3C, not 2C MT-G2 Maglite Mod - BEAM shots are up in Post #1 and it's done!!!
40 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
Hello,
I need some music to complete this mod...
So...
It's a 2C 3C, my apologies. I ordered a 2C and I got a 3C, but I never checkedEmbarassed till I actually put the batteries in today. It's a 3C Maglite and I'm putting an MT-G2 led in it with a DrJones ramping driver, using comfychair's mod (Thanks cc), to make a NANJG driver work with higher voltages. I am using two 18650 Li-ion cells and well,... hell, just go look at the derned photos.Wink This is one that I've had sitting around for a long time, never completed and I figured I would clean up all the leftovers around here. Spring cleaning in the fall.
2c1a
2C Mag, MT-G2 led, "O-L ring", polished reflector, 7135 driver, momentary switch, glass lens and the Heat sink was made by Texas Lumens (Thanks Dan!!).
2c1b
The photo of this modified driver is not the one I actually ended up using. I thought it was a DrJones driver, but it wasn't, so I had to do another one. The one I am using in the light involves a zener diode and 200 ohm resistor, don't ask me, I had to PM comfychair and he had to hold my hand through the whole process. It is beyond me, I just followed instructions. I also added six extra 7135 chips to the driver. No, it won't produce the full amperage, but it will get to at least 4 amps and that's enough for me.
2c1c
I will be fitting this momentary switch into the stock switch housing. Just a little dremel action should do the trick.
2c1d
The reflector and ring are what I did the testing with a while back and I have hand polished the reflector. It was one that I ruined many moons ago and I decided to salvage it if possible.
2c1e
I used a dremel cutter bit and the drill press to open up the head of the Maglite and to cut down the reflector major OD so it would all fit tightly together.
2c1f
The heat sink is courtesy of Texas Lumens. He did a real good job with it and even made a threaded hole for an allen set screw.
2c1g1
I was going to make this another "Flame light" and I bought some 3m film that is supposed to be for masking in plating operations. It didn't work well at all and in a few minutes, the de-anodizing solution got under the tape. Now you can see the outline of the flames. The paint is VHT caliper paint and it's baked on.
sc123
I painted the head too.
2c2a
The switch housing has been opened up so that the new momentary switch will fit in flush.
2c2b
The positive contact for the battery is on the switch housing.
2c2c
The housing and switch are in place.
2c2d
Looks like a stock switch to me.
2c3a
The driver is wired up to the switch and to positive and negative. The stock negative contact in the Mag switch is where I am getting negative for the driver.
2c3b
The pill is wired to the driver and it's all ready to slide in.
2c3c
There you go. In place and the set screw is tightened to keep the heat sink from moving.
2c3d
It even works. I am getting a consistent 4.2 amps on high using the 18650 batteries.
2c3e
I bought some decent 18650 batteries and this is the temporary holder. I will be making a better sleeve later on, but I gotta try this light out!
2cb1
When I turned it on high, the camera shook in fear, LOL. It's a fairly bright light.
2cb2
Not much to say, it's a floody light. It won't be a thrower, but I didn't want a thrower. It's a very big hot spot and some spill. A deeper reflector would produce more spill, but this is good enough.
I still have to do some cosmetics before it is done, but it works and that's good enough for now...
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 09/08/2013 - 23:04
Old-Lumens
zaq1
zaq2
zaq3
zaq4
zaq5
Enough...
I will do some beam shots tonight. I removed the "O-L collar" and I am just using the reflector now. Right now, it seems to be great for a "flood to throw". I will do some beam shots of that comparison, but turned all the way in (past the die), it is totally floody and turned way out, it actually focuses a fairly good spot.
Beam Shots: Flood versus Throw. These are with the OL ring taken out. The bottom of the reflector has a 21mm hole in it, so I can screw down till it's down past the star. Flood is all the way down and the best throw, (spot), is turned way up till the reflector is higher than the led die.
fth1
I went all the way down to a 125th of a second, to show the beam. The MOUSE OUT is FLOOD and the MOUSE OVER is THROW. Notice the donut hole in the flood shot, but not in the throw shot.
fth2a
Here it's at 1 second, (my standard setting), the donut hole is basically gone because it's just so damned bright. MOUSE OUT is FLOOD and MOUSE OVER is THROW.
fth3a
Here's a better distance to see the difference. MOUSE OUT is FLOOD and MOUSE OVER is THROW.
