutes is super!
your medium mode is prolly my high mode on mine, and you can prolly run it on that mode for over 10 mins .
Tom E
Tom E's picture
Last seen: 1 week 5 days ago
Man, the more I think about what you've done, the more I'm thinking of doing soemthing similar to the J18 - taskled hyperboost driver, 7 XM-L2 U2's on copper, etc. It would be a mini version of yours but thinking I could exceed 6,000 lumens with it for sure, maybe hit 7,000, a whole lot cheaper - $45 host (WallBuys), ~$45 driver, about $35 in LED/stars using IOS's XM-L2 U2 1A or 1C's on Noctigons (at qty 10, they are $5 each!). Think that's about half your cost. The taskled driver seems vastly superior to anything else out there - just don't understand it all yet - not much info.
Hyprmtr
Hyprmtr's picture
blueb8llz wrote:
thats true, but still, you have one bad ass mofo light .10, 000 lumens at that size and can be ran for a few minutes is super! your medium mode is prolly my high mode on mine, and you can prolly run it on that mode for over 10 mins .
I have to say, for only doing this flashlight/laser stuff since about March, I have learned a lot!
My AK-90 does not have modes. Its all or nothing. The HBflex driver that Taskled has, does have modes. I will put the HB flex in my shorty 12 XML light when I get it from Kaidomain. Smile
Ken
Hyprmtr
Hyprmtr's picture
Tom E wrote:
Man, the more I think about what you’ve done, the more I’m thinking of doing soemthing similar to the J18 – taskled hyperboost driver, 7 XM-L2 U2’s on copper, etc. It would be a mini version of yours but thinking I could exceed 6,000 lumens with it for sure, maybe hit 7,000, a whole lot cheaper – $45 host (WallBuys), ~$45 driver, about $35 in LED/stars using IOS’s XM-L2 U2 1A or 1C’s on Noctigons (at qty 10, they are $5 each!). Think that’s about half your cost. The taskled driver seems vastly superior to anything else out there – just don’t understand it all yet – not much info.
Do it! You could probably turn the current up even more with “only 7” leds. Hehe!
The formula that taskled has on his site is what I have been using. The formula uses lowest voltage of your batteries so your very safe. Smile
Ken
TheGloriousTachikoma
Last seen: 2 years 3 months ago
And now you want to add another 4000mAh to this light? If you make it any bigger you’re also going to need a surplus MG42 tripod to mount this thing on. Silly
Hyprmtr
Hyprmtr's picture
Haha! This is definitely be a strap light.
8)
Ken
8)
Ken
Do you have a Trustfire X6? That comes with a sling. Or perhaps go tactical with a Magpul single-point or some other such nonsense :bigsmile:
blueb8llz
thats what im talking about, while your at it, make me one as well! LOL.
but wait a second, its not just about hitting that mark, but once your there, i dont think the j18 can handle all that heat right? itll just be like my 9xml ak47 @6000 lumens where your only able to use it for about a minute or two max each time.
for the j18, itll probably be worst.
why dont we do it real big, and get the 15xml and try and hit 12, 000 lumens!? LOL
i found it for $85 shipped.
you down!? LOL
Tom E
Tom E's picture
Been considering the heat mgt - easiest thing may be a big custom heat sink plug for the top of the pill, but some logistics issues there - can't get it in because of the smaller opening. Hhhmm - maybe replace the pill top with a big copper heat sink, or, cut the head off through the pill, add an insert, copper heat sink, and more massive alum cooling fins in the new section. This would increase overall length the pill area/flashlight size. Sounds like a project for MrsDNF, not me for sure...
The HBFlex driver sounds like the best -powerful mode setup, up to 3A per LED. I think 6,000-6,200 lumens total would be about the max. Hard to imagine getting 900 per LED at 3A, but not sure.
MRsDNF
MRsDNF's picture
Last seen: 10 hours 56 min ago
Tom E wrote:
Been considering the heat mgt - easiest thing may be a big custom heat sink plug for the top of the pill, but some logistics issues there – can’t get it in because of the smaller opening. Hhhmm – maybe replace the pill top with a big copper heat sink, or, cut the head off through the pill, add an insert, copper heat sink, and more massive alum cooling fins in the new section. This would increase overall length the pill area/flashlight size. Sounds like a project for MrsDNF, not me for sure…
I reckon you’d have to do me a plan in the dirt with a stick for this mod. Silly
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
blueb8llz
thatll be awesome hahah
ill purchase it from you after its done
