Slick looking 1-AA Q5 Zoom, price Drop, $4.24 from $5.99 shipped
47 posts / 0 new
ImA4Wheelr
Last seen: 2 weeks 5 days ago
That sounds about right to me, but you know way more than me about this stuff.  I don't know if the different emitters have different efficiencies.  I think the SK68 emitter XRE? has a narrower, more concentrated beam pattern.
I got what seems like a nice glass 18mm lens from ebay for cheap, but it doesn't work in the "Slim" (does this light have a real name?) because it's focal length is pretty short.
djozz
djozz's picture
Last seen: 44 min 16 sec ago
yes, the XRE is  a bit narrower than the xpe, but not that much, and if both emitters are Q5 bin, they should be just as efficient. The XRE tends to be a bit cooler tinted than the xpe in most cases.
If you manage to get the new lens a bit closer to the led one way or another (sanding a bit off the head-tube  perhaps?) it could focus well. You'll get more flood, a bigger hotspot, but about the same throw.
ImA4Wheelr
Updated post 29 with the numbers I had written down at the time.  No real change, but wanted to have the actual numbers documented.  I really like the light because it's so easy to carry.  Next mode memory isn't too bad in a 3 mode light, but I would like to get rid of that.  Also need to drop a Nichia 119 H1 in his baby.
Someone should do a review on the light when they get one.  I just have too much going on at the moment.
Pregulla
Pregulla's picture
I bought a black single mode one for $3 (auction) on ebay. Happy with it so far. It is slightly dimmer then SK68 but has a nicer beam, it focuses to a tighter spot and flood beam is smooth and very wide – 1.5-2 times wider than SK68 (depends on SK68 model). The zoom mechanism was very loose – the head would slide a bit under it’s own weight if pointed up or down. Adding a layer of teflon tape under the o-ring on the pill fixed it. It accepts 14500 but doesn’t get any brighter on it.
Lennart
Lennart's picture
Last seen: 8 months 4 weeks ago
Bought two black from Wallbuys, real jeans pocket edc size. Mine are brighter with 14500 but not as Sipik. Like the size and will use it.
Lennart
lhartman89
Last seen: 6 years 1 month ago
I bought 2 of these from WB also when they had them on sale for $2 each. The tint is more of a purple/blue and it’s not brighter than my SK-68 clones. Also, the beam is a little ringy when zoomed out. I really like this thing. I checked the tail cap current and got 900mA on high and 200mA on med/low with a 14500. Also, mine resets to high after a while.
unknown00101
I also got 2 black. I tried AA in one… dimmest light in collection. With 14500 they’re actually worth the $1.99 (echoing, no where near Sk68).
I like the easily removable clip too. Having to file down the screws for the SK68 clip was tedious (unsure if the clip will even be able to be put back on now).
hank
hank's picture
Last seen: 2 hours 33 min ago
> nowhere near the SK68
Only problem I have with the SK68 is overheating if I try leaving it on (like to work under the house on wiring or plumbing).
So if these are cooler as well as dimmer, it’d be worth having.
Fritz t. Cat
Fritz t. Cat's picture
SK 68 3 modes on low don’t overheat, but small size is a big advantage. I also have on order two more SK 58s. SK 68s are probably OK left on high if you avoid burning your hand. They have a lot of cooling area, well shaped fins and they heat up uniformly, shoeing the heat distribution is good.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
Serenity
Last seen: 2 years 2 months ago
I’ve got a gold and a black one from Wallbuys. The black one works well and pulls about 1.5A from an Eneloop. With a dodgy 14500, I measured about 0.5A, and it did seem a bit brighter.
The gold one has issues, flickering on all modes, probably because of a bad contact somewhere in the head part. At some point it had a consistent output for a while, but it was a bit less bright than the black one. The lens unscrews easily, but I’ve not yet managed to get the pill out. Has anyone managed that? Is it threaded or press fit?
Manafront has same lights that look exactly the same listed as UniqueFire UF-V25 (with logo and type number printed on it):
http://www.manafont.com/product_info.php/uniquefire-ufv25-cree-xpe-led-3...
Pulsar13
Pulsar13's picture
Last seen: 10 months 6 days ago
Threaded, same way sith sk68. I opened up quite a few using a tiny screwdriver. I have 10 of these ($1.99 ea) and love them. ESPECIALLY the high pwm. How is it I always get very high pwm on ultra cheap lights like these and the Ultrafire S5… but low lame PWM on more expensive ones (SRK, 3T6, MF drop-in… well expensive for me at least).
To solve flickering issue – the problem is the connection between driver and body. Take the pill out and push/tap the driver in with a small mallet. Works great.
Serenity
I haven’t managed to get the pill out. Didn’t work with split ring pliers, and didn’t want to force it and damage them. Took a pretty strong U shaped nail and bent that to fit, but it twisted, trying to unscrew the pill, even with the nail put in a vise. In the end I just put a stick in the battery compartment part and tapped the driver board a few times, and that fixed the flickering issue. Thanks for the tip.
Any ideas about the tail cap? One of the boot rubbers isn’t seated quite correctly, and I can’t really push it back in properly from the back. So I guess I’ll need to remove the switch from the inside. But I haven’t found a way to remove the plastic piece with the spring yet (without damaging it).
Serenity
Just got the boot out by just pushing from the back, after pulling out the switch boot. It’s just a single switch assembly with 2 contacts on the side.
Fritz t. Cat
djozz wrote:
xatu wrote:
That flashlight is less bright than a sipik sk68 clone, a guy that have it wrote it.
And the lens has a longer focal length by the looks of it: so smaller hotspot but not brighter.
I only measure 10% less current, but it seems to be a bigger difference without the thin leads of my meter. In addition to the lens being smaller and longer focal length, they must have tuned the driver for the smaller cooling area and mass. I think it is a great light for general use, just not for light hogs and collectors.
The other thread on this is http://budgetlightforum.com/node/25402#comment-494167.
On Amazon it is called “Foxnovo® 508 Focus Adjustable CREE Q5 3-Mode 250-lumen Mini LED Torch Flashlight with Pocket Clip (Black)” and sells for $11. My guess is that all are coming from the same production line and that they are making a lot and therefore marketing them in several ways at once.
hank
hank's picture
cross-reference: http://budgetlightforum.com/node/31780#comment-591154
This is called “#3” in the topic about AA/AAA lights under $10 — a good and growing compilation.
And if anyone knows a reliable source for these with solid pills — I’m looking.
They happen to perfectly accommodate the 10mm square boards that Luxeonstar sells with all colors of Rebel emitter — drop right in, wire holes are open, four corners of the square center the emitter in the round cutout — and the solid pill (the … one … damn … solid … pill) makes a great heat transfer backing for the board.
hank
hank's picture
Double checking — any solid pills among the many lottery versions of this light that y’all have bought?
(Only one I know of that has a solid pill is the Rustu from DX recommended at http://budgetlightforum.com/node/29459 )
(I like dropping Luxeon PC Rebel emitters of various colors into these — I found them from luxeonstar on a square 12mm board, which fits perfectly into the ring for these #3 and SK68 lights — touching at all four corners with the emitter centered. On a soild pill that’s perfect. On a hollow pill it’s almost zero contact for heat transfer)