This light will never be a thrower, but now it's a Maglite, being that it is adjustable from flood to throw and overall, it does it better than a stock Maglite.
I love the DrJones program. This one is set with four modes and ramping, as well as the hidden flashy thingies I never use.
That's all. It will go up for auction very soon.
18sixfifty
18sixfifty's picture
Very nice looking beam on that one. Great build.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
DBSAR
DBSAR's picture
Last seen: 1 day 17 hours ago
nice job on the Mag mod Smile i had so many ideas of modding the 3D Mag i have kicking around, ( and the handfull of 2AA MiniMags) but not sure what yet.
MRsDNF
MRsDNF's picture
Last seen: 21 hours 9 min ago
Wow. These led’s are unbelievable to me in their own context. 4.5 amps should be the sweet spot between a heater and an oven with decent light output. Again what do I say. Very clever and creative. Its a shame these leds are so expensive. I have five on order and there is no change from $110.00 US. Looking forward to your next build. Thanks for sharing and it’s fantastic that others take their own time to help others out. Cheers all.
skyrider1
Very nice. Is the C body wide enough to be bored out for 26650s?
spaceboy
Last seen: 4 years 1 month ago
Want
bibihang
bibihang's picture
Last seen: 1 day 4 hours ago
MT-G2 mods are not easy. Incredible!
StorminMatt
The C body is wide enough to take 26650s provided that it is an older light (no C in the serial number). Newer lights need to be bored. On the other hand, getting 2×26650 in a 2C light is going to be difficult due to length issues. I actually grabbed a couple of 18650s and stuck them in my old 2C Mag. And they protrude about .75 inch out the end. The tailcap won’t go on all the way with these cells. But you could certainly make it work (I’m guessing this light here probably has some switch mods to make the batteries fit, especially since his 18650s are probably longer than my unprotected LiFePO4 18650s). But with 26650s, the cells can’t fit in the recess on the tailcap. So you couldn’t get the tailcap on AT ALL. On the other hand, a 3C Mag will fit 2×26650 without modification (provided it is an older light). The same goes for a 4C with 3×26650.
Without lamps, there’d be no light.
jmpaul320
jmpaul320's picture
Last seen: 4 hours 40 min ago
wow
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
Hill
Hill's picture
Last seen: 1 year 1 month ago
Nice job Justin!
My lights here and here
jdunlap27284
Last seen: 2 hours 38 min ago
Very very nice!!
jacktheclipper
jacktheclipper's picture
Last seen: 6 hours 24 min ago
Cool
Gtamazing
Gtamazing's picture
Last seen: 2 years 1 month ago
The 2c is a great package.
Pinetreebbs
Pinetreebbs's picture
Last seen: 1 month 1 week ago
Nice work!
phantom23
phantom23's picture
Last seen: 2 weeks 3 days ago
How did you make 3,7V driver to power over 6V emitter?
RaceR86
RaceR86's picture
Nice work. What do you use around the switch wires? The white stuff?
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
LumenHound
LumenHound's picture
Last seen: 4 days 12 hours ago
A pair of unprotected 18650 cells that don’t have tall positive buttons will fit fine in a newer 2C Mag if you remove the anodizing on the inside of the tailcap and slide a low profile spring into the rear of the cap. Hundreds of incan ROPs were made this way. A pair of unprotected ICR 25500 cells is also an option but you still need to ditch the stock tail spring for one that rests in the same tailcap groove but is low profile as well.
Old-Lumens
Sorry everyone. I ordered a 2C Maglite and I did not bother to check the length of it. I just started the modding and I didn't actually put batteires in it until after most everything was done and the thread was started.
It is a 3C and it could be bored for 26650, but with the newer 10 amp 18650s, I just don't see the need for 26650 batteries.
@RacR86: The white stuff is Arctic Alumina Adhesive.
Old-Lumens
Glamour shots in Post #1.
Flood to Throw Beam shots tonight.Wink
moderator007
moderator007's picture
Last seen: 12 hours 6 min ago
Nice job OL. Awesome beamshots. Looking forward to more.
