Great data. Thanks for sharing. It certainly performs well it seems! :)
Its always interesting to see how temperature and CRI change depending on current. What kind of equipment is needed to get those values?
Were these numbers done by foxtrot 824? Just curious if these numbers are directly comparable with these results. I rarely read anything on CPF, but I came across those numbers once. I would not mind seeing more testing like that.. :) (links are appreciated)
How instant is this instant on? I always find an output drop in the first three seconds after switching on, from internal warming up of the emitter, no matter how well it is mounted.
RaceR86,
I had requested this LED to be tested and even though he is a very busy guy he graciously accepted but requested not to be mentioned as he didn’t want others asking for more LED testing.
That being said, yes these numbers should be directly comparable to your link.
djozz,
All I was told was these were instant ON measurements.
It was mentioned to me that for the higher current measurements there is probably at most 10-15% loss of output due to heat.
I was also told that the testing jig is all aluminum so it soaks up the heat nicely but it does get warm to the touch.
I also believe the testing was back to back so the LED should have already been warmed up internally.
I hope that helps.
Hehe... the numbers you shared looked like his work. Have he done similar stuff in the past that can be found online? (except the Nichia 219 testing I linked to earlier) Normally I don't read on CPF.
Btw, for people reading, his blog has some cool stuff. :)