I wonder what the rebel reflector would look like with the MT-G2? If it be any tighter or about the same.
Old-Lumens
moderator007 wrote:
Nice job OL. Awesome beamshots. Looking forward to more. I wonder what the rebel reflector would look like with the MT-G2? If it be any tighter or about the same.
Possibly tighter, but also more/wider spill, since it's a lot deeper reflector.
Old-Lumens
http://budgetlightforum.com/node/22379?page=1#comment-411039
http://budgetlightforum.com/node/23683
Old-Lumens
Beam shots of Flood to Throw are up in Post #1.
It's done, have fun!
DB Custom
DB Custom's picture
Last seen: 6 days 23 hours ago
But I don’t remember for the life of me…what do you use to strip the anodize? I tried a Sulfuric Acid solution today and it just didn’t get the job done. Eats everything else, just not the black anodizing on a Defiant 3C.
Really nice looking light, that one is, great that it still adjusts for the spot. Like that.
Old-Lumens
DBCstm wrote:
But I don't remember for the life of me...what do you use to strip the anodize? I tried a Sulfuric Acid solution today and it just didn't get the job done. Eats everything else, just not the black anodizing on a Defiant 3C. Really nice looking light, that one is, great that it still adjusts for the spot. Like that.
Greased Lightning found in Lowe's or Home Depot, in the household chemical sections. Yellow Gallon Bottle, red label "Greased Lightning Super Strength".
It takes about an hour to two hours for type II and it takes longer for type III ano. I use a plastic container, sit the part in it and fill so the level is a couple inches above the part. If I were to strip a 2D Maglite, it would take a full gallon in a good sized container. I sit the parts on end, never lying flat, (like a body tube) and I turn them end to end about every half hour. When I see the color coat is gone, I take them out, rinse them in another container of water and steel wool them to remove the residue and then put them back in. Sometimes it's hard to judge if the actual base ano layer is gone, as it looks like aluminum, but steel wool will usually tell, as the ano will not shine up, but the bare aluminum usually will, (unless it's a cheap Chinese aluminum and then it won't shine up too well).
panthervision23
Last seen: 6 years 2 months ago
Great job! I can see it the way the beam shots illuminate the areas during the night. They’re very bright!
DB Custom
DB Custom's picture
I probably didn’t stick with it, only had it in the acid about an hour…was afraid the threads were gonna get killed. Will the Greased Lightning eat the aluminum at the unprotected threads? Is there a way to mask off those so there’s no issue?
I really like how you get yours chrome looking but the Mag etching still shows, looks factory that way. Ever re-anodize and just leave em clear?
Old-Lumens
DBCstm wrote:
I probably didn't stick with it, only had it in the acid about an hour...was afraid the threads were gonna get killed. Will the Greased Lightning eat the aluminum at the unprotected threads? Is there a way to mask off those so there's no issue? I really like how you get yours chrome looking but the Mag etching still shows, looks factory that way. Ever re-anodize and just leave em clear?
I have never had it eat the bare aluminum or threads. I supose it could after a longer time, but I've never seen it.
I have thought about anodizing, but I would want to "do it right" and that costs a lot, plus I have no way to dispose of the used chemicals or "dirty water".
TexasLumens
TexasLumens's picture
You're welcome Justin!!  That's a great looking light and the beam shots are superb. I like that tail cap decoration. Your work just balances out a light!!! Super nice!!
 Cool! I have a part inside an Old Lumens Mod!!! Can't beat that!  I'm not sure my head will fit through the door now!! Tongue Out  The little part was fun to do! Enjoy!
Dan.
Texas Lumens Website… http://www.texaslumens.com
WE LIVE IN THE LAND OF THE FREE ONLY BECAUSE OF THE BRAVE!
MRsDNF
MRsDNF's picture
TexasLumens wrote:
You’re welcome Justin!!  That’s a great looking light and the beam shots are superb. I like that tail cap decoration. Your work just balances out a light!!! Super nice! I have a part inside an Old Lumens Mod!!! Can’t beat that!  I’m not sure my head will fit through the door now!! Tongue Out  The little part was fun to do! Enjoy!
Dan.
I am slightly jealous. I still love your work though TexasLumens. Love
